PC Motherboard Acer 671M01-8KSH Intel Socket 775 ATX Computer Mainboard
SOURCE: Gateway Intel 850 Socket 478 ATX Motherboard
http://support.gateway.com/s/MOTHERBD/INTEL/2515762/8508314.pdf
I found the pdf file(manual) for this motherboard kinda by accident but hopefully this could help someone else out. : )
Posted on Sep 26, 2008
mdsaeed67
  • 849 Answers
SOURCE: ASUS P5Q3 LGA 775 Intel P45 ATX Intel Motherboard
ALTHOUGH THE PINS WERE SAME BUT THE MODULE ARE NOT COMPATIBLE WITH EACH OTHER.
Posted on Nov 22, 2008
gotgeek2
  • 565 Answers
SOURCE: my asus p5gc-mx motherboard sound driver cd is missing
Killer rig :-) Do you have it connected Raid 0? Yes, here ya go:
http://support.asus.com/download/download.aspx?SLanguage=en-us
This is for XP. If XP is not your OS, then select your OS.
Posted on Jan 27, 2009
ProsunPal
  • 60 Answers
SOURCE: Intel D915GAG Socket 775... vga driver finding problom
Can you explain this a little more ?
Posted on Feb 14, 2009
p4prince2par
  • 285 Answers
SOURCE: FOXCONN 915M07-G-8EKRS Socket 775 Pentium 4 915G Express + ICH6R microATX Motherboard- R... (FOX915M07G8EKRS): how can i fix my pc problem i have a socket 7...
check power supply unit
Posted on May 19, 2010
Gigabyte GA-G41M-ES2H LGA 775 Intel G41 HDMI Micro ATX Intel Motherboard
Hello here is the homepage:
http://www.gigabyte.com/products/product-page.aspx?pid=3468#ov
A new hdmi connector, can be ordered by a gigabyte dealer.
But changing the connector, is not a do it your self job.
I suggest you to buy a graphic card, to add on the mainboard in the
1 x PCI Express x16 (orange slot) for better performance.
A new graphic card, does also have the hdmi connector
This will be the cheapest way to repair it.
Good luck
Feb 09, 2013 | Gigabyte GA-G41M-ES2H LGA 775 Intel G41...
Black out busted capacitor need repacement
http://www.msi.com/product/mb/848P%20Neo2-V.html#/?div=Driver&os=Vista%2064
It does not pay, to let the caps be changed.
This will exeed the cost, for a new mainboard.
Good luck
Jan 13, 2013 | MSI 848P Neo2V Intel 848P Socket 775 ATX...
Ms 7529
Hello here are the supported cpu list for your mainboard:
http://www.msi.com/product/mb/G31M3-F-V2--3-Audio-Ports-.html#/?div=CPUSupport
You maybe have to upgrade the bios to support the new cpu.
May 25, 2012 | Intel Motherboard
945gz laeport gz motherboard want vga and lan driver
Hi, you can download the drrivers here:
http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=78
Please unzip the file before installation.
There is also another version of your mainboard:
http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=79
Sep 04, 2011 | Biostar motherboard I945GZ-M775 Socket 775...
Where to get replacement motherboard for Gateway 507GR Intel E210882 LGA 775 GW149671509FC00124
I think a micro atx socket 775 motherboard would work here if you wanted to retain the original CPU
You may have to sort out some wiring though..
For an original board, best off trying ebay
Jan 27, 2011 | Gateway 507GR PC Desktop
What is the fastest chip I can use in a aCER TI60-US321H
The best way of knowing for sure is to find the Socket that your computer mainboard uses. The socket information can be found either on the CPU socket or written on the mainboard nearby. Acer normally uses Intel. Therefore could be either, Socket 478, 775. I think it will be 775 as 478 is a bit old.
If it says Core 2 Duo then you know for certain that it is Socket 775. I think 3.2GHz or there abouts is the max it goes to.
Just a thought, instead of upgrading, sell your PC and then buy another one. I myself would go for either an Intel i3/i5 or an AMD Phenom 2 X2 560 or 565.
All the best!
damnor01
Dec 21, 2010 | Acer Aspire T160-US321H (AST160-U-S321H)...
Dear Sir, my mother board d101 has been damaged can i use of p4sd m/b insted of that while i want all rest parts remain using i dont want change ram,SMPS, Proccesser etc.
fbhushan, the Intel D101GGC motherboard (Grand Country) supports;
1) Intel Pentium 4, Intel Celeron D, and Intel Pentium D processors that fit in an
> LGA 775 processor socket.
http://en.wikipedia.org/wiki/LGA_775
The Processor has the socket holes, and the processor socket (LGA 775) has the pins.
775 socket holes, and 775 pins.
The Front Side Bus (FSB) can be either 533MegaHertz, or 800MHz.
2) Supports DDR Sdram ram memory at either 333MegaHertz or 400MHz.
(PC2700 and PC3200, respectively)
Will support Up To 2GB of ram memory.
Has two ram memory slots. The maximum amount for EACH slot is 1GB
3) The SMPS used for it has,
A) One 24-pin ATX main power cable
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
B) One 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
The Intel D101GGC motherboard has Four SATA headers (Connectors) on it, so I'm going to assume you are using a SATA harddrive.
This would mean the SMPS you are using should have at least one SATA power cable.
It should also have an assortment of 4-pin standard Peripheral power cables.
(Misnomered as 'Molex')
The Asus P4SD (Motherboard chipset Intel 865PE) supports;
1) Intel Pentium 4 and Intel Celeron processors that fit in a > Socket 478 processor socket
http://en.wikipedia.org/wiki/Socket_478
The Processor has the pins, and the processor socket has the socket holes.
478 pins, and 478 socket holes.
Your Processor will NOT work.
The Ram Memory WILL work.
The SMPS MAY work.
I state MAY because the Asus P4SD motherboard uses a 20-pin ATX main power cable.
If the last four pins of the 24-pin ATX main power cable that you have on your SMPS right now, Do Not remove, you can Carefully cut them off. Wrap them up, and out of the way.
If you need guidance on this I can help instruct you.
You need an IDE (PATA) harddrive, or a SATA adapter card to use a SATA harddrive.
So there you have it sir.
Regards,
joecoolvette
Nov 22, 2010 | Intel D101GGC Motherboard
Models of motherboard with socket 775
To many to name but here are a few.
Asus P5Q Pro Turbo Intel P45 Socket 775 Motherboard - Socket 775, ATX, Audio, Video, PCI Express 2.0, USB 2.0, RAID
Biostar G41-M7 Motherboard - Socket 775, Intel G41, MicroATX, DDR2, PCIe, USB 2.0
EVGA nForce 750i SLI Motherboard -NVIDIA nForce 750i, 45nm Support, Socket 775, ATX, PCI Express 2.0, SLI Ready, Gigabit LA, USB 2.0, Serial ATA, RAID
Jun 01, 2010 | ASUS Maximus Formula Motherboard - 45nm...
I need a motherboard that can use the same case and everything els as the p4vmm2 My case is the ATX with Intel celeron 2,4GHz
you can use any ATX mainboard into an ATX case, they are universal. Your cpu will only fit boards with the same cpu footprint so you need to know what socket your cpu is.. lga775 is most common now. I would advise a Gigabyte EP45-UD3LR board. Excellent board and well worth the outlay.. no issues with windows xp or vista and you can expand drives and ram as you wish..
Nov 02, 2009 | EliteGroup P4VMM2 Motherboard
Computers & Internet Logo
167 people viewed this question
David Payne
David Payne
