Question about RIM BLACKBERRY TORCH 9800 TOUCH SCREEN DIGITIZER with LENS COVER REPLACE
Camera bb 9800 could not capture the image - RIM BLACKBERRY TORCH 9800 TOUCH SCREEN DIGITIZER with LENS COVER REPLACE
2 Suggested Answers
SOURCE: nokia 5220 camera does not show image
i dont know how to open my nokia 5220 and Iwant to fix the display
Posted on Apr 12, 2009
N73 nokia, i have problem in take of the image capturing , in the image capturing mode doesn't key accept for image capture but it has work for video capturing. so plz help me what i do?
Generally the image capturing button should press 1-3 secs to get a picture.If it doesn't works there might be some hardware problem.But first try to Restore the phone by typing *#7780# and capture.If the problem still persist contact mobile repairing shop. The camera switch may damage .Or at least clean the pcb if you can remove the cover ..Thanks for visiting fixya
Mar 18, 2012 | Nokia N73 Cellular Phone
I need to unlock my bb torch 9800
You can Unlock it simply using the Unlock code,You can get the Unlock code and instructions from here
www.classicunlocking.com
and Unlock it.
Oct 28, 2011 | Orion Gadgets Sync & Charge USB Cable for...
Download jar are invalid
If you are refering to a file with a .jar file extension, which I usually have for my Blackberry phone, I notice that doesn't work for another BB model. The curve takes in .jar but not BB 9700 or BB 9800. If it's a BB phone, then try to update the device using the BB dekstop manager. I hope this helps
Mar 10, 2011 | Cell Phones
My Torch 9800 camera has a black screen, but the icons at the bottom of the screen are there. It will not take pictures and then also tends to freeze.
This is not a solution, but helps to get the camera functional:
1. Push the dots/BB button. Set Autofocus to "Single Shot".
2. Go to Scene Modes, some people recommend selecting "Face Detection", but I find "Auto" also works well.
3. Under Options - Select Select Picture Review to "Off".
My Torch (9800) now at least have a functional camera with reasonable pictures, as long as I hold the camera steady for taking pics.
Jan 17, 2011 | RIM BlackBerry Torch Cell Phone
My mac wont recognize my Fuji Film camera.
Looks like you may need to use a specific application to see the photos on the camera.
Try using Image Capture and iPhoto (for me it worked in Image Capture after changing the iPhoto preferences to always open Image Capture when camera connected - go figure).
Apr 03, 2010 | Fuji FinePix J10 Digital Camera
What do i do
If images cannot be downloaded from the camera to a Macintosh, check the status of the camera and the Macintosh and resolve the problem accordingly.
1) Check the status of the camera and Macintosh.
1. Connect your camera to the Macintosh and turn the camera on.
2. Open the "Applications" folder on the Macintosh HD.
3. Double-click "Image Capture".
* If the "Imaging device not connected" message appears, follow the steps described in [Checking the connection between the camera and PC].
4. Select "Preferences" from the "Image Capture" menu.
5. The procedure for using the Image Capture Preferences window differs depending on the OS version used. Use the correct procedure for your version of Mac OS.
- Mac OS 10.4: Click "General" in the Image Capture Preferences window.
- Mac OS 10.3: Click "Camera" in the Image Capture Preferences window.
- Mac OS 10.2: Simply proceed to the next step.
6. In "Items launched at camera connection", select "FPVBridge" and then click the [OK] button.
* If FPVBridge is not among the displayed items, follow the steps in [Displaying FPVBridge] below.
7. Quit "Image Capture".
If you implement the above procedure up to step 6, FinePix Viewer launches automatically.
* To stop FinePix Viewer from launching automatically, follow the steps in [FinePix Viewer Setup] below.
2) Resolving the problem
1. Plug the USB cable into the camera and Macintosh again.
* If you are using a USB hub, do not connect the camera to the Macintosh via the hub.
1. Select "Other".
2. Click the "Applications" folder.
3. Click the "FinePix Viewer" folder.
4. Select "FPVBridge" and click "Open".
5. Click [OK].
1. Launch FinePix Viewer.
2. Select "Automatic Save Settings" in the Settings menu.
3. Tick the "Auto save images when the camera is connected" checkbox in "Operation Settings When Camera Is Connected".
4. Click [OK] and close the "Automatic Save Settings" window.
5. Exit FinePix Viewer.
6. Turn the camera off and then on again to test whether FinePix Viewer launches automatically.
Apr 28, 2008 | Fuji FinePix S5700 Digital Camera
Why does it take so long to take a picture?
You may be pressing the shutter all the way down at once. This forces the camera to focus, make exposure adjustments, and capture the image all at once. By pressing the shutter button partially to focus, then the rest of the way to capture the image, your camera can process pictures more quickly. If you are taking a picture in Uncompressed Tiff mode, the camera takes longer to process the image. Tiff images create large files and can take approximately 32 seconds to process. If you are trying to capture large, high quality images that you can print, try setting the camera to HyPict mode instead of Tiff mode.
Sep 12, 2005 | Epson PhotoPC 3000Z Digital Camera
NEF Image will not open - Macintosh
RAW NEF images from Nikon cameras are proprietary formatted raw data directly from the cameras's sensor. If the images are improperly transferred to the computer they will not be able to be opened and will give an "Unsupported File Format" warning. Macintosh OS X has an "Image Capture" application (found in: Hard Drive/Applications/)that can be used to transfer images. If "Image Capture" is used NEF files will be corrupted and will not be able to be read. Only Nikon View, or manually dragging images from the mounted card, should be used to transfer NEF's. To disable "Image Capture": Double-click to open the hard drive and then the "Applications" folder Double-click "Image Capture" From the "Image Capture" menu choose "Preferences..." In the "When a camera is connected" pop-up choose "No Application" Close the Preferences window and Quit Image Capture After disabling Image Capture, it will not launch when the camera is connected and you can use Nikon View to properly transfer NEF images.
Aug 30, 2005 | Nikon Coolpix 5000 Digital Camera
Aug 30, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
RIM BLACKBERRY TORCH 9800 TOUCH SCREEN DIGITIZER with LENS COVER REPLACE Logo
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
