Question about Vivitar DVR 882HD Camcorder
How do i charge the battery on my 882hd camcorder
What does a red light on the camcorder mean
It indicated the camera is recording the media.
Aug 17, 2015 | Vivitar DVR 882HD Camcorder
VivitarDVR882HD-HD720P; How do I get the notice protected card off of the camera to take pictures?
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 23, 2014 | Vivitar DVR 882HD Camcorder
How to pop the battery of a vivitar 882 hd camcorder
It's not sealed just, fortunately. It's just difficult to open.
The door should be on the same side of the camera as the lens.
Turn the camera upside down, and using both thumbs, push against the flat area, about 2 cm (or, about an inch) below the lens. Push from the lens toward the Vivitar name. It may not move the first time, but it should come loose after a few attempts.
This is for the Vivitar DVR 882HD. If you have a Vivitar 882 (without the DVR), it should be the same instructions, but the door to the battery case might be on the other side...I don't know if it is or not, because I don't have that version. In either case, though, just keep trying, and it should open for you.
Nov 29, 2013 | Vivitar Video Cameras
Cant get my pictures downloaded onto my computer from the card reader
On the front, where the camera lens is, is the door you can open to take out the battery if it will not turn off. Hold the camera upside down, and use your thumbs to force the door to side off - it's not always easy to do. Push from the lens, toward the "Vivitar" name.
I have the same model, and mine just started doing this last month, and I've had it for almost 2 years now. Maybe it's just not recognizing the Off command from the button like it used to. I don't know. But taking the battery out always kills it. Then, put the battery back in (correctly) to use the cam again.
Oct 26, 2013 | Vivitar DVR 882HD Camcorder
My Vivitar Camcorder 882HD would turn on but not work; also won't turn off
Sep 12, 2013 | Vivitar DVR 882HD Camcorder
Camcorder works only when charging!!
Maybe you need a new camcorder battery to test.
We have many camcorder batteries on sale. Welcome to visit:
Canada
www.buy-battery.ca/camcorder-battery.php
USA
www.all-batteries-shop.com/camcorder-battery
May 08, 2009 | Jazz DV-179 Digital Camera
Battery Won't Charge on JVC GZ-MG275
The only suggestion is that it's a faulty battery. You said the camcorder is new, take the battery back, it's under waranty, and get a new one.
Dec 25, 2007 | JVC Lenmar BN-VF707U Camcorder Battery
Sharp Camcorder VL-NZ100E battery doesn't seem to charge
2.7 volts is too low. Usually camcorders use battery at least 6 volts. Problems with rechargeables especially NiCds and NiMH, a cell will be shorted. for 6 volts pack, there are 5 cells in series (5 pcs x 1.2 volts with load , 1.35 no load). If you are measuring only 2.7 volts, it is highly possible that 3 cells are dead. As for the charger, if the same charger is used to power the camcorder and you said the the camcorder operates using the adaptor, this means that the charger is OK. You can ZAP the battery back to life but I will not recommend. It can be dangerous. If you can buy the battery, I suggest you do it since the old battery, even when zapped, will not provide enough juice anymore.
May 22, 2007 | Sharp Viewcam VL-NZ100U Mini DV Digital...
Can't charge the battery
# New batteries need to be drained by using the camcorder until the viewfinder indicates the battery is empty. Follow these steps: Once the battery has been drained, you may use the charger to recharge the battery. # Consult your manual for the amount of time the battery requires on the charger to get a full charge. # A full charge will be delivered by the charger. # Some camcorders have a Refresh feature, which will automatically drain the initial charge on the battery. This allows the battery to fully recharge.
Sep 06, 2005 | RCA CC-432 Camcorder
Vivitar DVR 882HD Camcorder Logo
52 people viewed this question
Top Vivitar Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
 John
John
Are you a Vivitar Video Camera Expert? Answer questions, earn points and help others
