Question about Bosch "30"" Induction Cooktop with Touch Control 500 Series - Black with St..."
U 2 error on my cook top NIT5065UC
Was boiling water and burner shut off and a flashing U alternating with flashing 2 appears on control panel. What does this mean? The other "burners" work.
4 Suggested Answers
SOURCE: VGSU 36" gas cook-top control panel paint coming off
I just bought a bank repo home in So. Cal. that has the same Viking range as you have. Yes, the black lettering has almost entirely rubbed off. on this one too. Not good for such an expensive product.
I bit the bullet and ordered a new panel from appliancezone.com
http://store.appliancezone.com
Part # PE40057
The price is about $75, $80 with shipping, which is a ripoff I know.
I plan to put a clear coat of sealer on it and let my wife know to treat it gently.
I was surprised how many people think Viking products suck. Lots of negative reviews abound on the internet. If I was to buy a whole new range I think I'd avoid this brand.
Cheers,
Andy Dale
Posted on Jun 01, 2009
  • 530 Answers
SOURCE: pot overflowed and then flames from R side and clicking
yes this is commen when you spill liquid on the spark module what happens is it grounds itself out and will continue to spark until it drys out. you should be fine.
Posted on Jun 21, 2009
meztang
  • 112 Answers
SOURCE: When I turn any burner on, the ignitors work fine
It seems like one of your burners is clogged. You made need to use some oen cleaner and a small toothbrush to clean the burner. If the problem occurs with all the burners, then you have a blockage in the gas supply line. you willm have to take it apart at the stove and clear it out. Check the main gas connection and at the burner(s) to spot the debris clogging. Make sure to shut your gas valve off behind the stove. Good luck... hope this helps.
Posted on Jul 16, 2010
Gaggenau 200 Series?
If it is similar to the VE260 model, this induction type of cook top is very old. 22 - 23 years if it came with the home when it was built.
I can only offer basic suggestions of which you already probably know.
These induction type cook tops rely on the pan or skillet to be magnetic like stainless steel. If the bottom of the pan has any buildup of residue, this will dramatically reduce the efficiency of the unit.
If the pans are immaculate, then the electronic elements that produce the magnetic induction to heat the coils must be weak. As old as the unit is, it is probably not feasible to have 3 of the elements repaired....
A new top can be purchased much cheaper. Consult Consumers Reports for unbiased product reviews for your best reviews. As a final suggestion, find someone who is qualified to use an electrical multimeter to read the current on both sides of the power receptacle to ensure that your voltage is 230V. A loose connection on the receptacle can cause the elements to have the same result.
Although I can imagine you have already done everything above, I just wanted to send you what I can offer.
Jan 02, 2014 | Gaggenau Cooktops
I was boiling water for potatoes on the Electrolux induction cooktop last night. Only using one of the five burners when I heard a "pop" sound and possibly a flash of light. Error code we have is EO
Hi Gail, I am happy to assist you!
It appears the main control has detected a faulty or error condition. "E0" should be followed by two more digits to indicate which error has occurred. Let's try turning electrical power supply off. It is necessary to wait roughly ten minutes to reset cook-top main controls. If resetting the power does not correct the issue or provides a new error code, at this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
Dec 20, 2013 | Electrolux 36" Electric Hybrid Induction...
Maytag Range won't heat up oven or cook top
you have melted internal wiring, probably some mice ate it. call an electrician and DO NOT USE IT!! turn off at the wall/fusebox
Nov 20, 2013 | Maytag MER8770WS 30" Freestanding Electric...
Error message on my electrolux INDUCTION STOVE TOP
Hello - Typically error code E on Electrolux induction cook top indicates an error with the user interface board/control board. Contact a professional to move forward accurately and properly diagnose/repair the unit.
Oct 30, 2012 | Electrolux ICON Designer Series E36IC80ISS...
New Maytag MGC7430 gas cooktop leaks gas when lit
First it could be leaking from the control knob when it is on . There could be a leak at the base off the burner letting out gas or on the burner line . You need to get back on to your installer or where you purchased the cook top . This basic gas fitting leak detection .
Jun 15, 2017 | Maytag Cooktops
Spark igniters continue to spark:
let it all dry out
thumbs up
Aug 17, 2009 | Cooktops
Water boiled over into control knobs for the cook top elements.
Just fixed this problem and repaired the corner of the Ceran cooktop.
Disclaimer: These cooktops run on 220V and will kill you if you don't know how to work with electricity. If you're unsure, get some help.
The boiling water slopped out of your pot, and went over to your controls (knobs) and went down the shaft and into a component call "Infinity Switch". The water caused the switch internally to weld one of the two internal sets of contact points into a permanent position. The fix is to replace the
"Infinity Switch" that the boiling water spilled into. The Infinity switch is the component that the control knob slides on to.
In my cooktop one of the infinity switches failed and appears to damage the adjacent switch. Mine actually caught on fire and damaged the wiring and the connector. Hopefully you are better off. Since they were in such close proximity I replaced them both. For $20 you might consider the same. I replaced both to be safe and they were $21.47 each.
My cooktop has 4 elements 2 small, 1 large and 1 combined (small and large) surface. A large element was definitely damaged and possibly a small element. I ordered both. I mention this in case a multi-element was damaged on your cooktop.
You will need to contact either Jenn-Air or someone. Since you can't see an exploded parts list online, you'll have to use the schematic. It is in a plastic sleeve and it stuck to the side of the ventilator housing underneath the cooktop.
When you wire the new part in, make sure you have the wiring correct or when you turn it back on you will burn up the new part.
I hope this helps.
Apr 02, 2009 | Jenn-Air JED8430 Electric Cooktop
Will burner get too hot
Hello Pinewood7. The issue here is concern from what you have heard. Don't worry! All you are doing is boiling water. The system will allow constant heat for what you are doing. Use this as a test. Put your largest pot on the top full of water and set on high. Attach your thermometer to the side and see what happens. I know several people who use these tops for canning with excellent results. My sister in law has had yours for years and not an issue with jams. Hope this helps with your concerns.
Aug 09, 2008 | Jenn-Air Expressions AR141 Electric...
Ticking Sound of spark igniter persists
Our GE cook-top burner igniter has started ticking even when the oven is shut off. Even after cleaning the bottom of controls the ticking persists. Any suggestions? Thanks
Aug 27, 2007 | GE 36 in. JGP628 Gas Cooktop
Bosch "30"" Induction Cooktop with Touch Control 500 Series - Black with St..." Logo
54 people viewed this question
Top Bosch Cooktops Experts
Paul Carew
Jay Finke
Jay Finke
steve morris
steve morris
Are you a Bosch Cooktop Expert? Answer questions, earn points and help others
