Question about Cell Phones
Johnson corporation is preparing a flexible budjet and desires to separate its electricity expense , which is semi variable and fluctuates with total number of machine hours, into its fixed and variable components.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cell Phones Master
  • 102,366 Answers
Okay, and what is the question?
Posted on Nov 21, 2013
Tip
Dryer Ducting Installation Tips
Here’s some useful guidance for installing dryer ducting. Improperly installed ducting can cause the following:
GAS DRYERS – Rapid burn cycling and improper drying results.
ELECTRIC DRYERS – Premature Heating Element failures.
IMPORTANT! NEVER terminate ducting in a chimney, under an enclosed crawl space or attic, and never common a dryer duct with a kitchen exhaust.
The total length of ducting and number of turns should be kept to a minimum. Semi-rigid metal type ducting is strongly recommended as it is more durable and resists collapsing.
If connecting sections of ducting, all joints should be tight to avoid leaks. The male end of each section must point AWAY from the dryer to prevent lint from accumulating at each junction. Ductwork should NOT be assembled with screws or fasteners that extend INTO the duct as this also will create points where lint will become snagged and accumulate. Wrap overlapping sections of ducting with duct tape.
A screen should NEVER be installed over the exhaust duct termination. The preferred termination is a dampered wall cap having a 4 inch opening. It must be installed a minimum of 12 inches above the ground.
Maximum Length of Metal Duct:
# of 90 degree elbows 4” Semi-Rigid 4” Flexible
0 58 ft 28 ft
1 48 ft 23 ft
2 38 ft 19 ft
3 29 ft 17 ft
4 21 ft 15 ft
NOTE: It is recommended that you inspect your dryer ducting periodically to ensure you have no lint build up. Excessive lint can present a fire hazard.
on Feb 10, 2008 | Whirlpool GEW9250 Electric Dryer
Need to buy 2007 toyota tacoma 6 cylinder Variable Valve Timing SENSOR PLATE.
The variable unit is a bolt on on the end of the cam shaft
if you cannot get it separate , I would imagine that a genuine unit with shaft will be expensive
try wreckers where good serviceable units would be available at a fraction of the price
Sep 25, 2015 | Toyota Cars & Trucks
I can't get my scanner hooked up
Are you getting an error message? It could be your path EV. Try this
Look in C:\Windows\twain_32 and there should one other folder in there. In my case it was named CNQ4803.This is the path that is needed to be added into the PATH environment variable.
C:\Windows\twain_32\CNQ4803
Now, follow these instructions to get to the dialog to modify the PATH environment variable.Control Panel > System > and then choose Advanced System Settings in the left hand column.This will bring up the System Properties dialog (it should already be on the Advanced tab).At the bottom of this dialog is an Environment Variables button. Clicking this button will bring up the Environment Variables dialog. In the bottom panel, scroll until you find the variable named Path. Select this one and then hit the Edit... button to bring up the Edit System Variable dialog.
In the Variable value text box, scroll all the way to the right and then add in the path C:\Windows\twain_32\CNQ4803 that was determined earlier. Make sure to separate this value with a preceding semi-colon. And also be careful not to make any other changes to this value.
Now OK your way out of all of the dialogs and CanoScan Toolbox should now work as expected.
Nov 10, 2014 | Office Equipment & Supplies
I have a 1988 hurricane deck boat with a johnson 110 vro does it have a separate oil tank or do I mix the gas and oil in the gas tank?
seperate tanks VRO stands for variable ratio oiler .unless it has been disabled gas and oil don'y need mixed
Jun 23, 2014 | Boating
Fluctuating temperature now got un bearable, ive de scaled shower head totally and cleaned filter !!!!!!!
Test: take the shower head off, then run water. If the water can be adjusted to the desired level (hot/cold mix), then the problem is probably in the shower head. Contact the manufacturer of the shower head. If you cannot maintain a good mix, the problem may be in the valve behind the wall or a total house pressure problem---time to get out your wallet and call a plumber.
Apr 16, 2010 | Home
Thinner (and more expensive!) articles of clothing getting multipe small holes/rips. It appears that a plastic semi-circular insert/liner surrounding the inside of door opening broke free and the 'gap'...
go to home depot and buy a roll of flexible metal tape it looks like a roll of duct tape but is actually very thin metal almost like aluminum foill but thicker it is usually used to seal dryer vents it has a strong adhesive on it and is heat resistant.you can cut it to shape but make it a little larger, then make sure surface is clean and apply it around the hole appply a good amount of pressure with your thumbs when applying it I would give it a couple hours to adhere to surface and then try the dryer...good luck
Dec 19, 2009 | Dryers
WHIRLPOOL DRYER ELECTRIC - HOW TO VENT - WHAT PARTS NEEDED
You might want to check with your local building codes, because different states have different requirements, but for an electric dryer, a flexible vinyl tube should be fine. Better options are rigid metal, and flexible rigid metal tubing which are both more expensive, but stay cleaner longer and last longer.
Mar 12, 2009 | Dryers
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
