Question about Dell 2007WFPB LCD Monitor
Dell 2007wfpb monitor won't turn on. - Dell 2007WFPB LCD Monitor
4 Suggested Answers
toolkits
  • 1099 Answers
SOURCE: Dell 2007wfpb monitor. No power present. Looked at
First check on the fuses in the panel, if bad replace with the same current rating, but if ptherwise Power supply board just die.It can be dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Jun 27, 2010
  • 117 Answers
SOURCE: i have a Dell 2007WFPb
Here is one of the simple solution to your issue.
I suggest your try a different outlet, if your using a strip, try connecting it directly to the power outlet. Also most of the monitor has the same power cable as the computer, try swapping the power cable and make sure only the power cable is connected to test the monitor. If still doesnt power on, call Dell and have it replaced if still has a warranty if not, repalce the monitor.
I hope this resolve your issue.
Thank you for choosing fixya
Posted on Mar 04, 2011
Slasher_X
  • 767 Answers
SOURCE: I have a Dell 2007WFPb 20
If your LCD monitor displays your desktop fine as it boots up and then goes blank after a few seconds, but you can still faintly see your desktop then this may seem like a brightness issue but it's not. The picture displays very faintly, this is because the LCD backlighting isn't working properly. Which in turn is either because (most likely in cases like this) the inverter circuit has failed or the cold cathode tube has blown. If you're new to the electronics business and are not sure how to solder and connect circuits then this is the job for a qualified repair technician. So i suggest you head on down to your local PC store and have a technician take a look.
If you want to try it youself go here to order some spares.
If the monitor switches off and you can't see your desktop faintly then this may just be a power saving issue. Yo fix this check out my other tip here.
If your monitor is less than a year old then I suggest you take it back to where you bought it and have them send it in for repairs or swop it out with a new one. LCD monitors usually have at least a 1 year warranty sometimes it can even be up to 3 years if you register yours when you purchase it or if it's a really expensive screen.
If the monitor is a good 4-5 years old then it may not be worth fixing or may be too expensive. I suggest you invest in a newer widescreen option. LCD monitors have drastically come down in price over the years and you can easily get a wopping 23" for as little as $180.
Posted on Dec 15, 2011
Dell Pc won't boot gets black screen with floating dialog box
Floating dialog box is the monitor's self test. Your monitor tests good. Your computer is the problem.
Mar 04, 2013 | Dell Dimension 3100 PC Desktop
E248WFP (external) Monitor Won't Power Off when Laptop Screen does!
this is not a pc problem... this is because the connection loss between pc and monitor... not all pc's have sleep mode in externa vga connection.... it just cuts power off... u can configure monitor of possible to do that..
Jul 09, 2012 | Dell UltraSharp E248WFP 24" LCD Monitor
Dec 14, 2011 | Dell 2007WFPB LCD Monitor
No power ho to remove cover to check fuses
You lift up the front bezel and then work your way around, when yoy have to the top and the Left and Right bezel loose, place the monitor face down and then remove the back, just watch out ont e front panel cable.
http://s807.photobucket.com/albums/yy352/budm/Dell%202007FPB/
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Replacement board: http://www.lcdrepair.us
http://www.lcdrepair.us/Installation.html
Apr 03, 2011 | Dell 2007WFPB LCD Monitor
I have a Dell 2007WFPb 20`` Widescreen TFT Flat Panel Monitor. I cant seem to power up. What is the problem here?
Mar 04, 2011 | Dell 2007WFPB LCD Monitor
I have moved my monitor to another computer and the USB ports no longer work??
Did the monitor come with the computer that you are moving away from?
If so, it's because the 'drivers' were already installed for when the computer was made.
Some Operating Systems (Like Vista) will automatically detect the new software (your monitor) and download the necessary drivers.
However, if you have moved the monitor to a computer that is foreign to this particular monitor, you will need to go to Dell.com and locate your monitor and download the drivers for it.
Save the file to your desktop and once downloaded, double click the icon and follow the on screen instructions.
Good luck
Jan 23, 2011 | Dell 2007WFPB LCD Monitor
Dell 2007wfpb monitor. No power present. Looked at capacitors but saw nothing unusual.
Jun 27, 2010 | Dell UltraSharp 2007WFP Monitor
About a week ago my Dell 2007WFPb LCD monitor (purchased in 2007) flickered on and off PIP mode, and would not stay on one setting for PIP for longer than 2 seconds. It was not fixed and now the power...
Not the power cord problem at this point, more likely to have failed Power supply or Inverter board.
http://lcdrepair.us/2007fpw-power.html
http://lcdrepair.us/2007fp-inverter.html
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Jun 15, 2010 | Dell 2007WFPB LCD Monitor
The on and off button won pop back out so that i can push it in to turn the monitor off and on.
Call dell with the 20 digit serial no at the back,if it is in warranty you will get a replacement monitor for this issue i had the same problem mine was replaced
Normally Monitor has 3 year warranty for parts
Dec 30, 2009 | Dell UltraSharp 2407WFP 24" LCD Monitor
COMPUTER WON,T YURN ON
first of all,is your power cable properly connected to your system unit.if it is not,connect it properly and turn the system unit on again
secondly,make sure your signal cable from the monitor to the system unit is properly connected
after following these instructions,reboot your computer again.
thank you for consulting fixya with your problems
Feb 14, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell 2007WFPB LCD Monitor Logo
59 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
