Question about Garden
I need an engine diagram to help repair a Kirby tecumseh motor
Just need info to recondition the above 4 stroke motor
  • Garden Master
  • 2,478 Answers
Go to youtube On line overall kirby tecumseh moyor
Posted on Nov 22, 2013
2 Suggested Answers
  • 6 Answers
SOURCE: my lawnmower engine cuts out
I was having the exact same problem with my 6.5 hp Toro lawnmower with a Tecumseh engine. The engine would start up okay but after a few minutes of mowing, the mower would start missing and eventually shut down. I would pull and pull and pull on the starter rope, getting angry and frustrated and eventually going back in the house to let it cool down.
I looked up all kinds of information and I finally decided it was a bad coil (something about the resistance being low when the mower wasn't hot and then when it heated up the coil would conduct enough electricity to somehow make the engine shut down.)
I called a local shop and wanted to get an estimate on replacing the coil. I have no clue about engines so I dared not get into the guts of the mower myself. He told me to check the gas cap. HUH??????
He told me to make sure there wasn't a part missing out of it. I thought, what the heck would a gas cap have to do with the engine shutting down. Well, apparently there is a mechanism on these caps that prevents a vacuum from pulling on the fuel system and my gas cap indeed had a part missing. To verify this, I cut the grass for about 5 minutes. When it started to run rough, I took the gas cap off to allow pressure to escape from the gas tank and voila! it started to purr like a kitten.
So, I'm only out $4 for a new gas cap and I'm as good as new. Man I wish I was more mechanically inclined so I hope your problem is as easy to solve as this one.
Hope this helps!
Posted on Apr 14, 2009
Need a engine manual on victa RM-40P lawn mower
looks closest to an early sanli /honda clone motor
cant find its user manual
coil failure common
spark plug lead caps crack and arc
metal carb easy to clean and maintain
round air filter
valve clearance
piston to top of compression
valve clearance gap is like 3 -4 thou
Nov 22, 2016 | Garden
Do I use reg gas or a gas mix?
Matt, If engine is two stroke and not oil injected then yes you must mix 2 stroke oil and fuel. 4 stroke engine have a crank case which is filled to proper level with 4 stroke engine oil. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Decide Between Two or Four Stroke Outboard Boat Engine
4 Stroke Outboard Motor vs 2 Stroke Outboards
2 stroke outboard Vrs 4 stroke outboard
http://www.cottagetips.com/tips/boat-motor-gas-to-oil-ratios
Apr 15, 2016 | Boating
Tecumseh Engine Diagrams
the best way is go to the website from tecumseh, or get support via ONLINE chat for suministration of engine diagram. However try with this. www.servicemanual.net
God bless you
Nov 21, 2013 | Garden
Hi i have a Ryobi c430 weedeater, what petrol do i use in it?. is it 2 stroke or a 4 stroke motor? i dont have the manual for it. thankyou
This is a 4-Stroke model. Just use regular unleaded gas in it. Here is a viewable manual of models like yours.
http://dl.owneriq.net/8/8875c2d5-4f85-4c2b-a141-df69cc2b8e93.pdf
The manual is 52 pages and takes a little time to download.
Oct 29, 2010 | Ryobi 15" Electric Factory Reconditioned...
Warranty info on 8 hp Tecumseh motor
rowville mowers 03 7534443 can help you with a warranty issue.. BYNORM is the company that handles the Tecumseh engines... you could ring them for you nearest local dealer (03 9796 4244 bynorm no.)
Jul 14, 2009 | Heavy Machinery
What oil do I put in my 4-stroke Troybuilt weed trimmer?
According to troybuilt, here's their info.
For Briggs & Stratton engines use an SAE30 oil above 40 degrees F (4 C) and below this temperature use 5W-30.
For Tecumseh engines use an SAE30 oil above 32 degrees F (0 C) and below this temperature use 5W-30.
For Kohler L-Head engines use an SAE30 oil above 32 degrees F (0 C) and below this temperature use 5W-30. For Kohler Overhead Valve engines use a 10W-30 above 0 degree F (-18 C), and below this temperature use a 5W-30.
For Honda engines,10W-30 is recommended for general use, and above 55 degrees F (10 C) you can use an SAE 30.
For MTD Brand engines, SAE 10W-30 is recommended for general, all-temperature use.
K
May 25, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Wiring diagram
If theres wires coming out of the motor it is more than likely an electric motor , If it is a gasoline engine it is a 4 stroke engine
Dec 05, 2008 | Air Tools & Compressors
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
