TCL 29 i have TCL 29" tv. in morning it works fine for 30 minutes then it goes to standby mode(as if turned of by remote), then immediately after again turning it on it works fine for 15 minutes and same standby mode, then again after turning it on it works for 5 minutes, then the cycle continues 5 minutes on and standby. i have opend it up looked for visible capacitor problems but all are perfect. even i changed the main big two line capicitors. but same problem. what can be the prblem. i have given the tv to service center 1 year ago for the power supply problem and those people charged me 2500rs for repairing it. they authorised people just drain our money. so i have decided to repair it myself. just tell me the IC no or some cap. or some tranisistro no and i willl change it.. again one important thing i have a same tv at my uncles house and both bought on the same date. and both have the same problem. please help me out. thanks i m dhaval. plesae give me ur no so i can say u thanks.
  • Anonymous Jun 21, 2008
    My 29" TCL full flat is showing zoom and single horizontal line. I have changed the pre set for and capacitors in vertical section, but the symptom is not solved. The zoom symptom I checked the 2 kv capactor but no effect. Please give me suggestion to solve the problems
SOURCE: demo mode wont shut off
some friends of ours has this problem also. I've been trying to find a solution over the internet for a few hours now. I came across one page that said to hold the menu button on the front of the tv in for 20 seconds and that should fix it. guess we'll see.
Posted on Jun 10, 2007
  • 179 Answers
SOURCE: Sony KV34XBR800 Won't Turn On
a technician can get the complete D circuit board from pts rebuilders ( for about 152.00 ..the labor depend on the technician you use for the job the part number is
A-1300-319-A...when pts rebuilds a board the put in any upgrades the manufacture recommends it is a good service..
Posted on Nov 29, 2007
Testimonial: "Thanks"
SOURCE: Sony TV not turning on!
u need to change the lamp...same thing happened to me then i bought a lamp on ebay for $75n replaced it n now it works fine
Posted on May 29, 2009
  • 6 Answers
SOURCE: My Magnavox plasma screen tv, model number:
You either have a cold solder joint in your horizontal deflection circuits or your or in your horizontal output circuit. please be careful due to the fly-back transformer still holds power even unplugged until you discharge it.( ground it out). Hope this helps.
Posted on Jan 03, 2010
SOURCE: Name of TV Philips Power vision Type No
power suplly voltag is binking
Posted on Jan 14, 2010
My 39 inch tcl led TV power cord got abrubtly unplugged while watching TV. Plugged it back in and now the TCL logo on the start up screen stays there frozen. Many times already tried to unplug it, wai
Unplug the tv and hold the on/off switch on the tv (not remote) for 30 seconds. This should clear any power left in your electronic boards. Then plug it back in and try again.
Sep 14, 2014 | TCL LE39FHDF3300 39" LED TV 1920x1080, 60...
My matsui tv 28WNO5(A) will not turn on from standby
Try pressing the small reset button on the back, it works, and you will not loose any stored information which caused the unit to go in the stand by mode.
Have you tried turning it off for an hour and then turning it back on. This happens to me quite often and leaving it off for a while ususally allows it to come back on. Also have you tried to press the TV/AV button on the remote as sometimes it switches to TV mode when its on standby and then standby won't work as its on TV mode and needs to go back on to AV mode. Basically just press the AV button on the digibox remote and then try standby.
if the batteries are removed and left for about 20 minutes before being replaced again, everything works as it should.
if any of the above suggestions does not work then you have to open the unit and on the main board of the tv there is a thin mini tube light like component called fuse you will have to replace that fuse .the fuse is very very cheap and you can easily get it at any electronics shop.and if still the unit does not work then there is a major fault in the power supply board and should be taken to the service center for diagnosing the fault that it is repairable or not.but i hope the above information provided will definately help you to solve your problem.
Oct 04, 2008 | Sony KV-32XBR85 TV
Acoustic solutions lcd37761f1080p
The electrolitic capacitors are trickery: sometimes they look like fine but its capacitance has gone. The actual test is to replace them if you have not a capacitance meter to test them. Another approach is to check the Dual Schottky diode for leakage. It looks like insulated transistor and is screwed on a heatsink.
Sep 21, 2013 | Televison & Video
Issue with Samsung LE32B450. After the TV has been on for about 5 minutes, when you change channel the screen goes blank and the sound goes off. However, the TV is still on as pressing the power but
Just do a hard reset to this set and check. Unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so. This must make it a hard reset.
Jan 12, 2013 | Samsung LE32B450 32 in. LCD TV
TCL tv only turns on in afternoon
The on timer is most likely set resetting factory defaults will not deactivate the timer that has to be done manually
Mar 31, 2012 | Televison & Video
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
Pioneer 53
Unplug the TV for maybe 10 minutes, then turn it on. Sometimes these units simply need to recycle. If that doesn't work, you've likely got serious problems.
Apr 11, 2017 | Pioneer SD-533HD5 53" Rear Projection HDTV
Tv tcl-14175 no sound on channels but ok on audio video mode
The first problem was always standby mode.... get back the original eprom IC 24CO8WP in to the PCB, then find the original remote control of you TCL Tv tcl-14175 then you power On In the Remote control while your TV is in Standby mode! then you see your tv is going ON... Because your unit is in Child lock Mode....
Nov 21, 2008 | Samsung DLP HL-P5663W 56" TV
Sony Trinitron KV-28WS3U Dies
B+ over current protection (OCP), unit goes to the standby mode. Could be a short in the power supply of any of the circuits.
Nov 05, 2006 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Televison & Video Logo
272 people viewed this question
Top Televison & Video Experts
