Question about Stamina Products Stamina Dual Action Air Resistance Upright Bike 15-1100
Need tension belt for stamine 890 air bike
Need to fine tension belt for air bike.
Feels like pedals slip once in a while. How do I repair this please?
replace the spring, maybe it has lost some of the loading and become "tired".
Jul 03, 2015 | Cybex Cyclone 530c Upright Exercise Bike...
What is the problem if the tensioner is lose
Timing chain? Big problem if the bike is been driving still' you can wear the can hear and thus cause timing to slip or "jump" a tooth and cause huge engine damage
Feb 14, 2015 | Motorcycles
I NEED A DIAGRAM ON HOW TO INSTALL A NEW ALTERNATOR BELT ON A 1982 TOYOTA CELICA GT WITH A/C.
Hi, it appears there are other belts in front of the alternator belt. In this case, the other belts have to come off first. There are adjusting mechanisms on each the air pump, compressor, and alternator to loosen and tighten the belts. The power steering belt is adjusted by sliding the idler pulley. Please follow the instructions below and let me know if you have any questions.
ADJUSTING
See Figures 6, 7, 8, 9, 10 and 11
Fig. Fig. 6: Loosen the pivot bolt ...
Fig. Fig. 7: ... push the component inwards ...
Fig. Fig. 8: ... slip the old belt off and install a new one
Fig. Fig. 9: Pull outwards to tension the belt
Fig. Fig. 10: Belt routing on the 20R, 22R and 22R-EC engines
Fig. Fig. 11: Belt routing on the 4ME, 5ME and 5MG-E engines
Alternator
To adjust the tension of the alternator drive belt on all models, loosen the pivot and mounting bolts on the alternator. Using a wooden hammer handle, a broomstick or your hand, move the alternator one way or the other until the proper tension is achieved.
WARNING Do not use a screwdriver or any other metal device (such as a prybar) as a lever.
Tighten the mounting bolts securely. If a new belt has been installed, recheck the tension after about 200 miles (480 km) of driving.
Air Conditioning Compressor
A/C compressor belt tension can be adjusted by turning the tension adjusting bolt which is located on the compressor tensioner bracket. Turn the bolt clockwise to tighten the belt and counterclockwise to loosen it.
Air Pump
See Figures 12
To adjust the tension of the air pump drive belt, loosen the adjusting lever bolt and the pivot bolt. Move the pump in or out until the desired tension is felt.
The tension should be checked between the air pump and the crankshaft pulley on cars without air conditioning. On cars with A/C, the tension should be checked between the A/C compressor and the crankshaft pulley.
Fig. Fig. 12: Moving the air pump to tension the drive belt
Power Steering Pump
Tension on the power steering belt is adjusted by means of an idler pulley. Turn the adjusting bolt on the idler pulley until the desired tension is felt and then retighten the lockbolt.
Sep 11, 2011 | Toyota Celica Cars & Trucks
I have a Heritage Softail 87 on my way home I lost all gears, clutch feels fine, and I can feel it select gears but still no engagement of the gears, the bike also runs fine but no neutral light. Cheers...
Put the bike in gear with the engine not running. Try to push the bike. If the bike rolls freely, the final drive belt is broken. Check the tension on the belt. The only other thing that I can think of is the final drive belt front pulley has stripped out. The early belt drive bikes, the front belt drive pulley was very thin in the area where the splines were cut for the final drive gear. In 1994, Harley can out with an improved front pulley and offered a retrofit kit to replace the earlier models. When the front pulley strips the splines out, it will not drive the rear drive belt. The final drive gear simply turns inside the center bore of the pulley.
To change the belt on your Softail, you'll have to pull the outer primary cover, the entire primary drive mechanism, the inner primary, the starter, the exhaust system (to get the starter off), the rear wheel, and the swing arm. If the pulley is bad but the belt is good, you do not have to pull the rear wheel and the swingarm.
Good Luck
Steve
Apr 21, 2011 | Harley Davidson FLSTC Heritage Softail...
Need diagram for serpentine belt
2004 SUZUKI FORENZA - L4 2.0L 2000cc GAS FI N
Adjustment
The belt is automatically adjusted by the auto tensioner.
Drive Belt Routings
Fig. Accessory drive belt routing-2.0L engine
Removal & Installation
  1. Remove the air filter housing assembly bolts and the air intake tube.
  2. Remove the air filter housing assembly from the vehicle.
  3. Use a wrench to turn the tensioner bolt clockwise, compressing the tensioner, and releasing the tension on the serpentine accessory drive belt.
  4. Remove the serpentine accessory drive belt.
To install:
  1. Use a wrench to turn the tensioner bolt clockwise, compressing the tensioner, and releasing the tension on the serpentine accessory drive belt.
  2. With the wrench in place on the tensioner bolt, loop the serpentine accessory drive belt loosely over the pulleys.
  3. Slip the belt over the tensioner.
  4. Remove the wrench from the tensioner bolt and the belt will tighten itself.
  5. Install the air filter housing assembly into the vehicle.
  6. Install the air intake tube and the air filter housing assembly bolts.
  7. Tighten the air filter housing assembly bolts to 53 inch lbs. and nm
I really hope helped with this. remember rated this help. Good luck.
Nov 12, 2009 | 2004 Suzuki Forenza
Timing belt or timing chain?
You 98 Corolla has a timing chain that it internal and need no normal maintenance. It uses a hydraulic/spring tensioner to keep things tight and as long as its quiet, everything is fine.
Your drive belt (not to be confused with a t. belt) is the external belt you see on the passenger side of the engine. It drives you alt, water pump, A/C and power steering. It uses a spring loaded tensioner to keep the belt tight. These can weaken over time and cause a rattle noise and belt slippage.
May 19, 2009 | 1998 Toyota Corolla
Change rear wheel on Harley Davidson
first ya need to suspend it in the air using a bike jack loosen chain tension on it unbolt the axel and it should come out from the rear of the bike
Mar 27, 2009 | Harley Davidson FLSTC Heritage Softail...
Belt squeal 2000 gmc
replaced the air conditoiner belt and serviced the tensioner for this belt
Jun 24, 2008 | 2000 GMC New Sierra 1500
Stamina Products Stamina Dual Action Air Resistance Upright Bike 15-1100 Logo
37 people viewed this question
Top Stamina Products Exercise & Fitness Experts
Electro Med Services...
Tom Chichester
Are you a Stamina Products Exercise and Fitnes Expert? Answer questions, earn points and help others
