Question about Zanussi TD4112W Electric Dryer
I have a zanussi td4112w dryer was no heat so got new thermostat but don't know how to replace it can u help
dniro592006
  • 121 Answers
SOURCE: reset button
your heating element may have burned out
Posted on Jun 18, 2009
dragonsthatk
  • 547 Answers
SOURCE: zanussi td4112w drum stopped spinning
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Posted on Jun 19, 2009
SOURCE: td4112 which way does belt fit around drive and
check the drive it should have grooves on it. that means that the belt grooves should go around the drive and facing the drum. When you see the belt on the drum you should not see the grooves on the belt
Posted on Jan 11, 2010
apart4u
  • 213 Answers
SOURCE: just bought 2nd hand a supposedly good working
this could be the stats or the drum is not turning Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Posted on Jan 13, 2010
heatman101
  • 43501 Answers
SOURCE: i have a zanussi td4112w. My washing takes nearly
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Posted on Oct 17, 2010
I keep asking but dont get answers help please
There is a video here on how to replace a belt on a dryer. I have done this before and most dryers are the same. You have to take them apart. It is not a real easy job. Hope this helps. Scroll down to the bottom of page to see video.
http://www.espares.co.uk/part/tumble-dryers/zanussi/td4112w/p/1088/332/0/553236/501196/tumble-dryer-drive-belt.html
Dec 02, 2011 | Zanussi TD4112W Electric Dryer
I have a Zanussi TD4112W dryer and it works fine apart from the fact that only half of the element heats, I have checked there thermostats and they seem fine 2/3 ohm at cold and o/c at high temp. Also the...
sounds like you know what you are looking for, here is a website that may help you, Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Oct 30, 2010 | Zanussi TD4112W Electric Dryer
I have a zanussi td4112w. My washing takes nearly double of time to dry as it used to. What should i do?
heatman101
Oct 17, 2010 | Zanussi TD4112W Electric Dryer
No heat drum turns on td4212w
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 28, 2010 | Zanussi TD4112W Electric Dryer
Just bought 2nd hand a supposedly good working order zanussi tumble dryer got it home turned it on drum turning but cold air in dryer. we then noticed that the back got rather hot.and then nothing. due to...
Jan 10, 2010 | Zanussi TD4112W Electric Dryer
Td4112 which way does belt fit around drive and
Dec 31, 2009 | Zanussi TD4112W Electric Dryer
Cold air
It seems that it is more likely a Burned Out Heating Element.
Check and let me know if the problem still persists.
Hope i helped you.
Thanks for using " Fixya " and have a nice day!!
Jul 11, 2009 | Zanussi TD4112W Electric Dryer
Zanussi td4112w drum stopped spinning
Jun 19, 2009 | Zanussi TD4112W Electric Dryer
Reset button
Jun 17, 2009 | Zanussi TD4112W Electric Dryer
Zanussi TD 4112 W Not warming up
I've taken the back cover offf the dryer and found a burnt connection to the heating element. Will try and repair.
Oct 14, 2008 | Zanussi TD4112W Electric Dryer
Zanussi TD4112W Electric Dryer Logo
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
