Technosat 9000 ultra
Programe
What is a general password for technosat 5700p
You may try the following list of Master Password codes for your Technosat 5700.
If none of these work please contact me and I'll be happy to provide help!
3724, 2374, 7176, 2606, 1470, 2441, 3724, 1250, 6893, 5400
Mar 07, 2016 | General Cameras
I've a problem. When i switch on the tv. It says no signal. I've thought of turning the satellite but it keeps saying no signal and the signal quality stays at 4%. How to do? Configuration: technosat.
firstly the satellite dish antenna must be correctly aligned to satellite you want to receive.
technosat setup" initial setup" select the correct safelite ,once selected u should see signal strength /quality then tune the channels...auto works best, after this you can create your own favorite channel list
Nov 17, 2013 | Televison & Video
Can't search for channels lost my password
i forget my password for receiver ir 7000 technosat thanks
Jul 31, 2011 | Ugly Dolls 10201 - Uglyworm - Classic -...
I forgot that password my technosat receiver,
i forgot my password for my receiver technosat ir-7000
my email swasety@yahoo.com
Feb 09, 2011 | Ugly Dolls 10201 - Uglyworm - Classic -...
How to solve the problem"*.exe
This error is generally an indication that the written program isn't designed to be run in the 32 bit windows environment, the program is corrupted, or an error occured while trying to run the program. It is generally due to an older program being run within windows.
The newer windows versions are mostly 32 bit platforms. Some of the old programs from windows 95 and 98 eras won't work because they are 16 bit programs. Examples may include older programs with a .com extension (which will bring up this error message), or old versions of .exe's written for 16 bit environments.
If the program you are attempting to run is a recent program (came with your version of windows XP or later) then it could be an error at execution or the program is corrupted. If the program is written by a major brand and is relatively new, contact the program's technical support number for help.
If you suspect a program error, try and obtain another copy of the program. Uninstall the current copy of the program, restart your computer, then install a fresh copy. If the error continues after doing this, then contact the program manufacturer's technical support number.
If the program you are using is one of the programs from within windows, (from the system 32 folder for example, and include notepad.exe, msconfig.exe, or other programs that can be selected and run from within this folder) do NOT remove or copy over the program. Some of the programs within the windows sub-directories are older 16bit programs, not designed to run within the 32bit platform. It is recommended to NOT remove any of these programs from the windows sub directories.
Jan 12, 2011 | Computers & Internet
Software for Sharp XE-A201 Cash Register
You need the PC Link software for your model.
All of these manuals can be downloaded at:
http://the-checkout-tech.com/
sharp ER-1017 Service
sharp ER-1072 Service
sharp ER-1073 Service
sharp ER-1074 Service
sharp ER-1075 Service
sharp ER-1076 User Service
sharp ER-1077 Service Programming
sharp ER-1077
sharp ER-1077
sharp ER-1772 Service
sharp ER-1772s Service
sharp ER-1871 Service
sharp ER-1872 Service
sharp ER-1873 User Service
sharp ER-1875 User Service
sharp ER-1910 User Service
sharp ER-1911 User Service Programming
sharp ER-1911s User Programming
sharp ER-1920 User Service
sharp ER-1921 User(R) Service Programming
sharp ER-1921s Programming
sharp ER-1970 User Service Programming
sharp ER-2000U Service
sharp ER-2100 User Service
sharp ER-2370 Service
sharp ER-2371 User(R) Service Programming(R)
sharp ER-2385 Service
sharp ER-2386 Service
sharp ER-2386s User
sharp ER-2395 Service
sharp ER-2396 Service
sharp ER-2720 Service
sharp ER-2722 Service
sharp ER-2722A User Service
sharp ER-2742 Service
sharp ER-2742A Service
sharp ER-2770 Service
sharp ER-2782 Service
sharp ER-2782A Service
sharp ER-2905 Service
sharp ER-2908 Service
sharp ER-2910 Service Programming
sharp ER-2970 User Service
sharp ER-2975 Service
sharp ER-2980 User Service
sharp ER-2980S Service
sharp ER-3100 User Service Programming
sharp ER-3110 User Service Programming
sharp ER-3115 Service Programming
sharp ER-3120 User Service Programming
sharp ER-3550 Service
sharp ER-3600 User Service
sharp ER-3630 User Service
sharp ER-3712 User Service
sharp ER-3721 Service
sharp ER-3731 Service
sharp ER-3732 User Service
sharp ER-4100 User Service Programming(R)
sharp ER-4110 User Service Programming(R)
sharp ER-4100S Service
sharp ER-4110S Service
sharp ER-4550 Service
sharp ER-4630 User Service
sharp ER-4633 Service
sharp ER-4700 User
sharp ER-6740 Service
sharp ER-8700 Not Available, do you want to swap?
sharp ER-A150 User Service Programming
sharp ER-A160 User Service Programming
sharp ER-A170 User(R) Service Programming
sharp ER-A180 User Service Programming
sharp ER-A220 User Service Programming
sharp ER-A227G Programming
sharp ER-A250 User Service Programming
sharp ER-A310 User Service Programming
sharp ER-A320 User Programming
sharp ER-A330 User Service Programming
sharp ER-A410 User Service Programming
sharp ER-A420 User Service Programming
sharp ER-A430 User Service Programming
sharp ER-A440 User Service Programming
sharp ER-A440S Programming
sharp ER-A450 User Programming
sharp ER-A450S User Service Programming
sharp ER-A450T User Service Programming
sharp ER-A460 User Service Programming
sharp ER-A470 User Service Programming
sharp ER-A490 User(R) Service Programming
sharp ER-A510 User Service Programming
sharp ER-A510s Service
sharp ER-A520 User Service Programming
sharp ER-A530 User Service Programming
sharp ER-A550 User Service Programming
sharp ER-A550s User(R) Service
sharp ER-A570 User Service Programming
sharp ER-A610 User Service Programming
sharp ER-A650 User Service Programming
sharp ER-A650S Programming
sharp ER-A670 Not Available, do you want to swap?
sharp ER-A670S Programming
sharp ER-A750 User Service Programming
sharp ER-A770 User Service Programming
sharp ER-A770II User
sharp ER-A770M User Service
sharp ER-A771 User Service Programming
sharp ER-A850 User
sharp ER-A880 Not Available, do you want to swap?
sharp UP-3300 User Service Programming
sharp UP-3300M Service
sharp UP-3301 User Service Programming
sharp UP-600 User Service Programming
sharp UP-700 User Service Programming
sharp UP-800F User
sharp UP-810F User
sharp UP-820N User Service
sharp UP-X300 User
sharp UP-X500 User Service
sharp XE-A101 User Service Programming
sharp XE-A102 User Programming
sharp XE-A106 User
sharp XE-A110 User Service Programming
sharp XE-A120 User Service Programming
sharp XE-A130 User Service Programming
sharp XE-A201 User Service Programming
sharp XE-A202 User Service Programming
sharp XE-A203 User Programming
sharp XE-A206 User
sharp XE-A20S User Programming
sharp XE-A212 User Service Programming
sharp XE-A213 User Programming
sharp XE-A301 User Service Programming
sharp XE-A302 User Programming
sharp XE-A303 ? Programming
sharp XE-A401 User Programming
sharp XE-A402 User
sharp XE-A406 User
sharp XE-A40S User Programming
sharp XE-A505 User Programming
Dec 30, 2009 | Sharp XE-A402 Electronic Cash Register
How do I uninstall a program from my computer?
follow these easy steps:
1)open my computer
2)click on Add and Remove Programs ,wait till is loaded then select your program that you want to uninstal and click Remove.
Dec 22, 2009 | Dell Dimension 2400 PC Desktop
Roxio Media Manager program installation will not complete. How do I uninstall.
Posted all operatings systems...
In Windows, how do I uninstall programs? Using the Add/Remove Programs control panel The Add/Remove Programs control panel in Windows makes it easier to uninstall programs. Follow the appropriate instructions below to use this control panel.
Windows 7
  1. From the Start menu, select Control Panel.
  2. In Large or Small icon view, click Programs and Features. If you're using Category view, under "Programs", click Uninstall a program.
  3. Select the program you want to remove, and click Uninstall. Alternatively, right-click the program and select Uninstall.
Windows Vista
  2. In Classic View, double-click Programs and Features. If using the Control Panel Home view, under "Programs", click Uninstall a program.
Windows XP in the default XP view
  1. From the Start Menu, select Control Panel.
  2. Click the Add or Remove Programs icon.
  3. Select the program you wish to remove and click Remove.
Windows XP in Classic View and 2000
  1. From the Start menu, select Settings, and then Control Panel.
  2. Double-click the Add/Remove Programs icon.
  3. Select the program you wish to remove and click Add/Remove.
Using the Uninstall program from the Start menu If the program you wish to uninstall is not listed among the installed programs, an uninstall program for that item might be available on the Start menu. To look for such an option:
  1. From the Start menu, select Programs or All Programs.
  2. Find the folder for the program you wish to uninstall and highlight it.
  3. In many cases, on the menu that appears, you will see an uninstall option.
Please let me know how this works out for you...
Thank you
Jon
Aug 12, 2009 | Computers & Internet
 Grubhead
Grubhead
