Question about Toyota Vehicle Parts & Accessories
What does the tvss light being on means as car wont start
95 pathfinder starts when cold drives for a while fine, turn off ,wont restart,let it sit for a couple hours will restart.
If you mean it wont turn over after driven then the starter is going bad.if you mean it turns over fine but wont start it is something else.is the check engine light on?if so get the codes pulled.
Aug 05, 2017 | Cars & Trucks
1999 dodge caravan's light is on, but car won't start. What is the problem?
Would be glad to try to help you resolve your no start issue....but in order to accurately point you in the right direction more input information is needed. when you say the light is on- which light do you mean? When you say it wont start....do you mean it wont crank over or do you mean it cranks over but will not start and run. Also need to know what the is displacement size of the motor in your van? If your motor is cranking over and it will not start we can proceed from there....
Jul 28, 2014 | 1999 Dodge Grand Caravan
Gauges go crazy
battery terminals dirty (no maintenance on car?)
start at the head lights. they are hot all the time.
if the head lights fail , fix that first. (easier).
not sure what crazy means.
and 1st is to check all fuses, in cab and under hood.
Sep 08, 2013 | Suzuki Cars & Trucks
Coil light stopped working engine wont start
by 'coil light' do you mean the glow plug light? is your car diesel? do you mean the yellow light that looks like a spring?usually if it doesnt come on or stays on there is a problem with one or more of the glow/heater plugs. If you can access them check with a voltmeter that you have power supply to them all
May 12, 2012 | Cars & Trucks
Should security light keep blinking
If the car wont start means that is not recognizing the key, if the car start and the light keep blinking means that somebody service the car and did not close the immobilizer ecu properly.
Dec 19, 2010 | 2005 Toyota Corolla
Battery light and brake light were on, card wont
Nissan truns the brake and battery light on when there is a charging issue. When you say it wont start does that means it craks or no? If it does not crank I would attempt to charge the battery then try to start it and check the charging system.
Feb 18, 2010 | 1996 Nissan Maxima
Programming tvss in T Avensis'98 to lock power lock automatically
i have a toyota avensis the alarm doesnt soud when you activate it and how do i fix my central locking i press the lock o the key but it only falshes and when i go to lock the door only the driverside lock all the others stay unlocked
Apr 26, 2009 | Toyota Vehicle Parts & Accessories
Mercedes c220 wont start
Hi
Did you mean oil light ?
If so.... have you checked your engine oil level ?
If this is a diesel, perhaps you mean the cold start glow plugs light ?
If this light does not go out, the problem is in this department, normally fuse or the relay.
If it is really cold, this is why the engine will not start, as the glow plugs are not functioning.
Good Luck !
Don´t forget to give me a FixYa rating, almost a Guru !
John.
Feb 05, 2009 | 2002 Mercedes-Benz C-Class
Wont start
Have the battery tested. Just because the lights come on does not mean that the battery has enough cranking amps to turn the engine over.
Sep 01, 2008 | 1996 Toyota Camry
Vehicle Parts & Accessories Logo
19 people viewed this question
Top Toyota Vehicle Parts & Accessories Experts
Randy Ohler
ashburton
Colin Stickland
Colin Stickland
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
