Question about Whirlpool Calypso GVW9959K Top Load Washer
Help................ started a load, water filled up, waited for the next cycle to kick in, and all it did was whine...and then a click and a code of C-5 CAME UP UNPLUGED IT ,PLUGED IT IN AND THE SAME THING. 4 TIMES.. REPLACED THE MOTOR 6 MONTHS AGO. joe
  • tuey222 Oct 09, 2007
    the code was a CA NOT C 5
I am not a technician but with all the trouble I've had with my Calypso I wish I were. I too am having this same problem. It acted like it wanted nutate or spin but couldn't get going. When this would happen I opened the lid and spun the basket to "jump-start" it then closed the lid a hit the start button and it continued normally. Unfortunately during the final spin it came to a dead stop and now the basket will barely turn as if something is dragging it down. At this point my guess is it is faulty drive motor or brake assembly. And at this point I'm not sure if I really want to continue repairing this lemon.
Posted on Oct 21, 2007
Kenmore washing machine will not stop filling
There is a water level sensor in the tube and it might be plugged. IT could also be the load selector or the control module.
Feb 10, 2014 | Kenmore 22642 Top Load Washer
5 year old dishwasher.Press START button,dishwashing cycle kicks in for a few seconds then stops.A few seconds wait and it starts again, and on and on.It finally works its way to the full cycle.
The dishwasher is taking too long to fill with water...
Here is a tip that will help you to find out whywater will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
May 24, 2011 | Whirlpool Dishwashers
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
The machine stops after the wash cycle and won't finish.
The code is UE
load too small.
• Load is out of balance.
• The washer has an imbalance
detection and correction
system. If individual heavy
articles are loaded (bath
mat, bath robe, etc.) and the
imbalance is too great, the
washer will make several
attempts to restart the spin
cycle. If an imbalance is still
detected, the washer will stop
and the error code will be
displayed.
• Add 1 or 2 similar items to help balance the load.
• Rearrange items to help balance the load.
please rate this help to keep the service online
Aug 20, 2009 | LG Washing Machines
Maytag MAH20PD washer does not do the High Spin Cycle
with what you have described the problem should be in the door lock unit. there is a check switch that gets pressed down and sends a signal to the computer board telling it that it is locked. if the switch isn't working then that signal will not be sent and the washer will just turn and never enter spin. replace the switch and this will clear up the problem
Jan 03, 2009 | Maytag MAH20PD Front Load Washer
Whirpool Duet won't spin clothes at high speed
Thinking of 2 things either the transmission is out or the clutch is burnt out and the drum basket and possibly the drive shaft broken as well. Prices vary greatly by how many of these things are broken but should run between 100-200 including labor.
Dec 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer fills up; makes LOUD whine/click metal noise
sounds as if you have a bad mootor coupling, part number 285753, easy enough part to change, easier to search on the you tube site for whirlpool motor coupling repair, fo rthe video, then try to explain procedure, but definalty easy enough repair for home owner
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Won,t drain on rinse cycle
There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
Jan 13, 2008 | GE WNCD2050AWC Top Load Washer
Washer only fills
it sounds as if its your lid switch. on some top load whirlpool washer it will fill even if the lid is open. if you open the control panel and open the jones plug you can check for continuity on the lid switch
Jul 22, 2007 | Whirlpool LSR6334LQ Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
61 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
