Question about ECHO, Inc. 20 In. Double Sided Hedge Clipper
Echo hc 150 won't stay running
Runs for about 3 min and cut off
3 Suggested Answers
dmiesner
SOURCE: ECHO HC-1500 hedge trimmer wont stay running cuts off
Replace the fuel cap.
Posted on May 29, 2010
philwalker78
  • 608 Answers
SOURCE: I have a echo HC-150 it won't stay on boggs down
Hi, either the carby is flooding and requires a carby kit or the spark arrestor or outlet in the muffler is blocked. Hope this helps, regards Phil.
Posted on Jul 18, 2011
Replacement of starter cord on HC-150 hedger
You may have wrapped it the wrong way. If not, your spring is either broken, the bend on the end which slides into the plastic has straightened, or the plastic spool has broken where it holds the other bent end of the spring.
Nov 07, 2013 | Echo HC-150 COMMERCIAL SERIES HEDGE...
1989 ford f-150 start but stalls out
Injector require 40 PSI on a Ford. Your Fuel Pump is BAD
Apr 08, 2013 | 1989 Ford F 150
Echo HC-150 rebuilt the carb, and now the primer bulb sticks and engine won't start
Try to pressure test the carb to see if you have an internal leak. If it won't hold pressure then it is junk and needs to be replaced. If it holds then double check that you didn't accidently put the gaskets and diaphragm in wrong. If it holds and still doesn't work right replace the carb anyway. They are relatively inexpensive
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Jan 20, 2013 | Echo HC-150, Hedge Trimmer 20"
Echo Chainsaw keeps cutting off
does it start and run for a min or two then die try and remove the muffler and run it if ok open the muffler and clean the screen off
May 25, 2012 | Echo Garden
Chainsaw won't stay running
You must have dirt in one or more of the carb jets. Remove the carb and clean it with carb cleaner spray and compressed air (compressed air is a must).
May 10, 2012 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Hello, I have a Echo PE-200 that won't stay
You definitely have carb. problems. The fuel probably varnisized. In this case, you may have to place the carburetor in carb. dip for a few hours.
Try my Tip out:
www.fixya.com/support/r6081405-cleaning_small_engie_carburetor
Aug 05, 2011 | Echo Garden
Jul 18, 2011 | Echo Garden
ECHO, Inc. 20 In. Double Sided Hedge Clipper Logo
100 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
