Question about Toshiba P845t-S4310 Laptop i5 1.7GHz 6GB 750GB DVDRW
Left click not working correctly on Toshiba touchpad
Touchpad not working correctly; hold down left click and press enter is the only way it operates
5 Suggested Answers
  • 566 Answers
SOURCE: Touchpad not funjctioning on Toshiba Satellite L40/45 laptop
You might have inadvertedly disabled the touchpad.
1. Press Fn + F9 to enable the touchpad.
This key combination acts as a switch, enabling or disabling the touchpad: press once to enable (if it is disabled), then press again to disable.
2. If the touchpad still doesn't respond, check the settings in the mouse control utility.
Click on the touchpad icon on the right side of the task bar if you see one or click Start button/Settings/Control Panel, select the Mouse icon and Press Enter.
Change the settings if necessary.
Posted on Aug 17, 2009
  • 125 Answers
SOURCE: Toshiba Satellite P505-S8980 Cannot get
As per my knowleger you have not installed touch pad drivers for your Toshiba Satellite P505-S8980 if you have installed it, try reinstalling it.
Posted on Mar 08, 2011
onyekapaul
  • 122 Answers
SOURCE: my mouse on my satellite
hello friend,
I THINK THE PROBLEM IS FROM THE MOUSE PAD, I THINK IS EITHER YOUR HAND IS WET OR SOME LITTLE WATER POURED ON IT, IF NOT, THEN IT IS DEVELOPING SOME FAULTS THAT I THINK MAY TAKE SOME TIME. PLEASE IF YOU CAN LOOK FOR AN EXTERNAL MOUSE TO USE FOR THE MINE TIME NOW AND AVOID TOUCHING THE MOUSE PAD FOR SOME TIME THEN I THINK IT WILL COME BACK TO NORMAL LATTER.
Posted on Jul 11, 2011
SOURCE: touchpad click buttons sticking
Did you waste some sticky soda on the touchpad. Before you try taking the laptop apart just shut the laptop off and repeatedly hit the buttons to try and work them loose from sticking.
If you want to take the touch pad off, you will have to remove the whole palmrest. Get some cups and label them so you will know where the screws you removed go. Also a digital camera might help you. You will start by turning the power off, removing the power cord and battery. The remove the screws from the bottom of the laptop. Remove the memory, the hard drive, the dvd drive. Look inside each one of them and there might be screws to remove especially in the battery compartment. Make sure you look for screws that might have the icon of a keyboard next to it. They secure the keyboard. Then open the lid and remove the strip that is above the keyboard. Be careful because there might be a cable attached to the strip. One the strip above the keyboard is removed, you can remove the keyboard screws and gently lift the keyboard out because there is definitely a cable under it that you will have to remove from the board where it plugs in. Next you will have to remove the screw from the lcd hinge and lift the lcd off. You should be able to just disconnect the lcd cable and have enough room to sit the lcd right behind the base without taking the wifi antennas off. If not you will need to remove the wifi card and antenna from the bottom of the laptop. Next you can pry the palmrest off, but be careful and remove any cables that are plugged in before you remove it. There might also be some screws that hold the palmrest to the motherboard so check for them.
Posted on May 13, 2012
Touchpad not active
Press the "Fn" and "F9" keys simultaneously.
Test your touchpad. If it works, it was simply disabled. Press the same key combination any time you want to toggle your touchpad on or off.
Plug an external mouse into a USB port on your laptopicon1.png if the key combination didn't work. Follow onscreen prompts to install the mouse driver--if necessary. You can also move the cursor using the "Tab" key and the arrow keys, as well as click by pressing "Enter" until the mouse is operational.
Click the link in the Resources section if you are using a Toshibaicon1.png Satellite with Windows Vista. Follow the onscreen prompts to download and re-install the driver.
Open a web browser and navigate to Synaptics.com if you have a different Toshiba model or operating system. Synaptics brand touchpads are used in all Toshiba laptops, and this site provides a generic driver.Hover your mouse over "Support" on the top menu, then select "Drivers" from the drop-down menu.
Select your operating system from the list provided and download the generic driver
Follow the onscreen prompts to install your new driver, and then test the touchpad again. If it still does not work, take your laptop to a licensed repair technician.
Jan 06, 2014 | Toshiba SATELLITE 1905-S301 TOUCHPAD AND...
My mouse pad doesent work
Locate the function key on your keyboard (F1 through F12) that has an icon of a touchpad. This is often a rectangle with two smaller rectangles below it, representing the touchpad and its two buttons.
Press and hold the "Fn" key, usually found in the lower left area of your keyboard.
Press the touchpad function key and then release both keys.
If this does not enable your touchpad, try holding the "Fn" key down and pressing the touchpad function key twice in a row.
Shortcut Key Method
Press the Windows icon key on your keyboard and hold it down until the Start menu pops up. If your keyboard doesn't have a Windows icon, press "Ctrl-Esc" at the same time.
Use your arrow keys to locate the Control Panel and press "Enter."
Navigate to "Mouse" with your arrow keys and press "Enter" to open the mouse control dialog box. Then, press "Alt-F" together to access the tabs at the top of this box.
Navigate using the arrow keys to "Device Settings" or "Touchpad" or the similar option on your system and press "Enter."
Press the "Tab" key until the "Enable" option or a check box next to it highlights and then press "Enter." Press "Tab" again until you are highlighting "OK," and press "Enter."
Your touchpad will be re-enabled.
hope this helps
Nov 28, 2012 | Acer Aspire 7741Z-5731
How to open unlock mouse pad
Click the Windows "Start" button in the bottom-left corner of your desktop.
Scroll up and click "Control Panel."
Choose the "Mouse" icon or type "Mouse" in the field in the upper-right corner.
Click the "Enter" button and then click the "Mouse" link.
Press the "Hardware" tab or the tab to the right of it that specifies the type of touch pad you have.
If you are under the "Hardware" tab, highlight the touch pad in the list of devices and click the "Enable" button.
If you are under the touch pad tab, click the enable button.
Click the "Apply" button and then click the "OK" button
or
Press the touchpad function key and then release both keys. If this does not enable your touchpad, try holding the "Fn" key down and pressing the touchpad function key twice in a row.
Shortcut Key Method
Press the "Tab" key until the "Enable" option or a check box next to it highlights and then press "Enter." Press "Tab" again until you are highlighting "OK," and press "Enter." Your touchpad will be re-enabled.
hope this helps
Sep 22, 2012 | Computers & Internet
The up and down scroll of the touchpad on my acer aspire 5630 with windows vista is not working
Click Start/Control Panel andlook for the Mouse and open it to check the mouse properties. Make sureyou don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on thebutton that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upperleft hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press andHold the ALT or FN function key located at the lower left portion of thekeyboard, then hit the key that toggles the touchpad. The correct key tohit will have the icon of a finger pointing at a square that represents thetouchpad.
Download and reinstall the touch pad drivers.Get online and got towww.google.com In the google search box type: "Dell Support"(without the quotes and put your manufacturer name before Support). Lookfor downloads and drivers. Enter your model number and operating system whenrequested. Download and install the Touchpad drivers.
May 29, 2012 | Acer Aspire 5600 Series 5630-6951 Laptop
Set touch pad to function
May 24, 2012 | Toshiba Computers & Internet
Touch pad set up
Click Start/Control Panel and look for the Mouse and open it to check the mouse properties. Make sure you don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on the button that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upper left hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press and Hold the ALT or FN function key located at the lower left portion of the keyboard, then hit the key that toggles the touchpad. The correct key to hit will have the icon of a finger pointing at a square that represents the touchpad.
Get online and got to www.google.com In the google search box type: "Dell Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Touchpad drivers.
How do I unlock
Are you into Windows and see your desktop icon when this happens?
If so you might have your touchpad toggled off.
May 15, 2012 | Toshiba Computers & Internet
Touchpad won't work
What's wrong with the touchpad? Rather than fix it if it is broken just replace it. In fact you can replace the whole palmrest which includes the touchpad that does not cost a lot.
Maybe you turned the touch pad off.
Maybe you just need to reinstall the touchpad drivers.
Get online and got to www.google.com In the google search box type: "Acer Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Touchpad drivers.
May 13, 2012 | Toshiba Satellite M65-S9092 PC Notebook
Toshiba satellite l505 mouse/click pad stopped working. Does not respond always. Either gets
Maybe you pressed the button to lock the touchpad. On some models there is a button located at the top of the touchpad in the middle that toggles the touchpad/mouse on or off.
On other models you have to tap twice in the upper left hand corner of the touchpad to toggle it on or off.
Some models you have to Press and Hold the ALT or FN key then hit the key that toggles the touchpad. Normally the key that toggles the touchpad will have the icon of a finger pointing at a square which represents the touch pad.
If all fails you can always download and reinstall the touchpad drivers.
Get onlineand got to www.google.com In the google search box type: "ToshibaSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the drivers.
Apr 26, 2012 | Toshiba Computers & Internet
Aug 17, 2009 | Toshiba Computers & Internet
Toshiba P845t-S4310 Laptop i5 1.7GHz 6GB 750GB DVDRW Logo
42 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
