Question about Whirlpool Dryers
What is the cubic foot for the Whirlpool model LER4634EQ0
I want to replace this dryer with a bigger one, so I need to know how big the present one is.
jsrock516
  • 5911 Answers
SOURCE: how do I get to the thermal fuse on Whirlpool
All the heating and temperature control components are located in the back of the dryer. To access, unplug the dryer and remove the exhaust vent hose. Turn the the dryer around so you can view the back and remove the back panel. With the panel removed, the component locations are as follows:
Right-Hand Side:
1. Heating element - located inside the heater box. If bad, the dryer will run, but will not heat. A good reading is about 9 to 13 ohms.
2. Thermal Cut-Out (TCO) - located on the outside of the heater box on the end opposite the heating element terminals. If bad, the dryer will run, but will not heat. A good reading is a short (0 ohms).
3. Hi-Limit Thermostat - located on the outside of the heater box adjacent to the heating element terminals. It works in conjunction with the TCO to help regulate the drum internal temperature. A good reading is a short (0 ohms).
NOTE: If either the TCO or Hi-Limit Thermostat are found to be defective, it is recommended that you replace BOTH components to prevent premature failure. These two components are commonly sold as a set.
Left-Hand Side:
1. Thermal Fuse - located on the blower fan housing. It is a small white plastic looking component with two wires attached. If defective, the dryer will not run at all. If the component is good it should read a short (0 ohms).
2. Internal Bias Thermostat - located on the blower fan housing adjacent to the Thermal Fuse. It has four wires attached to it.
NOTE: All resistance checks should be performed with the component terminal wires disconnected to prevent false readings.
If you have any questions, you can refer to searspartsdirect.com for some helpful exploded view diagrams to assist you. The components I mention are listed under the "Bulkhead" heading as follows:
Item 6 - TCO/Hi-Limit Thermostat replacement kit
Item 15 - Hi-Limit Thermostat sold separately
Item 17 - Heating Element
Item 23 - Thermal Fuse
Item 24 - Internal Bias Thermostat
If you need further assistance, please let me know. I hope this helps you.
Posted on Sep 23, 2009
Testimonial: "thanks so very much! Got the fuse yesterday and will try today. I'll let you know. VERY HELPFUL!"
jsrock516
  • 5911 Answers
SOURCE: replaced element and dryer still won't heat
You replaced the heating element, but did you check the Thermal Cut-Out (TCO) or Hi Limit Thermostat? These two components work in conjunction to regulate the temperature of the heating circuits. In most dryer related heat problems, the TCO will fail before the heating element.
The TCO is located on the outside of the heater box at the end opposite the heating element leads. The Hi-Limit Thermostat is also located on the outside of the heater box, but is located adjacent to the heating element leads. Both these components should read 0 ohms with a multimeter if good. If either component is found to be defective, you must replace BOTH of them at the same time. Failure to do so may result in premature failure of any components you replace. Thats why these two parts are usually sold as a set. The part number is 279816 and can be purchased at any of the following websites:
searspartsdirect.om
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
You can view a diagram of these components using the helpful exploded view diagrams on the any of the first three websites I have listed. The last website only shows part illustrations. The TCO and High Limit Thermostat will be listed as items 6 and 15 respectively under the "Bulkhead' parts section. NOTE: Item 6 comes with item 15 when ordering.
Another thing to consider is the input voltage at the wall receptacle. Did you verify the voltage was correct? You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
Now if you determine the TCO is defective, it usually blows for a reason. It usually fails due to an overheat condition. This is commonly caused by clogged or poorly installed exhaust vent ducting. If you haven't inspected or cleaned the dryer interior, or external ducting recently, now would be a good time to do so before you replace any parts. If left in a poorly ventilated condition, a dryer will overheat to the point of failure. Which may potentially ruin any new parts you replace.
If you have any questions, please let me know. I hope you find this information helpful.
Posted on Oct 09, 2009
  • 119 Answers
SOURCE: I need to replace my Dad's dryer (he's out of
ANY DRYER WILL WORK THAY ARE ALL THE SAME SIZE GET HIM A KENMORE HD
Posted on Jan 31, 2010
  • 2341 Answers
SOURCE: WHIRLPOOL ELETRIC CLOTHES DRYER MODEL#
go to the back of dryer where the plug connects to the dryer and make sure you have 240 volts,if you don't check the house fuses,unplug the dryer remove the vent line and take off the back panel,on the left side you'll see the duct that the lint filter slides into,to the right of it you'll see a white thermal fuse part 3392519,pull one of the wires off and check it with a meter,if that's bad you need to clean out the dryer,pull out the lint filter and remove the two phillips screws on top,now take out the four screws holding the duct in and clean it out,pull it out and push it to the right so you can clean it.clean out the vent line and the vent outside,if it's a long run from the dryer to the outside vent i use a leaf blower to blow out the line,you should do this once a year,you should pop the top of dryer with a screw driver lift up the top lid,take out the two 5/16 screws one on each side and remove the door switch wires and pull up on the front panel to remove it and clean out the inside of dryer also.if the fuse is good,read out the heater and the thermostats on the heater box,ifyou're not getting 240 to the heater you could have a bad timer,go here and put your model number in and you can see your dryer and all the parts,hope this helps you,if you need anything else let me know Parts & Accessories | Shop & Find Lawn & Garden, Appliance Parts at Sears PartsDirect | SearsPartsDirect.com
Posted on Mar 09, 2010
FixinFax
  • 3085 Answers
SOURCE: cubic foot size of Maytag PYE4500AYW
7.0 cubic ft.
Posted on Mar 28, 2010
What is the cubic foot capacity of Dryer modle 110.67832791 Ser MG3527834
Call whirlpool with that info. They can tell you.
Sep 26, 2017 | Dryers
What is the cubic feet or capacity of whirlpool elec dryer model # LER7648KQ0
Hi Sweetie, the dryer has a 7 cubic foot capacity. We hope this information is helpful.
Apr 01, 2017 | Whirlpool Washing Machines
What is the cu ft of model ler331dso
Hello friend, thank you for your inquiry!
I see that you would like to know the cubic footage of your Frigidaire dryer. It appears that your dryer is a 5.7 cubic foot dryer. I hope this information is helpful. -Matt
Feb 10, 2015 | Frigidaire Dryers
I need to buy a new dryer i have a Model GE DVLR223ETOWW . Need to Know Capacity. I need the same size Dryer because of the Limited Space
It appears to be 5.8 cubic foot capacity. Confirm this with the store when you purchase your next dryer.
Gary
Sep 03, 2011 | GE DVLR223 Dryers
Dryer Maytag LDE 9316 ACE -what is the capacity of that model dryer? Thank you!
Capacity is a key consideration when shopping for a dryer. The more you are able to dry in a single load, the less time and money you will spend doing your laundry. Most importantly, look for a dryer with approximately twice the cubic foot capacity of your washer.
Typical dryer capacity ranges from approximately 3.4 cubic feet (for a compact model) to over 7 cubic feet for an extra large capacitor
In addition to saving time by drying on fewer loads, and money on lower energy costs, a large capacity dryer often means spending less time once the laundry is dry. There is typically less wrinkling when clothes have more room to move around inside the drum.
Whirlpool brand offers dryers with a range of capacity and flexibility.
Dec 16, 2010 | Dryers
Compressor builds up air, but when i go to use tools looses pressure to point that its not usable.
how big is the compressor? if its only say 3 cubic foot a minuet that is at free air pressure not at say 8 bar,,,at 8 bar it would only be 0.375 cubic foot,, check to see how much air in cubic feet per minuet and at what pressure your tools need to work on
if they say 5 cubic feet at 8 bar and the compressor is only 3 cubic feet at 8 bar the tool will only run for a very short time before the compressor air tank has run out of air and the compressor cant keep up with the demand from the tool
the bigger the compressor and the bigger the air tank the better some times,,,for a hammer tool you need 8 cubic foot at 10 bar
thats a big compressor!! or a small one for only a short burst of time,,, in short,,,all ways go for a big un? compressor that is!!
i hope this has helped you out
Aug 26, 2010 | Hitachi EC12 Portable Electric 2hp Air...
How big inside (cubic ft.) is the Roper refridgerator
20.9 cubic feet for model # RT21AKXKQ
14 cubic feet for model number RT14BKXKQ05
Jun 07, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Dryers Logo
182 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
