Question about Symbol MC9060
Clean boot MC 9060 CE 4.2 - Symbol MC9060
  • 24 Answers
Posted on May 05, 2016
3 Suggested Answers
SOURCE: MC 9060 not retaining programming
We have the same problem, and according to our supplier we had to use the Regsave for saving the settings, due to internal proceudres, we haven't use the devices for a year, but now we have to use them again....
We have found this solution in the net, perhaps will help you...., now we are trying to find out the RegSave utility, if you find it, PLEASE e-mail me at alrapmttas@maersk.com THKS
quote
Some brief notes about the use of RegSave on Symbol 90X0 terminals, specifically the 9060 with the 802.11b RF option.
You will need RegSave_2_53_04.zip
Unzip this and locate the file RegSaveCED.exe in the 9050 folder.
Connect your terminal as a guest in ActiveSync and explore it using Win Explorer. Locate the c:\applications folder and copy the RegSaveCED.exe file to this folder on the HHT.
Now you can uncouple the HHT and click start menu and Windows Explorer to look at HHT's local files. locate applications folder and locate the RegSaveCED.exe file... double tap
Now screen RegSave EMEA TS appears.
In Registry section press "Create Template File"
Accept \Application\RegSave.tpl option offered
Click Create template and wait forever !
............. time passes ..................
The app rattles through all the registry entries and builds a file with them all in. Just when you assume it'll last forever it stops...
Now back to the main screen ...
Click OK (top right) to exit the app
--- oOo ---
Now set your IP parameters and RF bits... in fact anything you need.
--- oOo ---
Now re-load the RegSave app.
Press the button in the Registry section entitled "Save Current Configuration"
I got some missing file error here which I rode over roughshod... basically it's looking for a registry exception file. You can create this but and it can be a list of ignored keys but for our purposes it doesn't matter so I just said "Yes"
It'll do some stuff regarding comparing and checking for differences, then it saves the changed bits.
Now you can exit RegSave and try rebooting... it should have saved the changes to the Registry and everything should be the same as before
unquote
Posted on Mar 03, 2009
SOURCE: Symbol MC 9060 - can't get the scanner working.
Send to manufacturer.
Posted on Jul 16, 2009
I am going to change the brake fluid in my 2000 GMC Sonoma 4 x 4.How many ounces, quarts, of brake fluid will I need?
I usually buy 2 quarts just to have plenty, but 1 quart should be enough. I use a turkey baster to suck up most of the old fluid from MC first, fill with clean fluid, then start with wheel furthest from MC (right rear) and drain until clean fluid with no bubbles appears, but drain a little at a time and refill MC to insure you never let air enter system. Next, do left rear, right front, then left front. Most folks recommend fluid as specified on MC cap. For older cars or classics that don't get used often, I will use DOT 5 silicon fluid that does not absorb moisture like regular brake fluid. The pros=less moisture means parts last longer without corrosion, higher heat boiling point for heavy use. The cons= you get a slightly softer brake pedal.
Aug 12, 2015 | GMC Cars & Trucks
Clutch master cylinder?
where is this boot,
if the MC boot leaks, hell any mc leak, front or back it bad
if the fluild drops, mc or slave are bad, or both
if the slave leaks, the slave is bad.
imagine a unicycle with disc brakes,
its that simple, 1 mc, 1slave
it must not leak.
it most not have air in the lines
it the mc seal must be good. on it piston.
on this old car, id have both replace in heart beat,
both are cheap and easy to replace. fast.
(i dont know its history so..)
Jan 28, 2014 | 1985 Jeep CJ7
E shows on left of screen with 0 on right hand side. I can't get it to respond to any prompt.
sounds as if your calculator has registered a number to large to display. this can be done in either the normal calculating mode, or in the memory calculating mode. i will help with both scenarios.
for normal calculating mode:
try pressing the CE button and holding for about a half a second. the E should disappear and calculating function should resume.
if that doesn't work, try disconnecting power supply for a few seconds, then reestablishing power and hit CE
for memory calculating mode(there will be a M on the screen as well if this is the problem)
press either the CE or MC/MCE button for a half second. this should return normal function.
if that doesn't work, try the power reset as described above.
Jan 15, 2014 | Canon MP18D II Basic Calculator
Symbol MC9090 I formatted the Symbol MC9090 installed the drive after I do a setup on the device everything works correctly, after rebooting the symbol mc 9090 its configuration is...
this is because you are cold booting the unit. Everytime you cold boot a 9090 it re-sets all saved settings. You need to warm boot only unless you want the unit reset to default. any problems please mail technical@codeo.co.uk for support - we supply MC9090's in refurbished condition complerte with like new warranty incase you need any
Oct 21, 2011 | Zebra Symbol Technologies MC909X-G Series...
Windows 7 drivers for brother mfc 9060
Try this:
http://www.techrepublic.com/software/brother-mfc-9060-5125350-windows/476293
Mar 02, 2011 | Brother International Brother MFC-9060
Hi im looking for info on how to flash or load windows ce on a neoware ca5 thin client, i have downloaded the Os but have no clue how to load it on the thin. can you please assist me
  1. Make a bootable USB drive using HP Drive Key Boot Utility (via bootdisk.com Method 2)
  2. Format the flash disk in the device.
  3. Make the flash disk in the device bootable using MBRTool (This is necessary if you installed GRUB on the disk. The MBR needs to be overwritten)
  4. From the Win CE installation folder, from drive:\<path to wince installation>\PLATFORM\CEPC\SRC\BOOTLOADER\DOS\BOOTDISKcopy all files and paste it to the flash disk in the device (These files always comes with Win CE installation)
  5. Put your build of Win CE - EBOOT.BIN in the flash disk on the device (This will be your custom Win CE image)
  6. Remove the USB drive, and boot the device. Your new build of Win CE should boot up.
Aug 26, 2010 | Computers & Internet
quote
--- oOo ---
--- oOo ---
unquote
Feb 27, 2009 | Symbol MC9060-G
Symbol MC9060 Logo
445 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
