Question about Eastman Outdoors 38065 Turkey Fryer
How to assemble burner on east man model 90314
We have a new gas dryer that needs conversion to LP. Model is GFDR270GHWW. We are not able to access the area to change it over.
https://www.geapplianceparts.com/store/parts/spec/WE25X10032
Removing the burner to replace the parts will require some cabinet disassembly. GE doesn't publish a manual for consumers. A service man can do the conversion or you can use the diagrams here.
https://www.geapplianceparts.com/store/parts/assembly/GFDR270GH1WW
Apr 28, 2016 | GE Dryers
Igniter of left rear surface burner won't stop sparking
Sounds like a call to your gas company is in order.....it may be a part thats malfunctioning, part of the rotating knob assembly of that burner or the pieziolectric sparking mechanism is 'stuck' - gas man
will have a clue. watch out, gas is very user unfriendly!!
Jul 14, 2015 | Kitchen Ranges
Burner lights but then shuts off after about a minute
What's happening is a good indication that the pilot assembly and the burner assembly may need cleaning. Insects can really clog it up. If after thoroughly cleaning the pilot and burner assemblies the burner still shuts off,check the gas tank and make sure it's at east 2/3rds full. After reconnecting the hose to the tank, open the tank valve VERY, VERY SLOWLY (Slow motion, slow) until the valve is full open. Then attempt to light the pilot and the burner. If every things works as it should, you solved the problem.
If you find you need to order a thermocouple, I have provided a link to the Blue Rhino Company, the manufacturer of Uniflame Patio Heaters and you can order it thru them.
http://www.uniflame.com/BRWEB/getdoc/3dbb047b-509e-4627-98cd-c4cdb36d82a9/Parts-and-Accessories.aspx
I hope this helped you troubleshoot & solve the problem. Thanks for choosing FixYa.
Aug 15, 2011 | Uniflame 200209 Open Flame Patio Heater
I need a replacement hose for an Eastman Outdoors turkey fryer -model 90314. I am in Saskatchewan,Canada.Where do I find parts?
I assume you need the hose/regulator assembly. If so, you can purchase one from any home center or hardware store that sells gas grills and accessories. Just take your old one with you for comparison purposes.
Apr 03, 2011 | Eastman Outdoors 37045 Turkey Fryer
Is the pilot light manual or automatic light
MOST modern appliances that use gas ignition (including kitchen ranges) no longer have a pilot light. These appliances are now equipped with a burner assembly with electronic igniters. The following link explains a little theory about how these igniters work:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
I know the link is for a gas range, but the burner assembly functions are nearly identical, as well as, the type igniters used. If you are having ignition problems it may be a simple matter of a weak or bad igniter. If you ar referring to whether or not the burner ignites automatically, or if you have to manually light it, the burner assembly will ignite automatically as long as the gas valve, igniter coils and igniter are all functioning properly. It can take up to 90 seconds for the burner to ignite. As the igniter ages, you may experience longer ignition times.
If the model number is correct, you can view an illustration of your burner assembly at appliancepartspros.com. The components I've mentioned are as follows: Item 4 - Igniter assembly Item 13 & 14 - Igniter coils (BOTH should be replaced at the same time if found to be defective). Item 10 - Gas valve assembly. If you have any questions, please let me know. Include your complete model number if it is different from the one you posted this question under. I hope this information is helpful to you.
Mar 18, 2010 | KitchenAid KGYS850LT Gas Dryer
I have a 4000 btu model that is about 3 years old. It will start but shuts down after a few minutes. There appears to be plent of fuel in the tank.
You don't provide the make and model number of the unit, but, I would remove, dis-assemble, and clean, clean, clean the pilot burner and main burner assemblies.
The symptoms you describe are typical of dirt buildup and bugs/spiders getting into the pilot and burner assemblies.
Dec 17, 2009 | Cars & Trucks
I have a Jenn-Air model #720-0061-LT gas grill. All three burners cracked and I have received replacements but can not get their Tech. Support people on the phone to get installation instructions. Greg
How did you get your replacement burners, they are covered under the lifetime warranty.
They are east to replace, simply lift out of guide hole in back of grill slide off of the gas source. Then slide new burner on gas source and position back into guide hole.
Jun 11, 2009 | Jenn-Air Grilling
Magic chef rv oven burners work fine oven pilot hard to get lit and when it does lite the oven burner will not lite can you help me
thromo stat bad the tempature knob has a gas valve attached to it along with two gas lines you will have to remove the oven to acess all lines as they run on the backside of the case remove the burners and gas input line copper line remove gas supply tube to all burners remove valve and take to dealer they need the numbers off the vavle for exact repacement not just the numbers off the stove itself east fix with simpl hand tools thermost has a themocouple attached to burner assembly and this is your problem bad part is themocouple is built into thermostat and is no serviceable only fix is to replace "thermostic gas valve"
Apr 08, 2009 | Magic Chef 30 in. 8241RT Gas Cooktop
Solution for the problems of middle east
I have DACOR 5 burner gas range. The ignition system is continuously clicking. It clicks on all burners, even while the gas knobs are off. It clicks also while burner is on.
What could be the problem. Could it be one of ignition switches or spark module.
John
Jun 29, 2008 | Kitchen Ranges
Eastman Outdoors 38065 Turkey Fryer Logo
Top Eastman Outdoors Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you an Eastman Outdoors Grilling Expert? Answer questions, earn points and help others
