Question about KitchenAid KERI203PBS Electric Kitchen Range
Need to change orpheus on ge stove - KitchenAid KERI203PBS Electric Kitchen Range
How to change Orpheus is my kenmore range
do you know what spell check means as that is not a word in the English language
Jul 25, 2015 | Kenmore Kitchen Ranges
GE gas stove ....control panel has no power to turn oven on but oven does have light....do i need to replace control panel
I try to clean it up a thin tool pen and then put the fan on it and then try Does it work
In the case did not solve the problem, change the panel
Oct 09, 2013 | GE Stove/Oven/RanSurface Burner Knob -...
Ge oven membrane panel
Order GE range/stove/oven parts today. We ship GE range/stove/oven parts on time or your order is free. Return any GE range/stove/oven part for any reason for one full year. Customer service for GE range/stove/oven parts is available 7 days a week. More than one million parts available. We stock the GE range/stove/oven parts you need for immediate shipment. We have more than 200,000 high-resolution part photos.
Jul 26, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Need to change or clean out Orpheus tube. replaced hoses and compressor every thing check out good but after running ac for a while the clutch fan wont stay ingadge was told it could be a clogged Orpheus...
If the compressor cycles (turns on and off) frequently, and the AC is just cool, then you are likely low on freon. Did you evacuate (pull a vacuum) the system before charging it with freon? This will also cause your problem. The orifice tube is located within a high pressure hose near the radiator or the firewall. Look for diameter size differences in the lines at connections.
Sep 03, 2011 | 2004 Ford Taurus
Need to go from natural gas to Liquid Propane. What is the wright way to do this.I have a GE Spectra stove. #JGBP35WEA3WW
You need to have the orifices changed on the stove to LP and the regulator on the oven converted, This should really be done by a professional, if it is not done correctly you can cause damage to your appliance and home. http://www.sensus.com/gas/pdf/Orifice_Change_Out_Procedure.pdf Hope this Helps Ryan
May 11, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Where can I get new Oil Pump
Hi Loukit18,
#1) You can purchase or order the oil pump you need from the manufacturer or any small engine repair shop.
#2) I recommend that you support your local small engine repair shop and get to know them personally.
#3) Make sure you clean your oil reserve tank and orpheus with lite oil. always wear safety glasses when working on this project.
Notes (*Most oil pumps are easy to install. If you need help with this proceedure, please ask your questions @ FIXYA.COM)
( Advanced Mechanic note: Clean the oil tank and oiling Orpheus with a mix of 50/50 gas and oil. Drain and air dry for 30 minutes before using)
Thank You for using FIXYA.COM
Floman
Feb 19, 2011 | Garden
Ge stove reading F7 on JBP80 or 90
you have a stuck key on the erc
try unplugging for 5 min
but more than likely you will need to change it
erc= electronic range control
Oct 05, 2009 | Kitchen Ranges
How do you convert the oven to lp gas on ge xl44 range
if this is a new stove need to change the pin in the regulator ,
then need to replace the stove top orifices from gas to l.p.
check under the stove for pieces they tape them under there by the regulator -- that how i found mine under my new jenn air
check the stove companies web site for a users manual also
Feb 19, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
GE range stove #317B6641P001
Hi thanks for the question. the problem you are having is with the igniter. it does not get hot enough to work at 100 % . replace the igniter. thanks te appliance doc
Sep 10, 2008 | GE Profile JGSP44 Dual Fuel (Electric and...
KitchenAid KERI203PBS Electric Kitchen Range Logo
35 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
