Question about Olympus DS-4000 Digital Voice Recorder
Dictation module stopped opening - Olympus DS-4000 Digital Voice Recorder
Have you found your answer yet? In my case, it was the upgrade to latest version ie. Was using 9. ie 11 stole bits of code.
Posted on Jan 22, 2015
I need the wiring diagram for the 2006 chevy avalanche ignition
http://www.bbbind.com/free_tsb.html free wiring diagrams . Ignition switch or ignition system - coils , plugs , wires etc... .
Everything on your vehicle is electronically controlled by the BCM - body control module .
On vehicles that have several control modules connected by serial data circuits, one module is the power mode master (PMM). On this vehicle the PMM is the body control module (BCM). The BCM uses 3 signals from the ignition switch. These are the Ignition 0, Ignition 1, and Accessory.
Discrete Ignition Signals
Those modules that have discrete ignition signal inputs also remain in the state dictated by the last valid BCM message received on the serial data circuits. They then check the state of their discrete ignition input to determine the current valid state. If the discrete ignition input is active, B+, the modules will fail-safe to the RUN power mode. If the discrete ignition input is not active, open or 0 voltage, the modules will fail-safe to OFF-AWAKE. In this state the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle.
Your best bet , take it to a qualified repair shop !
May 10, 2017 | Cars & Trucks
How do you replace the ignition switch on a 2002 buick century?
What do you mean no sound when turning key ? Does the car start an run ? Or the car doesn't crank ? Ignition switch's do not work the same way they did in the old days , especially on GM vehicles . The ignition switch is an input to the BCM - body control module , the BCM processes these inputs an then energizes relays to turn things on . Also sends messages to other modules for them to turn on or energize relays .
The power mode signal may be as simple as a B+ input wired to a particular ignition switch contact. If this is also the B+ supply to the module/device, the module/device will only operate with the ignition contact closed to B+. An example of this is the starter relay when it is wired directly to the CRANK/START contact of the ignition switch. When the CRANK/START contacts are closed, the starter relay is energized and provides a current source to the starter and starter solenoid. When the ignition switch leaves the CRANK/START position, the switch contacts open and the starter relay is de-energized. This removes the current source from the starter and solenoid and the starter operation stops.
Serial Data Power Mode
On vehicles that have several control modules connected by serial data circuits, one module is the power mode master (PMM). On this vehicle the PMM is the Body Control Module (BCM). The BCM receives 4 signals/circuits from the ignition switch. These are the Ignition 0, Ignition 1, Crank and Accessory 1 ignition switch signals/circuits.
To determine the correct power mode the BCM uses:
The state of these signals/circuits, either switch closed (B+ = 1) or switch open (open = 0)
The sequence of switch closures received by the BCM
The status of the engine run flag.
Important: Any ignition switch states not covered in this table indicates a DTC setting situation.
The chart indicates the modes detected and transmitted by the BCM:
Power Mode Selected/Expected
Engine Run Flag Serial Data
Sampled Ignition Signal State
Power Mode State
Accessory
Ignition 0
Ignition 1
Crank
OFF-LOCK
0
0
0
0
0
OFF
Accessory
0
0
0
ACCESSORY
RAP
0
1 to 0
0
0
0
RAP
OFF-UNLOCK
0
0
0
UNLOCK
RAP
0
1 to 0
0
RAP-UNLOCK
Run
0
RUN
Crank
0
0
CRANK
Crank
CRANK
Run
RUN
Fail-safe Operation
Since the operation of the vehicle systems depends on the power mode, there is a fail-safe plan in place should the BCM fail to send a power mode message. The fail-safe plan covers modules with discrete ignition signal inputs as well as those modules using exclusively serial data control of power mode.
Serial Data Messages The modules that depend exclusively on serial data messages for power modes stay in the state dictated by the last valid BCM message until they can check for the engine run flag status on the serial data circuits. If the BCM fails, the modules monitor the serial data circuit for the engine run flag serial data. If the engine run flag serial data is True, indicating that the engine is running, the modules fail-safe to "RUN". In this state the modules and their subsystems can support all operator requirements. If the engine run flag serial data is False, indicating that the engine is not running, the modules fail-safe to "OFF-AWAKE". In this state the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle.
Discrete Ignition Signals Those modules that have discrete ignition signal inputs also remain in the state dictated by the last valid BCM message received on the serial data circuits. They then check the state of their discrete ignition input to determine the current valid state. If the discrete ignition input is active, B+, the modules will fail-safe to the "RUN" power mode. If the discrete ignition input is not active, open or 0 voltage, the modules will fail-safe to "OFF-AWAKE". In this state the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle.
You probably won't understand any of this info. your best but would be to take it to a qualified repair shop that has proper diagnostic test equipment !
Sep 29, 2016 | Buick Cars & Trucks
Ignition switch for 2003 malibu ls
Ignition switch ? Key an lock cylinder or the electrical part ? The vehicle keeps running or you can't turn key to off ! Different thing's come into play depending on which is your problem ! If vehicle doesn't shut off (keeps running ) You need to know how it works !
An ignition switch isn't the same as back in the old days , it's a low voltage input to the BCM .
On vehicles that have several control modules connected by serial data circuits, one module is the Power Mode Master, PMM. On this vehicle the PMM is the BCM. The PMM receives 3 discreet ignition switch signals to differentiate which power mode will be sent over the Class 2 Serial Data circuit.
To determine the correct power mode the PMM uses the following circuits:
Ignition 0
Ignition 1 voltage
Ignition 3 voltage
An you need a professional scan tool to deal with these problems !
Serial Data Messages The modules that depend exclusively on serial data messages for power modes stay in the state dictated by the last valid PMM message until they can check for the engine run flag status on the serial data circuits. If the PMM fails, the modules monitor the serial data circuit for the engine run flag serial data. If the engine run flag serial data is True, indicating that the engine is running, the modules fail-safe to RUN. In this state the modules and their subsystems can support all operator requirements. If the engine run flag serial data is False, indicating that the engine is not running, the modules fail-safe to OFF-AWAKE. In this state the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle.
Discrete Ignition Signals Those modules that have discrete ignition signal inputs also remain in the state dictated by the last valid PMM message received on the serial data circuits. They then check the state of their discrete ignition input to determine the current valid state. If the discrete ignition input is active, battery positive voltage, the modules will fail-safe to the RUN power mode. If the discrete ignition input is not active, open or 0 voltage, the modules will fail-safe to OFF-AWAKE. In this state the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle.
Aug 31, 2016 | 2003 Chevrolet Malibu
Pro-digital voice recorder sound
For all information about dictation and transcription please visit www.dictaphones.com, alternatively simply ring Speak-IT on (0121) 456800. Their team of specialised staff with over 30 years of experience in both dictation and transcription will be more than happy to assist!
Oct 24, 2012 | Olympus DS-3500 ODMS Pro Digital Voice...
SEARCH GOOGLE USING E-SPEAKING
These commands are built-in. You do not have to add or program them.
Working with Applications
Say... Open Word
Open Excel
Open Email
Open Powerpoint
Open Internet
Open Notepad
Close Application
Close Window
Close Document
Scroll Down
Scroll Up
Start Word
Start Excel
Start Email
Start Powerpoint
Start Internet
Start Notepad
Minimize
Maximize
Scroll Left
Scroll Right
Browsing the Web
Browse the web using the following commands: Open Internet
Google Website
Yahoo Website
Altavista Website
MSN Website
eBay Website
e-Speaking Website
Go Back
Go Forward
Refresh
Dialog Commands
Sometimes a program will simply ask you for a yes or no answer to an alert box or dialog. Yes
No
Cancel
Affirmative
System Commands
You can control when e-Speaking is "listening" to you using these voice commands. Standby
Resume
Stop Listening
Begin Listening
Hello
Computer
Listen to Me
Add a New Command
Add Mouse Click
Moving the Mouse
The Mouse Movement option has to be checked on the Mouse menu. Mouse Left
Mouse Right
Mouse Down
Mouse Up
Faster
Slower
Stop
Mouse Clock One
Mouse Clock Two
Mouse Clock Three
Mouse Clock Four
Mouse Clock Five
Mouse Clock Six
Mouse Clock Seven
Mouse Clock Eight
Mouse Clock Nine
Mouse Clock Ten
Mouse Clock Eleven
Mouse Clock Twelve
Slide Left
Slide Right
Slide Down
Slide Up
Mouse Buttons
Select
Double Click
Right Click
Properties
Drag Item
Drag File
Drag Object
Release Item
Release File
Release Object
Mouse Jump To
Mouse One - Top of Window
Mouse Two
Mouse Three
Mouse Four - Middle of Window
Mouse Five
Mouse Six
Mouse Seven - Bottom of Window
Mouse Alpha - Left of Window
Mouse Beta
Mouse Charlie
Mouse Delta - Middle of Window
Mouse Echo
Mouse Foxtrot
Mouse Golf - Right of Window
Editing Commands
Doing some word processing? These commands may help perform common Windows functions. Select All
Edit Copy
Edit Paste
Edit Undo
Edit Delete
Edit Find
Delete Line
Find
Search and Replace
Moving the Text Cursor
These commands may help navigate documents. Left Arrow
Left One
Left Two
Down Arrow
Down One
Down Two
Right Arrow
Right One
Right Two
Up Arrow
Up One
Up Two
Page Up
Page Down
Beginning of Line
End of Line
Beginning of Document
End of Document
Simulating Keys
Enter Key
Home Key
End Key
Spacebar
Escape Key
Delete Key
Backspace Key
Tab Key
Dictation
Start Dictation
Stop Dictation
Standby
Resume
Train Word
Show Commands
Dictation - Editing
Delete that Phrase
Delete that Text
Delete Last Phrase
Delete Last Text
Strike that Phrase
Delete Last Word
Edit Copy
Edit Paste
New Line (inserts a line)
Next Line (inserts a line)
New Paragraph (inserts 2 lines)
Next Paragraph (inserts 2 lines)
Select All
Delete Key
Backspace Key
Reading Commands
Read All Text
Read Selected Text
Stop Reading
Pause Reading
Resume Reading
Skip Ahead
Skip Back
Read Faster
Read Slower
Phonetic Alphabet
You must really like using voice if you are into the Phonetic Alphabet. Alpha
Bravo
Charlie
Delta
Echo
Foxtrot
Golf
Hotel
India
Juliet
Kilo
Lima
Mike
November
Oscar
Papa
Quebec
Romeo
Sierra
Tango
Uniform
Victor
Whiskey
Xray
Yankee
Zulu
Feb 05, 2011 | e-Speaking
Is it possible to rewind and overwrite dictation with Olympus VN-2100PC
Unfortunately with this device the VN-2100PC it is not possible to rewind and overwrite any dictations that were done. Each time the record button is pressed and then the stop button is pressed it will create a new file. They may want to look for a DS-2300 or a DS-2400 recorder as these devices have the ability to rewind and allow you to dictate over previously recorded information in the same file. There is a button on these devices called "New" that allows you to stay within the same file until you press New to start the next audio file.
Jan 09, 2009 | Olympus VN-2100PC Digital Voice Recorder
Editing? Can dictation be paused, then go back part way and....
you can not do this with the Olympus ws-100, you need a dictation machine that has the editing function which allows you to easily insert, overwrite, partially erase files and continue on the same file, most of the digital dictation units have NEW FILE BUTTON , you will stay recording on the same file till you press new.
Look at Olympus DS-2300. Olympus DS-33300 or ds-4000.
Apr 23, 2008 | Olympus WS-100 Digital Voice Recorder
Is it possible to stop recording without opening a new file?
Olympus DS-4000 Digital Voice Recorder Logo
180 people viewed this question
Top Olympus Audio Players & Recorders Experts
Mitch Davis
Mitch Davis
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
