Question about Kitchen Ranges
Tecnik Cooker Hood TCHY60 lights not working but fan working?
40w screw in bulbs. I've checked lights and the yellow and blue wires which run from light fitting to the switch board with a multimeter and no reading. Red and Black wires on switch board have a reading. Help?!
SolutionGuy
  • 331 Answers
SOURCE: fitting a new control switch for the fan oven (model number 10450G)
Sesspod, 2 things... 1.) Pull the oven out and look on the back of it, there may be an envelope back there containing a technical data sheet which includes a wiring diagram. If not on the back, then possibly under the cook top. It is somewhere on your oven, sometimes the hard part is locating it. If you can find it, look closely and you'll see the wiring color and location is labeled. 2.) If you can't locate the tech data sheet, can you post a good macro picture of the back of your new switch so we can see what you're dealing with.
Posted on Aug 11, 2007
  • 1314 Answers
SOURCE: F60 SS Cooker hood
short in light switch
Posted on Dec 30, 2007
  • 171 Answers
SOURCE: range hood light failure
Hi bentson,
I'm Harvey the Master Plumber.
Your problem is: Fan works but lights will not. switched bulbs and still lights not working.
You are dealing with a bad light switch. If you have the tools and the talent go for it.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
grandadfixer
  • 99 Answers
SOURCE: Both electric ovens do not work.
Have you set clock time?
Posted on Oct 11, 2008
  • 203 Answers
SOURCE: baumatic cooker hood lights not working
take the bulb out and bring it with you to store and see if you can find one the same . DIY stores have tons of types.Joe
Posted on Nov 22, 2008
Why will the lights no longer come on, on my ceiling fan, when the fan works fine & everything else is fine? What happened?
you get a slight shock suggests that you have a major wiring problem
at some point the installing electrician has used a ground wire as a neutral wire and there is live feed back that should not be occurring
Get in an accredited professional electrical inspector to run a full scan and test on the house wiring and then go from there
Jan 01, 2018 | Home
I need a replacement for a rhine pl-190B
A PL-190B ceiling fan module is is a Wattage Limiter rated at 190W maximum. It is about 1" square and has a red, blue and white factory wired into the fan's light circuit in most cases. The AC power to the lights is run through the module to "ensure" no one puts more than 190W (about 2 amps)of light bulbs through the circuit for "safety" reasons. So four 60w bulbs and some CFLs will trip the module. These wattage limiters are sometimes feeding the fan motor in addition to the lights, however the units I have seen just control the "blue wire" going to the lights. Some suggest simply cutting it out and splice the blue and red wires (or blue and blue) that are left in the fan after removing out the module. If the module has two whites, wirenut them together separately. Otherwise just insulate or cap the single white.
At that point your ceiling fan and lights are like all others made before 2005 and depend on the circuit breaker and you to only use four 40w bulbs max in the fan. As indicated, some low wattage CFLs will also trip the module. Some internet sources have the PL-190B available for around $15.
Dec 31, 2013 | Computers & Internet
I need a replacement part for a rhine pl-190B
Dec 31, 2013 | Hampton Bay 24002 Ceiling Fan
A bulb blew in my tecnik cooker hood and neither the lights of the fan will work? is there a fuse somewhere that I need to change?
In case you are still looking for an answer. The same happened to me.
I found a 3-amp fuse which I changed, and now it's ok.
I removed the chimney casing and located the electrical connection into the wall. You'll find a fuse unit within the switch which swings out.
Hope this helps.
Dec 08, 2010 | Rangemaster Kitchen Hood
The lights and the fan in our Tecnik electric range cooker hood have stopped working. I am not certain of the product number. It was bought 5 years ago and is stainless steeI. I suspect a blown fuse but...
Hello Jack728,
I never have found a fuse IN a cooker hood as long as I repair them.
My first impression would be a faulty connection to the grid, as both functions of the hood do not work.
I hope this helps, Kind regards, Dik
Feb 08, 2018 | Tecnik TKC1426 Electric Kitchen Range
Bulb blew on Whirlpool cooker hood and new ones fail.
well is there a switch you might want to check that out.
Jun 29, 2009 | Whirlpool GZ5730XR Kitchen Hood
Bulb has blown on one of the lights but the other light will not
Its definetly the control board again.
Its worth $110.00
Read other answers ive given to others about similar problem
gtp_jmp
Jan 22, 2009 | Kitchen Ranges
40w candleabra bulb blew now can't turn lights off with remote
There is a receiver in the fan that when the light blew might have damaged that part of the receiver. I think you can buy them,but you will have to get into the base of the fan(ceiling cover).
Jan 02, 2009 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Rangemaster cooker hood. model no.LEIHDC120SC/
hood should be connected to a fused spur outlet which you havent found. try removing the chimney and you may find it there. chimney only held by 2 screws at top usually.the fuse in the outlet sometimes goes when bulbs blow
May 31, 2007 | Rangemaster Broan 614804 BALLISTA 48IN...
Kitchen Ranges Logo
103 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
