Question about Hotpoint HSS25GFP Side by Side Refrigerator
Have a hotpoint model CSX22GRSA side by side refridgerator freezer with ice maker and ice keeps forming and stopping the fan. It also has ice down the back corner of the freezer. What could be causi
It has been doing this every now and then for awhile now, but I always just cleaned all the ice off and it worked fine. This time I did that and it iced back up again and stopped the fan. The ice it was making before it did it this time were smaller and some were hollow. Please help me figure this out. Thank you
2 Suggested Answers
FreeTech
  • 426 Answers
SOURCE: Our Hotpoint side by side refridgerator, the ice/water not workin
It sounds like you have a failing relay/valve that wont stay open when current is passed through them, check there first otherwise your control board could have water/heat damage remove inspect and if necessary replace let me know how it goes :)
Posted on Jul 11, 2009
Have a hotpoint CSX22GRSA side by side refridgerator freezer with ice maker and ice keeps forming and stopping the fan. What could be causing this?
I don't think it is defrosting properly, possible defrost element failure, the ice being produced is smaller because of this.
Nov 20, 2013 | Hotpoint HSS25GFP Side by Side...
Hot point side by side, back of the freezer inside by the fan keeps building up ice and freezes up the water tube for the ice maker, it will build up enough to hit fan.
if there's ice on the inside back wall of the freezer you have a defrost problem.i need the model number so i can help you.open the fridge door,look up on the right hand side up near the ceiling and you'll see a tag with the number,if it's older look down near the bottom hindge near the kick plate
Feb 02, 2011 | Hotpoint Refrigerators
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Jul 11, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Refridgerator not cooling
is it side by side or freezer on top/bottom...check to see if the fan inside the freezer is running when the compressor is running..also check to see if ice is covering the evaporator coils.. the freezing should be even with a thin layer of ice/ not partically melted..sometimes the ice forms in the vents and stops the air flow...to review...check and see if fan is working in freezer
check to see if vents are clogged......good luck!!
Apr 29, 2009 | Refrigerators
Aug 18, 2008 | Refrigerators
I REPLACED ICE MAKER UNIT BECAUSE REPAIR MAN TOLD ME THAT THE HUMMINING NOISE WAS DUE TO ICE MAKER BEING STUCK IN A CYCLE. AFTER REPLACEMENT THE NOISE IS STILL THERE. WHEN I SHUT THE ICE MAKER OFF NOISE...
theres ice in the fan propelar, if you see no ice blocking the propellers its the fan motor itself,if you unplug the fridge and stick something thin between the vents where you feel the air blowing thru and try turning the fan,gently and it spins smooth its the fan motor,if you dont wish to do this turn freezer off,open the door and let it defrost,then plug it in if buzz still there its the fan motor
Jul 08, 2008 | Hotpoint Refrigerators
Hotpoint HSS25GFP Side by Side Refrigerator Logo
21 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
