Question about Cuisinart Cwc-3200 32 Bottle Wine Chiller
Circuit board 3200
I need circuit board
    Champion:
    Habit-Forming:
  • 275 Answers
Have you contacted the Cuisine Art service centre if in the US try 1-800-726-0190.
Posted on Nov 21, 2013
My 2006 Polaroid 3200 lcd tv goes black. It may stay on for days, or it may stay on for a few minutes or it may not come on at all. has audio all the time?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced.
Dec 10, 2015 | Polaroid Televison & Video
How to fix a proview 3200 HD TV with no sound?
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Aug 10, 2014 | Proview Televison & Video
Proview 3200 LCD TV won't turn on
Possibly a printed circuit board gone in it,recommend a TV repair man have a look.
Jul 21, 2014 | Proview 3200 Repair Kit
Hi i have a ilo 32" tv, it powers on for 1 second and then picture goes black and the power button continues on, how can i fix it?
Bad or blown capacitors. Look on circuit board for domed, bulging or leaking capacitors. USE CAUTION!! high voltage capacitors can electrocute you. They should be properly discharged before working on circuit board.
Jun 12, 2011 | iLO 3200 32 in. LCD Television
My screen on my Sanyo 3200 is white and nothing comes up. What is the problem and how do I fix it? Thank you.
Chances are that the very thin, delicate ribbon cable that goes to the upper part of the phone with the inner display screen has either come detached from the circuit board, which can be fixed, or the cable itself has broken and in which case the phone is non-repairable.
Oct 26, 2009 | Sanyo SCP-3200 Cellular Phone
I'm getting a code 10; cannot start device on my maxtor 3200 . The power light is on, but it no longer functions.
What is wrong with your drive is probably what was wrong with my drive. After two whole days of gut wrenching about should I or shouldnt I take the darn box apart , I took it apart figuring well it is a code 10 and Seagate ( bought maxtor) tells you that the drive has probably failed.
I took mine apart and found a printed circuit board that was attached to a standard IDE drive. I took the board off and plugged the now IDE drive into a spare IDE cable and power connection, turned on my computer and crossed my fingers. Lo and Behold the "CODE 10" DEAD HARDDRIVE WAS ALIVE!!! my guess is that the circuit boards overheat as their are very little air flow slots for this drive and something lets go between the hard drive and the connections. So dont throw it away , carefully pry open the plastic case and remove the hard drive and the printed circuit board ( you have to unscrew the metal cage around both and take out the 3 screws in the printed circuit board. then carefully separate the board from the hard drive . At least you should be able to recover your data on the hard drive. I ran a quality test on the hard drive after I copied all the files from it and there is not one sector wrong on the whole drive. This may not be the solution you are looking for but in the least you are not throwing away a possibly good hard drive. Patience is the rule in prying the case open ( I did it with two medium screwdrivers and started at the hole in the case near the connectors that is rectangular in shape. I too had the lights are on but nobody's home syndrome. Good luck
Aug 05, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Averatec 3200 power jack repair
You mean THIS?
eBay is full of power jacks for various computers. It isn't a difficult thing to do to replace it if you have a fair amount of soldering/desoldering experience. Be very careful and wear some sort of grounding device because you might toast the motherboard as you work on it.
I'm guessing you are having problems with it charging, including having to find a specific spot where there is a good connection and/or having to apply pressure in order for it to charge.
Oct 16, 2008 | Averatec 3200 Notebook
Tv.inop
check your children lock status.if lock, unlock from your remote
Sep 18, 2008 | iLO 3200 32 in. LCD Television
OMNI 3200 KEYPAP WORN OUT
I can replace these keypads for a fraction of the cost of another terminal. Contact me if you'd like.
Feb 29, 2008 | VeriFone OMNI 3200 (P092-101-10) Printer
Cuisinart Cwc-3200 32 Bottle Wine Chiller Logo
129 people viewed this question
Top Cuisinart Refrigerators Experts
Darrell
richie46
Are you a Cuisinart Refrigerator Expert? Answer questions, earn points and help others
