Question about Microwave Ovens
Computime Model # CTW218
Manual or troubleshooting list
Do you have a manual for model # MH7100XYB-0 (Microwave)? I am having problems with my microwave and have misplaced the installation manual.
The installation manual is here. The exploded parts list is here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Aug 18, 2010 | Whirlpool GH7145XF Microwave Oven
Maytag MMV4205BA internal fan quits
As promised, here is your solution information:
You can download Maytag owner's manuals, installation instructions, and parts lists here.
You can find the service manual (which may not have a parts list) by selecting Literature by Model on this page and entering your exact model number with suffix. (Also try it without suffix if you have trouble).
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You need all three of those documents in some cases.
Finally, you can find helpful exploded view diagrams and order parts by entering your full model number here.
At our site, we now have a video available showing how to remove a typical control panel assembly in under 5 minutes.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Aug 28, 2008 | Maytag MMV4205 Microwave Oven
I have a whirlpool microwave. Model GT4185sks-2. I turned on by itself. Afterwards, no heat coming from unit.
When it's plugged in, does it still try to come on?
If so, it may have a failing keypad.
And if it ran empty for too long, it may have overheated and damaged the magnetron too.
I don't see a thermostat or thermal cutout mentioned in the exploded views and parts lists, but it pretty much has to have one.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
This is one case where that will come in handy.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 10, 2008 | Microwave Ovens
I have the GE profile combo microwave & convection. I keep getting F4 code when ever I use the sensor buttons.
F4 means your temperature sensor is shorted or coated with grease.
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Jun 27, 2008 | GE Microwave Ovens
Microwave was run with nothing inside and shut down.
Did it come back on?
If not, then you probably have a blown thermal cutout on the magnetron.
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
Jun 04, 2008 | Maytag Microwave Ovens
Model JMV8000 Jenn-Air Microwave
I would say one of the thermal fuses has blown, either the one for the magnetron or the cooking cavity. This is a simple and inexpensive fix for a DIYer.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find the full service manual for a similar model here.
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting. It will have exact troubleshooting details.
William E. Miller, AS-EET
prototech@usa.net
Apr 27, 2008 | Microwave Ovens
The exhaust on our frigidaire microwave started making a high pitched squealing noise, is there anyway to fix it?
I would say the bearings of your hood exhaust fan motor are going out.
Please reply back with your brand and full model number so we can possibly offer more specific advice?
prototech@usa.net
Apr 26, 2008 | Microwave Ovens
Where is the fuse for a maytage microwave MMV5207bas
The fuse is located behind the grille in line with the power cord on the right side of the unit.
But if your unit is dead, it may also be a bad magnetron thermal fuse or oven thermostat.
We have the entire service manual in electronic format as well. Please feel free to contact me directly if you need more help or would like the manual.
prototech@usa.net
Apr 23, 2008 | Microwave Ovens
Ge microwave
To mrotu47182 and MaryGur - you may very well have different problems!
TO mrotu47182:
Chances are the magnetron overheated, blowing the "magnetron thermal cutout".
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
To MaryGur:
Your problem may be a bad keypad, but the first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
If that doesn't fix it, you may have a bad keypad, assuming that your unit's display is on, but it won't respond to any key presses.
Is this your symptom?
If you'd rather have us fix it for you, we do that for $39.95 plus parts and you can visit us via our link here on Fixya http://tinyurl.com/yzjozk
Mar 17, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE microwave model number-JVM3670sk03. It seems to make too much noise when it is in use.
It may be a failing turntable motor or magnetron, depending on where the noise is coming from.
Mar 14, 2008 | Microwave Ovens
Microwave Ovens Logo
61 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
