Question about Fossil CH2692 Watch
Battery model Wanted to know the battery no/ model for replacement of my watch battery
FR60 garmin watch error message
No solution. I just tried to change my battery yesterday and am receiving the same message. If I get a resolution I'll post it. Just wanted to let you know you're NOT alone!
May 06, 2012 | Garmin FR60 Wrist Watch for Men
No problem, just wanted to say i've had the watch for 8 years and have never changed the battery. just wondering how it last so long?
probably it is a solar, kinetic or automatic that is why you had been never replaced your watch battery.
Sep 06, 2011 | Watches
How many batteries does the monte carlo have. the analog side of my watch stopped working.. but the digital side works fine. is it a battery problem?
Hi, don't know the solution for this problem, but i just wanted to say i have the same problem here. And it't the exact same watch. Have you been able to solve it yet?
Sep 21, 2010 | Vestal Monte Carlo MMC001 wristwatch
I wanted to replace battery in my wife's Relic watch and a little metal part dropped on the table. I don't know where should it be put back. Do you have a manual for watch ZR33471. I would like to fix...
Thank you for contacting FixYa.
First of all, the manual would not help you with the battery. They usually dont have this info in manual. Your best bet is to take your watch to a local jeweler who does watch batteries. I imagine its just the battery strap but they can help you. You may get lucky and they dont charge you if you have the battery.
Best regards. Jewel
Sep 21, 2010 | Relic Calendar Date with Round Silver Dial...
I need a replacement battery for an original navy seal model (3000)? Does anyone know what type and size is in these watches? Other than sending it to luminox has anyone successfully found a replacement?...
If anyone opted out to replace battery2_bing.gif in their own watch and do not know what type and size of battery is correct for replacement, just open your watch case back and reed and memorize all the writings on battery your watch allready has in it. All you can do now is to buy exactly the same replacement battery and you will never get it wrong. All that matters is the combination of letters and numbers on battery. Make is not important, so, it can be made by Casio, Maxell, Citizen, Ronda - you name it. Just make sure you are not buying some of those cheap, unknown maker batteries2_bing.gif, as they usualy lasts for about few weeks and then they are gone. Choose well known makers name and the battery will power your watch for 2-7 years, depending on each particular watch movement model. In case if you lost your original watch battery, check your watch instruction manual. If you lost both - battery and manual - then there is no other way, but to visit your nearest watch repair shop and ask for help. In your particular case I do not see the reason why you should find the battery, because any decent watchmaker has many different batteries in stock. All you have to do is to find your closest watch repair shop and ask watchmaker to replace the battery. No need at all to send it to Luminox, as this job can be done at any watch workshop with the same precision and quality. In addition you will save money for shipping and pay less for battery itself.
Rate me, plz.
Jan 29, 2010 | Navy Seal Luminox Dive Watch
How do you know when the battery is low or flat
My watch has a similar issue recently. The light stopped working and I thought the watch was faulty but it was the battery was too low. Changed the battery and it started working again like a charm. Hope this helps!
Feb 01, 2009 | Tissot T-Touch T33159851 Wrist Watch
Directions for setting correct time with Smash Watch 05-0407
You need to reset your watch completely and to do that, you have to start from battery.
Extract watch battery completely and leave your watch without energy supply for an hour. This will erase any data kept in watch memory.
Then put the battery back in watch exactly the way it was and reset your watch using pushbuttons.
Don't forget to rate, please.
Jan 14, 2009 | Bulova Watch
Needs battery replacement
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Here's my suggestion. Take it to the jewelry dept at Walmart. Do you have one where you live.
They'll replace for free - Battery $8
Watch how they do it with their tools and you'll know how to do it yourself in the future.
Good luck
Dec 12, 2008 | Oakley GMT OAK0531 Wrist Watch
Fossil CH2692 Watch Logo
27 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Lyle Siemens
Lyle Siemens
Are you a Fossil Watch Expert? Answer questions, earn points and help others
