Question about Ovens
Siemens HB75AB.50.B How to change bulb
I have a siemens electric oven. The bulb has blown and is encased in a glass cover. The intructions say to turn anti-clockwise to remove the cover, but it just won't budge. Ant ideas how I may free it?
The bulb cover is probably gummed up with solidified oven grease and therefore stuck.
The only thing you can try is to turn the power off and spray around the edge of the glass with oven cleaner and leave for a couple of hours in the hope that it will soften and allow you to unscrew it.
Be careful not to get the spray cleaner on to the heating elements.
Dec 17, 2010 | Ovens
I have a Siemens single electric oven. It has a self-cleaning facility,but I have lost the manual and I don't know how to use this. I turn 2 dials when cooking - one sets which oven type and the other...
COPY AND PASTE THIS AND IT WILL TAKE YOU THE SIEMENS DOCUMENT SITE FOR FREE DOWNLOADS
http://www.siemens-home.bsh-group.com/uk/customer-service/user-manuals
Dec 10, 2017 | Siemens H 4680 BP KAT Stainless Steel...
How to change bulb on newworld g90 vision cooker
To change the bulb is quite easy, the glass lens screws off, give it a good soak and clean whist popping out to buy a new bulb, otherwise you won't notice the difference. Note the bulb is a special oven bulb, if yoo can't read the old bulbs rating it's probabily a 25W 230/240V rated for 300deg C - try Wilko's around £2.50
Sep 18, 2010 | New World G90m Gas Double Oven
1) I have an HB13M.50B - where can I purchase the oven bulb and glass in the UK. 2) How do you clean the top of the oven pls
I have the same problem re oven bulb for this model. did you find a solution please?
Aug 03, 2010 | Siemens Ovens
Oven door will not close completely no tension.siemens 6 hob.
I told bosch which is the same as siemens that the door hinges are defective. I even told them how to fix the problem without changing the hinges .If you add three washers on each hinge this will bring the door in to close the same for the bosch ranges. ps ex tech:)
Feb 24, 2010 | Ovens
Manual for HB56m550B Siemens Double
http://www.espares.co.uk/part/cookers-and-hobs/siemens/hb56m550b/01/p/1092/161/0/657527/766592/instruction-manual.html
you can buy a manual from the above link, costs less than £10, sorry couldn't find a free download
Dec 05, 2009 | Siemens Ovens
Hello I am after the user manual for a Siemens HB86E560B microwave oven
The SIEMENS HB86E560B is discontinued. You can try one HERE
Jul 08, 2009 | Siemens Ovens
Siemens oven tripping RCD
We need wiring diagram for HB905 Siemens double oven, to start with it kept tripping, element ok. Now we have no heat coming from the main oven.
May 02, 2009 | Siemens Ovens
How do I change the light bulb in the oven
You can replace the light bulb(s) in your range/oven, though you may need to remove a glass covering or dome to reach it. Most interior oven lights use a universal 40 watt appliance bulb.
Apr 24, 2009 | Philips Ovens
Ovens Logo
43 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
