Question about Philips Magnavox DVD Player MWD200F
Konka br/dvd player kbd301ad i need unlock region code
Getting wrong region error when tried to play dvd
devocap
  • 201 Answers
SOURCE: UNLOCK REGION CODE FOR PHILIPS DVDR3475/37 Recorder
Your device is designed for playing back region 1. It will also playback disks recorded with a region setting of all. The region setting of the device is fixed. Also it will only playback NTSC, and not PAL . This is also fixed on your unit. Sorry I could not bring you better news. However there are many burning and conversion programs you can use on your computer (ie Nero Vision, ConvertXtoDvd,..) which provide you the optional settings you are looking for, and allow you to burn in the setting you choose, allowing for playback on your Philips device. Good Luck!
Posted on Feb 07, 2008
jaffa012001
  • 376 Answers
SOURCE: philips dvdr 3320 v DVD Player Unlock region codes
In DVD mode, press System Menu
Go down to the "Lock " icon
While lock is highlighed press zero "0" for 7 times ( i.e 0,0,0,0,0,0,0)
There will be pop-up window that asks you confirm. Press "OK"
Posted on Aug 12, 2008
jaffa012001
  • 376 Answers
SOURCE: tryed the code to unlock region
1. Turn on the unit
2. Open the loading tray
3. Press the "Setup" button on the remote
4. Navigate to the "Preferences" page using the right arrow key
5. Enter 138931
6. You will now see the current region code displayed
7. Use the Up/Down arrow keys to select the region required or "0" for all regions
8. Press the "Play" button on the remote
DVP 5106k
1 - Make sure there is no disk in the player
2 - Press EJECT on the remote or on the player. The eject icon has to be visible on screen for the hack to work!!!
3 - Press MENU (System) on the remote
4 - Press the RIGHT button on the remote until you get to the PREFERENCES screen
5 - Now enter the sequence 135566 with the remote control
6 - Now "Region Code" should appear
7 - Select the 0 (multiregion)
8 - Press MENU (System) on the remote to exit the setup screen
9 - Press the power button on the remote to set the player on standby, this saves the new setting.
  • 35 Answers
SOURCE: Want to unlock Philips DVD player (DVP320)
Did you follow these instructions exactly? If you pressed 9990, as you mentioned, it will not work. You need to press 99990. Do you see region "0" on the display?
start the player without any DVD in it.
open the lid.
while the lid is open press 9,9,9,9,0
you should see region 0 displayed.
close the lid.
Your DVD player is now region free.
note:
replace 0 with 1 to 6 at to set the wanted region number if needed.
Posted on Mar 05, 2009
SOURCE: Philips Portable DVD Player PET 730/98 Unlock Code Needed!
Philips PET730/05
Using remote control
Setup
Down arrow
Down arrow
Right arrow
212225 (you won't see anything!)
Left arrow
Down arrow
should now show region code box
Enter 0
Setup to save
Posted on Apr 09, 2009
How to unlock regional code of philips HTB3510 3d blueray player?
Check current region code
Open the Philips HOME Screen
Type on your remote: 8520
This will display all of the current settings for your player.
Example: Region_Code: DVD(2) BD(B)Change region code
Turn on player with no disk inserted
Press "Open/Close" on the remote control until the tray is open
Press 8689310 - 0 means all region
Press 8689311 - 1 means region 1,
Press 8689312 - 2 means region 2,
Press 8689313 - 3 means region 3,
Press 8689314 - 4 means region 4,
Press 8689315 - 5 means region 5,
Press 8689316 - 6 means region 6.
Now the front Buttons might not work!
Go to SETUP and click on RESET FACTORY SETTINGS
Wait until the player restarts and now you can play all DVD regions
Oct 08, 2014 | Philips HTB3510 5.1 3D Home Theater System...
Alpine PKG-RSE2 Car DVD Player.
It is difficult to get unlock code for Alpine PKG-RSE2 Car DVD Player
To get the code you can contact them.
Main support number 800-421-2284
Goodluck..
Apr 08, 2008 | Alpine PKG-RSE2 Car DVD Player
I have a Philips HTS 3371 DVD home theatre and can not play many DVD's as it give wrong region error. Can you please provide the unlock code and how/where to enter it to get it fixed?
Hi -
Please follow the instructions below for unlocking your Philips HTS 3371
Please note: Unlocking a DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
1. Switch the DVD player ON
2. OPEN the disc tray
3. Key 9 9 9 9 0 using the Philips remote control supplied with the player
4. Press PLAY. The disc tray will close.
5. Switch the player OFF then switch ON again.
6. To test, play a disc from a region which was previously locked.
If it does not work the first time, switch the player off and back on, then try again.
This is a verified unlock method, but I was unable to confirm whether it works for players sold locked to Region 1 (North America). If you have a Region 1 player and the method above does not work, you will not be able to unlock your player.
Regards,
BElectric
Mar 26, 2011 | Philips HTS3371D Theater System
Bought a new dvd it will not play, its giving me a regions code error. what is the code, and how do i put it in the dvd player?
A regions code error means that the player is not compatible to play a DVD from a different region than what it was designed to play. For example, if you purchased your player in the U.S. or Canada then it is a region 1 player and therefore will play DVD's from region 1.
Here is a region map http://www.mvps.org/marksxp/WindowsXP/dvd/regions/regions.php
There are however, ways around this as some manufacturers of players have made a way to be able to allow the end user to unlock the software codecs that are for different regions. You will have to search for an online source that has a download or a procedure to follow to unlock your player.
Nov 01, 2010 | Emerson EWR20V4 DVD Recorder/VCR
DVD player is saying "Wrong region"
region codes are as follow. Region 1 North America, Region 4 South America, Australia, Region 2 Europe, Region 5 Asia Major,Africa,Region 6 Asia Minor, Probably your DVD is from another region....hope this helps
Jan 01, 2010 | Insignia Televison & Video
DVD movies form Amazon show in India ''wrong region''.
try to unlock your dvd player to play all free region. what you need is the code to unlock and a remote control to enter the into menu/programming mode. please specify model # of your dvd player when you look for the unlock key.
Apr 03, 2009 | Philips Televison & Video
Won't play DVDs from asia .. need region code unlock.. help.
try with the disc tray closed. and if that doesn't work turn player off by plug socket and turn back on and start from the setup menu part of the unlock code after turning player back on.
Aug 22, 2008 | Jwin JD-VD135 DVD Player
PANASONIC DVD RECORDER DMR-ES35V
DVDs are region coded. This means that they will only play on a DVD player from the region the DVD was produced to be watched in. For example, an Australian DVD is Region 4. It will only play on a Region 4 player. If you try to play it on a player that is set for a different region, it will probably not play. One way around this is to get hold of a multi region player. These are widely available. Alternatively, you should be able to watch the DVD on your computer, although you may need some region free software if your computer's dvd player has been locked. Usually computer DVD players will allow you to play DVDs from any region a few times and then they will lock to a particular Region Code. If you are in North America, you will need a PAL player. The only other thing you may be able to do is to unlock your existing player to convert it to region free. Many DVD players can be unlocked but you would need to find the unlock information for your paticular player. Hope this helps....
Jul 27, 2008 | Panasonic DMR-E55 DVD Recorder
Yamaha DVD S1700 player multi-region unlock code
see if this works
  1. Power on
  2. Press PLAY
  3. Enter 2, 7, 4
  4. Enter 222 222 005 255
  5. Press PLAY
  6. Power off
Nov 18, 2007 | Televison & Video
Philips Magnavox DVD Player MWD200F Logo
102 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
