Question about Refrigerators
How to replace pc board on whirlpool wrf40 refrigerator
3 Suggested Answers
SOURCE: I have a whirlpool WRF40 IX all refrigerator. The ...
Seems to be a problem with this fridge. Mine did the same for a couple of weeks (and I have a friend who also has one and it is doing the same) and now only runs on 1 light - useless. Have been told that the "PC" board needs replacing. No stock of the part. Never want to buy Whirlpool again!
Posted on Oct 06, 2010
  • 16 Answers
SOURCE: WRF40:
sounds like the thermostat is not working properly because once the refrigeration side of it is either on or off. So I'd say the thermostat is turning it off to early. try bridging out the thermostat and then you'll know. Make sure you unplug it first.
hope this helps
koolman777 (refrigeration technician)
Posted on Feb 07, 2011
How do I remove front cover on Whirlpool WRF40 IX fridge. I need to access the PC board
Need full model # for proper dissemble bottom cover should just snap off
Dec 24, 2016 | Whirlpool Refrigerators
My whirlpool refrigerator model # GI0FSAXVY011 is not working.
I found out the answer. I replaced the control board. I installed a new one. Now my refrigerator is working.
Jan 12, 2016 | Whirlpool Refrigerators
Replace pc board of fridge
Can you locate the model number for your refrigerator? I have no idea what model your refrigerator is without the model number. e06d966b-e453-467b-946f-bc02641bcb47.jpg
Every refrigerator is different, Thanks, John Tripp Appliance 911
Feb 01, 2014 | Whirlpool Refrigerators
WRF40: It will only work on the lowest temp setting. The PC board has been replaced before
hope this helps
Feb 07, 2011 | Whirlpool Refrigerators
I have a whirlpool WRF40 ix all refrigerator. The problem is that the compressor trips at the high cooling settings (4 and 5) starts again and then trips immediately again. It only runs at 3 or lower....
WHIRLPOOL WRF40 Solution to this problem!!! very easy ----I assume you have a problem with the control board switching on and of erratic when you pass setting 3 on the LED display, the designers of this fridge left the calculator at home that day, ask a technician to replace the Resistors 5, 6 & 7 (330 OHM 1/4 watt) on your electronic control board with 680 OHM 1/4 watt. This would solve the problems with this board, the LEDs will not be as bright as they were but still highly visible. Questions? deon@electro-web.co.za
May 20, 2010 | Refrigerators
My gold whirlpool refrigerator does not make ice
The most likely cause is the water solenoid behind the fridge. Take an ohm meter and test across the two terminals and it should NOT ohm out (beep). If it does not ohm out I would replace the P.C. Board kit, emitter & receiver icemaker control.
Dec 03, 2008 | Whirlpool GD2SHGX Refrigerator
Whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Mar 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
WHIRLPOOL CONTROL PANEL
Hi. Your temperature control board display is bad. You may also have a power convertor board located next to the compressor. Normally you would replace the temperature control board first. I have a temperature control board listed on Ebay as item number 250211412492. Good luck, Mack
Dec 31, 2007 | Whirlpool GS6SHEXNL Side by Side...
Refrigerators Logo
156 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
