Question about Emerson Televison & Video
Emerson lc370em2 vesa mount screw size needed
I can't seem to find the correct wall mount screw size. I bought it used and works well but wanted to mount it on the wall.
  • 92 Answers
SOURCE: what size screw for holes on back of set
go to this size to figure out the screw size. http://www.tvwallmountguide.net/
Posted on Jun 18, 2009
  • 3 Answers
SOURCE: Tv didnt come with screws....
The size is #8-40 X 3/4". This is a specialty screw, so you're screwed
Posted on Dec 13, 2009
budmrtn
  • 11361 Answers
SOURCE: LG 42" wall mount screw size
Metric M5 or M6, when you buy wall mounting bracket, it will came with a bag of screws for attaching the TV to the bracket. All my wall mounting brackets for my TV come with screw.
http://s807.photobucket.com/home/budm/allalbums
Posted on Jul 01, 2010
Testimonial: "Thank you! We'll head to Lowe's tomorrow to pick up the appropriate size screws. We just moved into a new home and they left the wall mount up for us, but did not leave any of the extra screws that went with the mount. Thanks again! "
SOURCE: VESA Screws
I went to Lowes and found some 4mm .7 screws, 25mm long, and they worked like a champ. (get the lock washers too)
Apparently, most mounts include only 5mm and larger screws
Posted on Oct 08, 2010
SOURCE: Can't find screw size to
M8 - according to a document I found online for a Toshiba mounting bracket kit for their LCD TVs the bolt size is M8. It should be easily available in a large hardware store or place that sells large flat screens.
Make sure you hand tighten it into the mounting hole before attaching any brackets, to judge the proper depth for tightening. Over-tightening with a long bolt could damage the TV.
Posted on Jan 14, 2011
Can you tell me what size screws I need to mount my Toshiba Model 46G310U on a wall?
M6 or M8
http://support.toshiba.com/support/search?s_query=mounting+bolts
User Manual
Page 6
... stand. 3) Once you have removed all four screws holding the pedestal stand in place, remove the pedestal stand ..., level, stable surface that can support the weight of the surface. Four screws Hook Sturdy strap (as short as possible) 46 / 55" TV VESA Mounting Pattern 32" TV VESA Mounting Pattern Four screws Hook Sturdy strap (as short as possible) Four screws Hook Sturdy strap (as short as a quilt or blanket. Make ...) 200x200 mm 200x200 mm 400x200 mm 400x200 mm Screw Size M6 M6 M8 M8 (unit in mm) 40" TV VESA Mounting Pattern Removing the Pedestal Stand 1) Carefully lay the front ...
Toshiba 46G310U Mounting Screws
Sep 24, 2017 | Televison & Video
How do I install a tv on my wall
First of all find out what size mount is on the TV. On the back of the TV you should see 4 screw holes to take the bolts of the stand. You can measure the space between the holes. Then you can search for a mount that will take that size. If the TV is big you will need a very strong wall mount.
When you get the mount it should have instructions for mounting it. But make certain the wall you are fixing it to can take the weight and is stable. Fix the mount to the wall, make certain that you use the correct screws and plugs for the screws. You should be able to tell if the mount is secure enough. If you have any doubts, get somebody in to do it. The mount will come with the correct fixing screws for the TV. You will need two people at least to fix a smaller TV to the wall and two people to hold a big TV while a third screws the mount to the TV.
Feb 10, 2017 | Televison & Video
CAN I GET SCREW HOLE SIZE OF BACK OF TV FOR WALL MOUNT
The 3 most common sizes for the bolts to mount the wall mount to the TV is either M8x20mm or M6x20mm or M4x20 depends on the size of the screen. This site has a chart that will show you what to look for, for your TV M6x20mm TV to Wall Mount Bracket Phillips Bolts Screws Stainless VESA 200
Aug 23, 2015 | Panasonic Viera TC-32LX85
What size screws do I need to mount my Polaroid model no. Tlac 02255 to a wall bracket?
Dear Billy,
It is very difficult to determine what size screw for the TV bracket.
  • If you bought a wall bracket, it will definitely have different sizes of screws in it.
  • Follow the installation guide for what Size screw to use on the TV. It varies by manufacturers.
  • Get a Universal Bracket.
Good Luck!
JP
Jul 08, 2015 | Polaroid Televison & Video
We want to wall mount thevTV what size screw fits the back of the TV? Sanyo model DP32649
Assuming a modern TV with a square/rectangular arrangement of holes (i.e. VESA mount) - they're M4, length varies.
Appropriate screws will be in the kit with the wall bracket.
Nov 08, 2014 | Televison & Video
What screw/bolt size is it to wall mount?
Contact the authorized dealer for more details about the sizes of hardware. Electro help
Oct 16, 2014 | Televison & Video
Mounting bolts for emerson lc401em2f
I had the same problem, there is documentation on the web or in the manual, total BS and it is not a vesa standard mounting bolt, hang the engineer. Fortunately I work at a shop with bolt inventory to experiment with, you will need four 5/16 x 1 inch us standard. Enjoy!
Jan 25, 2012 | Cars & Trucks
Televison & Video Logo
56 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
