Question about Frigidaire FEF364DQ Electric Kitchen Range
My Frigidaire ele. convection oven only heats up to 287 drgrees
  • Official Brand Answer
  • 4,342 Answers
Good Afternoon Mitchel, thank you for your inquiry!
It could mean a few things in why your range is taking a long time to reach desire temperature:
    ·Convection heating element
    ·Thermal cutout
    ·Thermal oven sensor
    ·EOC (electronic oven control)
    ·Ignitor
    ·Bake or broil element
    ·Shorted wired connections
    It would be advisable for the above parts to be properly diagnosed by an expert to determine the root cause to reduce the risk of unnecessary parts. Best regards!
Posted on Nov 25, 2013
  • 52 Answers
SOURCE: frigidaire oven will not heat up
here is a list of error codes that may or may not be displayed by the oven.
Frigidaire Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Electronic oven control failure Replace electronic oven control (also called EOC or clock). F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock). F2 Oven temperature too hot Check and replace oven temperature sensor (RTD). F3 Open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F4 Shorted oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Electronic oven control failure Replace electronic oven control (also called EOC or clock). F6 Electronic oven control failure Replace electronic oven control (also called EOC or clock). F8 Oven door lock failure Check lock relay and door switches.
Posted on Jan 29, 2008
SOURCE: convection cooking
Convection ovens are great for roasting!
I cooked a 15 lb  stuffed turkey in 2 hours in mine. And it was juicy and fab!
My auto degree set for convection  is 325.
I have a Jenn Air wall oven, so I don't know, it might be different for different brand.
Roast or bird should be in the middle of the oven. THe air has to circulate well to get best results.
I believe rule of thumb is a convection oven takes 1/2 LESS time than conventional.
Hope this helps.
Posted on Jan 13, 2009
  • 464 Answers
SOURCE: frigidaire plef398ccc displayed 'er' now won't heat cooktop/oven
You could have a problem with the user interface board, which is #97A in the attaced breakdown, part #316225039500. Hope this helps.
Posted on Nov 16, 2009
  • 557 Answers
SOURCE: I have a Frigidaire smooth top range with
make sure you have 220 voltage to the stove
Posted on Oct 20, 2010
  • 5467 Answers
SOURCE: lost manual for Frigidaire gallery gas oven. need to know how to use convection baking
What model Frigidaire oven do you have? Most Frigidaire manuals are available from the manufacturer's site: http://b2b.frigidaire.com/support/manuals.asp or http://www.frigidaire.com/Owner-Center/Product-Support-Manuals/ . Note: these manuals are in the PDF format; you will need Adobe Reader or a similar program to read them.
For example the User's manual for the FGGF3054MW range (with convection oven) is available at http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316901218en.pdf .
I hope this helps.
Posted on Apr 14, 2013
Self cleaning mode towards the end of its cycle went into a failure code cleared it by flipping breaker. Now when I run bake/convection it runs broil at 600. Lower oven now run under temp.
Amazon.com: Frigidaire Gallery 27 In. Stainless Steel ...
www.amazon.com/Frigidaire-Gallery.../B002HMRIBI
Amazon.com, Inc.
Rating: 4 - ‎4 reviews
When your appliance is delivered it will be brought into your room of choice and all ...The Frigidaire FGET2765KF Gallery Series 27 In. Double Electric Wall Oven, ... Using the "Quick" Pre-heat function on this oven, the timer goes off ... Great, until you check the temperature and find that it's only reached 225 degrees.
Frigidaire FGET2745KF Gallery 27 Double Ele
Frigidaire Model FPDS3085KA getting error code F90 ...www.shopyourway.com > Manage My Life > QuestionsMy wife did start the self cleaning and cancelled it and we have not been able to ...Frigidaire Model FPDS3085KA getting error code F90 ... I have tried holding the lock button down for 3 seconds and that puts it into a mode where it looks like it ...Missing: fget2765kfFrigidaire Range Error Codes for Self-Cleaning Rangeswww.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-range-e...Find error codes for your Frigidaire self-cleaning range at Sears PartsDirect. ...should only occur when the oven is active or when you attempt to enter a mode.Missing: fget2765kfFrigidaire Self-Cleaning Wall Oven Error Codes ' Sears ...www.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-wall-ov...
Jan 03, 2016 | Frigidaire FGET2765KF
Why ist myoven preheating anymore?
Good Morning Jo Rown,
I understand that you are having trouble with your Frigidaire oven not preheating anymore. I will be more than happy to assist you. In order to do so, I will kindly ask you for some more information. I will need the exact model number of your oven as well as what happens when you turn your appliance on. I want to know if it heats up at all or if you're not getting any heat from your oven. Looking forward to hearing from you.
-Best Regards-
WP
May 06, 2014 | Frigidaire Gallery FGEW3065K 30" Single...
Frigidaire double convection wall ovens, model GLEB30T9DSA ... The top oven will not heat, both the bottom element and the broiler.....
I have the Frigidaire PLEB30S8CCA single wall oven. About 3 months ago the baking element appeared to have gone out. We replaced it, but still didn't work. We ended up sending our control board off to a company named Corecentric. They fixed the problem and returned it to us. The oven has worked perfectly ever since. I searched extensively for a new one, but no one sold them anymore. I found Corecentric on Ebay. They were able to confirm over the phone that it was more than likely a control board issue. It cost about $130. My husband was able to do it himself by taking a couple before px and using them when reassembling it.
Apr 04, 2014 | Frigidaire 30 in. Electric Gallery Series...
Gallery series Frigidaire gas oven not heating up correctly
Hello Hilda, thank you for your post!
There could be a number of
any one of several underlying causes in why the oven is experiencing this
particular issue:
·Convection
heating element
·Thermal cutout
·Thermal oven
sensor
·EOC
·Ignitor,
·Bake or broil
element
·All wired
connections
·Lastly the oven cavity and insulation should be checked to ensure there are no gaps or damages that will leak out the heat.
The parts above will need to be assessed for further evaluation by a technician since it is always a good idea to get the appropriate diagnosis prior to making any unnecessary part replacements.
Aug 29, 2013 | Frigidaire Gallery 30" Self-Cleaning...
Need owners operating instruction manual for fsc88w-5 in the wall ele. oven
Have you tried the Frigidaire web site. I did a quick search and they seem to have lots of information and user manuals available. Google is also a good place to search for manuals and other information for older appliances.
Dec 09, 2017 | Frigidaire Ovens
Slow to heat on convection mode, bottom element not get as hot as
Check to see that the convection element is heating. If not, ohm it out, either the element is bad or it is not getting power from the control.
Jun 25, 2010 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire Oven making vibration noise when Pre-Heating or Convection cooking. Only notice when convection fan is running.
This usually is caused by a bad convection fan motor. This is something that you should have a technician replace, but ask for a price quote first. Fairly expensive to fix and usually very complicated to get at. Good Luck, Appliance Specialists
Dec 11, 2009 | Frigidaire PLEB30S9DC Electric Single Oven
Frigidaire plef398ccc displayed 'er' now won't heat cooktop/oven
Nov 16, 2009 | Frigidaire PLEF398C Kitchen Range
Convection oven problem
Most of the time the magnetron is defective if the food is not heating up.
In some cases there is a defective low power transformer or other componenents associated with the magnetron.
I would suggest to check the owners manual under the warranty section. Sometimes the magnetron has 5 years warranty.
Good Luck.
Feb 15, 2008 | GE JVM1490 Convection/Microwave Oven
Open Questions:
Frigidaire FEF364DQ Electric Kitchen Range Logo
137 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
