Question about Stanley Bostitch GFN1664K 16Guage Cordless Gas Finish Nailer
Its charged but wont work....right fuel gas can?
The Scooter was only ridden for 63miles around neighborhood. Then sat for about six months now wont start was told gas could be old. What to do
Best bet would be to empty the fuel left in it then buy some fuel stabilizer and refill fill the tank with good gas also check the battery and fuses.
Feb 19, 2016 | GAS Motorcycles
My 2005 dodge stratus set for about a month and a half without periodically starting it. I'm ready to start driving it again and it wont start. It has gas.it wants to start and will turn over but wont
Are you mechanically inclined?
Here are a couple things to try:
1. Turn the key to ON (don't crank the engine
then OFF and back ON - several times.
this will pulse the fuel pump several times to charge the fuel rail.
then try to start.
2. If it doesn't catch/start right away - hold the throttle to the floor while cranking. This will put the Computer in "Start Flooded Engine" mode and turn OFF the fuel injectors.
If those things don't work - some serious diagnostics will be in order - let me know how this works :)
Feb 06, 2015 | 2005 Dodge Stratus
I have a 92 caviler station wagon. That will start without a problem but will Idol for one second then die. My car was running fine last night. Then I got up for work this morning with a dead battery so I...
OK, have you check is the charging system is working correctly? The alternator should be charging the unit. Does you battery hold power(12.5V Minimum)? If the problem is not the charging system, check for Fuel issues. Does the gas pump delivering fuel to the EFI/Carburetor? Also try to clean the spark plugs and check if the ignition coil is working correctly.
Basically your wagon problem sounds as if it is Ignition/fuel issue. If it turns on then dies means that either there is spark issue or gas issue. Not enough fuel goes into the combustion change and it gets cut off right after turning on.
Dec 17, 2017 | Cars & Trucks
I have a 2004 pontiac sunfire it turns over but wont fire"start"
squirt a little gas on the air intake manifold start engine if it runs check fuel filters, fuel pump, anything related to fuel delivery injectors later, make sure fuel pressure is right. tell me the outcome ill find out more for you. good luck
Mar 16, 2014 | Cars & Trucks
Wont kick over
  1. Hi Mike, maybe something got stirred up and lodged in the fuel filter? Maybe the fuel pump finally went? Can you hear the relay click and/or the fuel pump run when you turn on the ignition? Maybe some critter gnawed it's way through a wire or two; they really seem to like our Loyales. I just had one do this because the battery connection was good enough, but then slipped away.
Jan 20, 2014 | 1993 Subaru Loyale
2002 Bonneville My gas gauge wasn't working right
it may be that you didn't run out of fuel but the fuel pump quit-check the fuse-you more than likely need a new fuel pump-the fuel pump and the fuel level sensor are one unit in the fuel tank-cheers Denny
Nov 01, 2013 | Pontiac Bonneville Cars & Trucks
MY 1971 CUSTOM SHOVEL HEAD 93 STROKER SOMTIMES ITS STARTS RIGHT UP AND RUNS FINE THEN IT WILL STALL AND WONT START AGAIN
Hi Eddisbrow, and the usual suspects are:
1. Severely discharged or damaged battery.
2. Loose, corroded or broken battery cable.
3. Alternator not charging or below normal rates.
4. Failed ignition coil, ignition/electronic module.
5. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor.
6. Faulty ignition switch.
7. Water or dirt in fuel system, carburetor or filter.
8. Fuel tank vent system plugged or gas cap not venting.
9. Fuel tank empty.
10. Fuel valve vacuum line broken or carburator vent line closed off.
11. Restricted, blocked or kinked fuel line.
12. Failed fuel pump, pressure regulator and or fuel injectors.
For a prime suspect please visit website below and good luck:
Harley Davidson Manuals Mark Workshop
Mar 18, 2012 | 2000 Harley Davidson FLTR-FLTRI Road Glide
Troubleshooting car starting problems for a 93 Cadillac Deville
this happen with my 93 ,if the car cranks,it's your gas presser regulator. it's on the top of the engine ,right side of carb.
Dec 28, 2008 | 1993 Cadillac DeVille
Wont strat
Hello thank you for using FixYa.com for your answer my name is David.
You say it wont start in the normal way by just turning it on but if you pour gas in the throttle body
it will start sounds like you have a weak fuel pump most likely but there are a few other things that could cause it also .
1 Inspect Battery Damaged or faulty battery and/or connections. grey_line.gif 2 Inspect Coil - Ignition Damaged or faulty ignition coil or ignition coil circuit. grey_line.gif 3 Inspect Fuel Filter Clogged or dirty fuel filter grey_line.gif 4 Inspect Fuel Injector Pressure Regulator Faulty fuel injector pressure regulator or circuit. grey_line.gif 5 Inspect Fuel Pump Improperly functioning fuel pump or circuits. grey_line.gif 6 Inspect Wireset Damaged, worn, or deteriorating spark plug or coil wire(s). grey_line.gif 7 Inspect Control Module-Ignition Faulty ignition control module or circuit. grey_line.gif 8 Inspect Solenoid Switch Damaged or faulty solenoid switch or solenoid switch circuit. grey_line.gif 9 Inspect Starter Damaged, worn, defective, or faulty starter or starter related circuit. grey_line.gif 10 Inspect Neutral Safety Switch Damaged or faulty neutral safety swittch or circuit. grey_line.gif 11 Inspect Air Charge Sensor Damaged or faulty air charge sensor or air charge sensor circuit. grey_line.gif 12 Inspect Fuse Corroded, burned, or shorted fuse may be interupting power source. grey_line.gif
Nov 08, 2008 | 1988 Chevrolet C1500
Stanley Bostitch GFN1664K 16Guage Cordless Gas Finish Nailer Logo
66 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
