Question about Canon PowerShot SD790 IS Digital Camera
Need to reset to factory settings on a Canon powershot 790is
Lcd screen is dark
t00nz
  • 4738 Answers
SOURCE: Dark fuzzy/flickering screen - Cannon PowerShot A75
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Jan 26, 2009
kram26
  • 544 Answers
SOURCE: how to repair lcd screen canon powershot sx110-is
hi,
For that camera that died, here are some non-intrusive simple fixes that you should try before throwing in the towel. Copied this first post from somewhere. It was a fix for a Canon A520, but am not sure if it would work for other cameras with the same problem? For those of you with a camera that will not power up or turn on, especially if this occurred after a power interruption with your lens extended, please give it a try. If you do, please leave a comment on specifics like your camera make/model, and whether it worked for you or not.
"DEAD CAMERA, LENS OPEN-If the batteries run down completely while the camera is still open, it may not start up again when new batteries are installed. But if you remove the memory card, then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time."
OK, so the above didn't work. Next thing to look at are the batteries themselves. Are you using alkaline batteries, or worse yet those "Super Heavy Duty" batteries? If so, betcha we've just discovered your problem. Alkaline and regular "super heavy duty" batteries just don't have the power for more than a few pics in a digital camera. Some may even have problems just powering startup of the camera. It doesn't matter if they're new, and right out of the package. Digital cameras for the most part should only be used with rechargeable NiMH batteries (if you still have your instruction manual, open it to the "batteries" section. Pretty sure you'll see a statement similar to what I've just said). Most retailers sell NiMH batteries for around $7 for a package of four (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
OK, so maybe those newfangled batteries didn't fix your camera, don't give up just yet. The next thing to check is that your batteries are actually making contact with the battery posts, and that these posts are clean. If not, bend the posts up/down a little, and maybe clean them with a little rubbing alcohol on a Q-tip.
The next thing to try is examine both the battery and flash card door. There's usually a little switch on both doors (note some SD card doors do not have this switch) that activates when the doors are closed. If they don't, the camera won't start to prevent damage to the flash card or camera startup sequence. For most cameras its usually a little piece of plastic on the door that pushes in on a pin switch when the door is closed. Closely examine both doors to try to identify these switches. A lot of times that little plastic nib wears down or breaks off, but can easily be jury rigged with a small glued-on replacement.
If you've tried all of the above and still no luck, the problem is then likely to be internal to the camera. Am planning on posting sometime in the future some likely things to check, hopefully with a pictoral guide. One example would be that if your camera uses Compact Flash, check to make sure all pins are present and aligned in the card slot (if bent, simply unbend/straighten them with a skinny "jewelers" screwdriver, then insert the flash card for final realignment).
As before, if one of these simple fixes worked in your particular case, please leave a comment on your camera's make, and which fix worked.
Good Luck!
Camera Repair please don't forget to rate our answers..
Posted on Feb 19, 2009
  • 47 Answers
http://digitalcamerarepair.googlepages.com
Posted on Mar 04, 2009
zohail
  • 1223 Answers
SOURCE: Overexposure problem with a Canon Powershot A620
CCD FAILURE !
Just Call CANON for FREE REPAIRS they will do it , bcoz it is a known manufac fault just ask them about BAD CCD
pls rate me WELL !
Posted on Jul 07, 2009
  • 6 Answers
SOURCE: canon powershot a590 IS lcd screen
I had this same problem. Once I got over about 1200 pictures, the screen just turned black, and the only setting that would work where I could see the lcd screen was the easy setting. I had read somewhere that this was due to the amount of pictures the camera had "counted", even if those pictures had been downloaded and erased from the camera. So I decided to reset the camera. Go to the tools list in the menu, scroll down to "reset all", and when it prompts if you want to "reset settings to default" click ok. This worked for me, and all of my settings - sunset, landscape, etc. - parameters in any of the settings (shutter speed, lighting, etc.) those will have to be reset.
Posted on Nov 22, 2009
Shutter darkens on Canon S5 IS
U have a sick puppy on your hands. Hopefully, the camera is still under warranty. If not, it may not be cost effective to repair and replacement might be in order.
Jul 31, 2015 | Canon PowerShot S5 IS Digital Camera
LCD not working
If you need them, you can get all the related user manuals/guides from this link; http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=320&modelid=14109 There are a few possible causes for your problem; Faulty LCD screen - check if you can review pictures on it, even if you can't take pictures using the screen. Bad connection - you can try moving the screen into different positions to see if it comes on at any of them - where the connector goes through the hinge is a possible problem site - more likely the connector has come loose at one end or the other. Software problem - Connect the camera to a PC/Mac, and open the "Zoom Browser EX/Image Browser" program. Find the "Set my Camera" window and you should have "reset to factory settings option" (check the software starter guide page 42) You can reset all the camera settings to their factory default value - this has to be worth trying. I would use the warranty - Canon warranty service is usually pretty good - post back with your general area and we can hopefully find you a service centre. Hope this helps :)
Jul 07, 2007 | Canon PowerShot A640 Digital Camera
Lcd screen doesnt work
check lcd connection & clean.if ok flash software.
May 30, 2012 | Canon PowerShot SX20 IS Digital Camera
Lately it has been taking very dark pictures, even though the flash goes off, the pictures are still dark.
Did you change the exposure compensation setting or the ISO setting? You could go into the menu and find "reset"...follow the on-screen instructions to return to factory default settings.
Dec 11, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon powershot a590 IS lcd screen
Nov 05, 2009 | Canon PowerShot A590 IS Digital Camera
I have an old Canon powershot ELPH s410. i am
Here is the user guide: http://gdlp01.c-wss.com/gds/0900001340/PSS500IXUS500CUG-EN.pdf
Jul 01, 2009 | Canon PowerShot S1 IS Digital Camera
Jan 25, 2009 | Canon PowerShot A75 Digital Camera
The camara won't show a picture on the lcd screen
Your lens is Damage. Prevent nextime from sunlight , it damage your lens if not in use.
Dec 24, 2007 | Canon PowerShot A75 Digital Camera
In AUTO mode, pictures are all dark!
Yes you definitely can,
Turn on the camera.
The mode dial can be turned to any setting.
2. Press the button for longer than 5
seconds.
The message “Reset settings to default?” appears on the
LCD monitor.
3. Select [OK] using the left and right
buttons, then press the button.
The normal screen resumes when resetting is complete.
To cancel resetting, select [Cancel] instead of [OK].
Dec 09, 2007 | Canon PowerShot A70 Digital Camera
Canon PowerShot SD790 IS Digital Camera Logo
27 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
