Question about Plumbing
Franklin electric motor wiring diagram for 1101671700
2 Suggested Answers
  • 523 Answers
SOURCE: I am replacing my well pump/motor and need the
This attachment should answer any questions you may have on the electrical connections
http://www.franklin-electric.com/business/WaterSystems/service/AIM/default.aspx
Tom
Posted on Oct 03, 2009
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
Jan 23, 2016 | Dayton Dryers
I have a franklin electric 4
I have plenty of children and grandchildren, none with my name..... Cash is better but that is not what I'm doing this for.
Sounds like your system is "water-logged", shut off the pump, drain the bladder tank and check air pressure in the bladder. Set it to about two psi below the normal cut on point of the pressure switch. If that doesn't solve it, post again.
Sep 10, 2012 | Franklin Electric 1/2Hp 2-Wire 110 Vlt Sub...
Franklin Electric model 1103012431 Nameplate is 115/230. The motor is to run on 115VAC. Which terminals is the 115v to be connected to?
I live in Canada and this is how mine is wired. Your colour coding may be different so, if your motor fries, don't come looking for me. Use at your own risk. (The motor does work, at least.)
Standing behind the motor where you can read the faceplate, the electric box is on the bottom right. Inside that box, one power feed wire goes to ground, the black wire goes to the far left terminal closest to the motor and the white goes to the far right terminal. The 2 center terminals lead off into the motor. Mine is running on standard household 110 or 120V, whatever it is.
Aug 01, 2011 | Kitchen Appliances - Others
Looking for model #2243019204 pond pump motor 2hp 3450 rpm 230 v ph1
This model is a well pump not a pond pump. http://franklin-electric.com/model-search.aspx Did you enter this information in a Google search? locator.aspx">http://franklin-electric.com/dealer-locator.aspx. I also see this pump is available @ Lowes if you live in the USA (please don't say).
I trust this response answers your question.
Thank you for your interest in FixYa.com
Mar 02, 2011 | Franklin Garden
I can't get the high speed motor on. It operates in low speed. Is there a wire diagram?
All pool and spa motors are required to have the wiring diagram on the side of the motor.
Oct 19, 2010 | Franklin Pool & Spa
I just purchaced a 4hp franklin spa pump. It is for a nuwave 2000 spa. The plug from the control panel has 4 wires, black, red, white and green ground. Where do the red, black and white wires attach on...
WHITE wire is your neutral so will go as blue wire.
BLACK and RED wires are your high and low speed for your pump.
I would plug red and black into either, plug in and turn spa on - if high speed comes on first then turn spa off and swap red and black wires round. the side of your pump or under top of control unit will give you a diagram of where high and low speed goes.
Adam Miller
Service Manager, Canadian Spa Company, UK
Aug 11, 2010 | Franklin Pool & Spa
How do you wire a 2 wire Franklin 1/2 HP 10 GPM
you can just install a regular plug to the end of the wires and plug it in,, but you will need to add a ground wire,, if there is only 2 wires there should be 3 so look for a screw with a spiral clasp on it for the ground,,
Apr 21, 2009 | Franklin ELECTRIC/LITTLE GIANT PUMP 1/4HP...
Plumbing Logo
67 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
