Question about Proform 315 Csx Recumbent Bike
Lose resistance when we start peddling after about 4 or 5 seconds and then it won't reset. we have tried shutting it off and then restarting it but that doesn't work
My screen freezes up? It happens every day.
Have you tried a complete reset? It has fixed my problems. Hold the power button down for at least ten seconds an the restart. Or got to the menu an click on reset to original. You won't lose any info just a restart.
Mar 21, 2015 | Kindle Fire HD 8.9" 32GB, 4G Wifi
Engine will not restart on first 4 tries after engine becomes warm . starts on first try, first thing in the morning when engine is cold
Choke is engaged in morning and makes car start real easy. If the choke sticks slightly closed after shutting down the engine and you go to restart it, you'll flood the engine. Could test this theory by trying to start car after it has warmed up, but when you attempt the start, hold the gas peddle to the floor as you start it. If it starts faster then usual, I would check the float levels or choke flap adjustment. Maybe take air cleaner top off and after warmed up, look to see if that choke flap is completely open when you restart the car.
Sep 07, 2013 | 1992 - 1999 GMC C1500 Engine Coolant...
My reader won't turn back on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 07, 2012 | Sony Reader Pocket PRS-300
My 1988 dodge Dakota 3.9 3 speed automatic 2 w Dr.idles rough and sometimes dies at a stop light and won't restart unless I put the gassed peddle to the floor.when it does finally start I have to keep...
Replace your hose going from intake to brake booster ( vacuum leak) check all other hoses also. Clean the throttle body. And a tune up probably wont hurt either.
Jun 09, 2017 | Cars & Trucks
I have a toshiba satellite x205-s9349. It won't boot at all, no beep codes or screen. The fans start and the hard drive lights go on for a bout 4 seconds and then the fans turn off and nothing....
Try this
unplug plug the power cord and remove the battery and hold the power button for 45 seconds,Then reinstall the battery and and try to start the computer,
if it fails to start
unplug plug the power cord and remove the battery and hold the power button for 45 seconds and
remove the memory and any usb devices that may be plugged in,then start it,
If it starts
Allow it to load completely and then shut it down and install one memory stick and restart, if all is well after if loads completely, shut down again and install the other memory stick and restart, if all is well again wait until it loads completely and then plug in and allow to load each of the usb devices you may have
Jun 29, 2011 | Toshiba Satellite X205-S9349 Notebook
On my 2004 duramax LLY the change engine oil light will not reset. The dealer has tried to reset normal way by pressing peddle 3 times and also put computer on truck and it will not reset. Any ideas?
Try this: turn key to on, do not start. Press pedal about 5 or 6 times in 5 seconds all the way to the floor. Start vehicle and then drive it. Seems some won't reset just sitting there. Shut vehicle off. then see if it resets.. Good luck.. 50/50 chance this will clear it.
Mar 04, 2011 | Chevrolet Silverado 3500HD Cars & Trucks
Car starts for two seconds shuts down trys to restart three times with same results
code program wire (pink) was left unpluged after programing code.At restart it would lose code. Reset code pluged in wire,runs fine
Feb 06, 2010 | Viper Security and Remote Start System...
Hey if i change oil in my gmc will the service engine lite go off
The service engine light will not go off. The Oil life monitor is serperate from the SES light. You can reset the oil life system if that's the light you are talking about. Turn the key on, engine not running. Push the gas peddle to the floor and back up to the top 4 times on the 4th time hold it down. Watch the light it will start to flash, once it stops shut the key off for 10 seconds and restart the truck. If it comes back on try it again until it goes out.
Oct 11, 2009 | 2002 GMC Envoy
WHAT IS THE RESET BUTTON ON THE BOTTOM SIDE OF MY COMPAQ PRESARIO 2500 SPECIFICLY DO. IN OTHER WORDS IF I PUSH IT WILL I LOSE ALL MY STORED INFORMATION ON THE DRIVE?
This is straight from the manual:
Occasionally, Windows or the notebook might stop responding, so that you cannot turn the notebook off. If this happens, try the following in the order listed. Press the power button to restart.
• If possible, shut down Windows: press ctrl+alt+del, and then select Shut Down > Restart.
If the system will not allow a software shutdown, press and hold down the power button until the display shuts down (about 4 seconds) and then release the power button. Press the power button again to restart.
• Use a ballpoint pen or a straightened paper clip to press the reset button on the bottom of the notebook.
In other words: You will not loose any saved data if you reboot your laptop this way. All unstored information (open documents etc.) might be lost though.
Dec 20, 2008 | Computers & Internet
Proform 315 Csx Recumbent Bike Logo
47 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
