Question about Baumatic B187 Stainless Steel Electric Single Oven
Baumatic osf60cepk no facia lighting, clock & oven light work
barkencoa
  • 3463 Answers
SOURCE: fan oven not heating up
If fan is working then the element has probably gone
Posted on Nov 30, 2008
barkencoa
  • 3463 Answers
SOURCE: Baumatic B501SS Built In Stainless steel electric single oven
If the fan is working in the main oven and there is no heat, then it will be a faulty element.
Remove the cover at rear of oven
and you will see the round element. remove it and replace with new one.
Plz rate my solution .
Thanks.
Posted on Jan 17, 2009
barkencoa
  • 3463 Answers
SOURCE: Baumatic fan assisted oven not heating up
The oven element has failed, you need to fit a new element.
It is a straight forward repair to do.
Remove inner rear panel of oven, you will see the round element at rear.
Unfasten element, detach wires, and fit new element.
Refit rear panel, and test.
Plz rate my solution.
Thanks.
Posted on Jan 24, 2009
SOURCE: Baumatic Oven - Setting the Clock/timer after power has been off.
Hi, You press the second and third button in together, hold them in and use the + or - buttons to set the time.
Posted on Jan 03, 2010
barkencoa
  • 3463 Answers
SOURCE: My Baumatic B180W-B oven does not heat up. The
If the oven is electrically heated, then more than likely, the oven element has failed.
This is located behind a removeable cover at the rear of the oven.
Posted on Feb 21, 2010
I have just installed an Baumatic wall oven mod. no. B605MS.1. The clock has lit but the oven does not actually switch on and heat. Please help. Thank you
The electronic timer/clock must be in the manual mode for the oven to work. Consult your instruction booklet and set to manual. Your oven will then work.
Mar 07, 2011 | Baumatic Ovens
Since a power cut yesterday, our Tecnik 8522 oven has flashing 'A' (Auto) on the clock & the bottom oven does not work. I know I have to reset the time to get te A off but no buttons work on the facia...
If you cannot change it from auto. to manual it doesn't mean you need a new oven. The electronic timer can be by-passed fairly easily by joining the active and oven load wire together..
Feb 10, 2011 | Ovens
The oven tripped the main fuse switch to the house while on and when i restored power the clock on the oven came on but nothing else works no grill, oven, fan or lights ???
you have to set the clock befire anything works .if you have done that its could be that the element has failed and the fault current has damaged any of the contacts in the circuit which can be themostat ,timer contact thermal cut out contacts. failure of the timer contacts would leave nothing working
Aug 04, 2010 | Baumatic B187 Stainless Steel Electric...
Feb 21, 2010 | Baumatic B187 Electric Single Oven
Baumatic oven not heating up
I have the same model steel finish was looking for parts mysel and came across yr dilema... I had that problem before . I always turn left knob to fan.. turn heat to whatever say 200 then click the button with the hand signal and i never touch any other button it alays does the job for me.. i cant cook so never need to touch ant other button ,,,, its a timer issue that stops it heating up swtch it all off at spur or mains start it up again
DamienPJennings@aol.com hope this helps
Jan 13, 2008 | Ovens
What do I do now that the temperature markers have been scrubbed off??
Go to www.baumatic.co.uk then go to their online catalogue. Find your oven model & download the user manual. You will find 2 very clear pictures of the facia. Regards
Jul 16, 2007 | Baumatic B180 Electric Single Oven
Baumatic bt180 oven
assume a fan oven.does fan turn and oven light come on? if so problem is the circular element. if no fan and no oven light, then clock probably needs setting - this will be in instruction book. clocks sometimes go wrong but not often. if clock is faulty, a cheap repair is to bypass the clock so auto function no longer works
Apr 09, 2007 | Baumatic B180 Electric Single Oven
Baumatic B187 Stainless Steel Electric Single Oven Logo
Top Baumatic Ovens Experts
ashburton
Andy Fraser
Andy Fraser
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
