Question about Dell Inspiron 8600 Notebook
Dell Inspiron1410 running 50% CPU usage with no other processes running in background. This after a nice repair install of Windows XP professional. High fan noise and heating up! Thanks
Dell Inspiron1410 running 50% CPU usage with no other processes running in background as indicated by the task manager. This after a nice repair install of Windows XP professional. High fan noise and heating up! Thanks
    New Friend:
  • 31 Answers
Hello Saman Tarik,
Task manager may say there are no other processes running but if you look in the next tab, "Services" you will find there are many things running.
The processor will run at a lower percentage when it is not busy.
As for running hot, I would suggest that the heat sink fins need cleaning out, I was surprised at how much fluff had accumulated in them, preventing a good air flow.
I have upgraded my processor from 1.5Ghz to 2.5Ghz which runs hotter so I bought a ZALMAN ZM-NC1500 USB and the hottest my CPU has reached is 41 degrees when both cores are running at 100%.
I hope the above information is of use to you.
Kind regards,
Ron.
Posted on Jun 16, 2014
amusedgeek
  • 787 Answers
SOURCE: Dell Dimension 8250 PC running Windows XP has CPU always at 100%
The cache is nothing more than a file on the hard drive, if it is missing Windows automatically creates it. If it was corrupt, formatting would have gotten rid of it. Try booting in safe mode (and afterwards safe mode with networking) to see if you have the same problem. This could also be a hardware issue, remove any cards that have been added (including video, I assume it has an onboard chip) and see if it helps. If any of this helps, it gives us the info to fixed it permanently.
Posted on Jan 03, 2009
  • 6 Answers
SOURCE: Laptop Mousepad and Keyboard stuttering, slow
Whenever that happens to me, at least to the mouse pad I restart my laptop and it fixes it...
If not then perhaps it's a hardware or software problem, maybe you could reinstall XP over again, or you could, as a last resort crack it open and see what's goin' on inside or have someone check it out for you (I wouldn't go that far though).
Posted on Jan 30, 2009
NitrusInc
  • 326 Answers
SOURCE: Slow performance after fresh XP install
There are many options you can choose to increase the performance of your machine.
You can increase your virtual memory settings. To do this follow these steps:
Press and hold the Windows Logo Key + press "pause break" key to access System Properties, note the amount of RAM it states before continuing, you will need it for a calculation. (xxxmb)
Select Advanced Tab > Under Performance click Settings > Click Advanced Tab > Under virtual memory click Change button >
Set the Minimum and Maximum to a number 1.5 times the physical amount of RAM that you have. (Providing you have less than 512mb. 2.5x for 1gb or greater.) Hit set, Hit apply.
Before restarting, you may want to consider reducing some of the Visual Effects of XP to gain some resources back.
Manually un-check the boxes listed on the Visual Effects tab that you encountered right before setting the virtual memory. You can also click "adjust for best performance" for an automatic trim.
Also, it is still considered a good idea to defragment the drive after the installation do to how the installer tends to throw out information in a rush. On a clean install I got almost a mb of resources back.
Also, you can tweak the services. Visit this site:
http://www.blackviper.com/WinXP/servicecfg.htm
Using the SAFE settings you will get around 5mb of resources, and picking and choosing after that can amount to another 7.5mb
This will solve your issue.
Let us know if you have anything else.
Posted on Apr 17, 2009
  • 643 Answers
SOURCE: I have a Dell Latitude D820. It is password
Try pressing control alt delete, which should start your task manager..
Then choose new task
type in explorer
If it pulls up a window, then what you need to do is a system restore..
If it does not pull up a window, then you will need to locate a xp install disk or one of your recovery disks and try a repair install
Posted on Oct 30, 2009
SOURCE: Dell Vostro A860 Ntbk, Vista Home Basic, Slow, Fan Always Running
Try one of my Tips & Tricks which i had published
http://www.fixya.com/support/r4681055-speed_tune_up_windows_vista
I hope it might help your Notebook run faster.
Posted on May 12, 2010
Testimonial: "Great list of options many of them I applied and my Vista laptop ran 100% faster now. Thank you!"
DELL INSPIRON 1410 idle process takes high processor usage and heats up my pc
If running Windows OS - there could be several background processes running causing this higher CPU usage.
Hitting 'CTRL/ALT/DEL' will bring up the task manager (Win98/WinXP) or a Menu which has task manager (WinVista/Win7/Win8), you can then see what background programs are running.
Nov 21, 2013 | Dell Inspiron 8600 Notebook
Cpu usage 100
Usually a CPU running at or near 100% means you have to many running processes. Have you added any hardware? Memory? Still using Windows XP? There are some tips to speed up Win XP: http://www.wikihow.com/Speed-up-a-Windows-XP-Computer Do you do regular Maintenance? Clean the junk from your machine. Try 2 freeware programs to get you started. 1, CCLEANER: http://www.filehippo.com/download_ccleaner/ Use the cleaner and registry to remove the junk and free up HDD space, select TOOLS, STARTUP section, disable ALL unnecessary startup programs, this will speed up starts ant running. 2, MALWAREBYTES: http://www.filehippo.com/download_malwarebytes_anti_malware/ In the install, UNCHECK the Trial Pro version, you want the freeware version. Run a Full Scan, delete ALL results, reboot. That should get you started.
May 04, 2013 | Dell Dimension 4550 PC Desktop
High cpu useage
Open the Windows Task Manager - you should be able to right-click on the bottom task bar to do this or else, you can use Ctrl + Alt + Delete keys to invoke it too.
In the Task Manager window, select the Process page tab, then click on the CPU column header and sort the list of running processes by the amount of CPU being used - this should help you understand what is consuming high CPU on your computer.
Jan 03, 2012 | Compaq Computers & Internet
My Dell Latitude D620 is constantly spiking at 100% cpu, the problem arises especially when running the mouse over any program, it basically locks down my whole computer and nothing will run, it always...
It sounds like there could be a virus on your computer that is using up all of your CPU resources. Try to monitor the processes and CPU usage, buy pushing Ctrl + Alt + Del at the same time. This will open up the Task Manager on XP, or show you a menu screen on Windows Vista and 7, and you can click on start task manager at the bottom. View all your processes and how much cpu usage is being taken up from those processes. Look for the process using the highest cpu usage when it spikes to 100% and please repost the process name!
In the mean time might I suggest running and anti-virus scan, scanning for malware, and spyware as well. If you do not have any of these programs, I would suggest using either AVG, or Avira Anti-Virus, Malwarebytes, and Super Anti-Spyware, all of which are free programs that can be downloaded here!
Copy and paste the links into your browsers address bar...
AVG-- http://www.filehippo.com/download_avg_antivirus_32/
Avira-- http://www.filehippo.com/download_antivir/
Malwarebytes-- http://www.filehippo.com/download_malwarebytes_anti_malware/
Super Anti Spyware-- http://www.filehippo.com/download_superantispyware/
Sep 13, 2011 | Dell Latitude D620 Notebook
Hi, my pc is not working well since i installed os xp home edition, its running too slow in spite it has 512 ram and 40 hd,i havent installed the drivers i mean nothing and th cpu usage is stil 100%. what...
Windows XP needs at least 1 GB of RAM to function reasonably and for best performance, go to 2 GB. But that might not be the main problem. You really need to install the system drivers to make the O/S work with the hardware. Then run the command MSCONFIG from the command line and click the startup tab to see what might be running in the background. Uncheck the things you don't need.
Sep 10, 2010 | Dell Dimension 4600 PC Desktop
When i drag an application around it skips or roll around the screen slow, its not like that smooth drag.
The "smoothness" depends on the speed of your CPU (Central Processor Unit), the speed and memory-capacity of your video-card, and what other "background" processes are competing for CPU cycles.
If you have a desktop computer, install a better/faster video-card.
Jul 19, 2010 | Microsoft Windows XP Professional
I have a Dell Vostro 1700 with widows XP. when i play a clip from Utube it continually pauses, starts, pauses, starts, etc..
There could be a couple reasons for this:
1. Your comptuer has too many background tasks running to be able to keep up with decoding the video and playing it.
2. Your Internet connection is too slow - possibly due to virus on the computer? Also a virus would also increase CPU cycles giving rise to part of the cause in #1.
What I would do is right click to the right of the Start bar and choose task manager and click the performance tab. Look to see if your CPU usage hovers under 10% max while nothing is happening. If you see spikes, they may be normal but a constant usage over 10% is a sign something is consuming CPU cycles. Click on processes to see if you can identify the application.
To test your Internet BW or get a reasonable indication of it's performance, do a download test. Sites like speakeasy.net offer such a test.
Last but not least, Windows XP should have at least 1GB of RAM as a bare minimum. Anything less will cause paging and if you have high CPU usage, your paging will go up causing a waterfall effect as paging increases demand on CPU as well as Disk I/O.
Mar 07, 2009 | Dell Vostro 1700 Notebook
Unknown file
In software Svchost.exe is a generic host process name for services that run from dynamic-link libraries (DLLs) within the Microsoft Windows operating system.
At startup, Svchost.exe checks the services part of the registry to construct a list of services that it must load. Multiple instances of Svchost.exe can run at the same time. Each Svchost.exe session can contain a grouping of services. Therefore, separate services can run, depending on how and where Svchost.exe is started. This grouping of services permits better control and easier debugging, but it also causes some difficulty for end users wishing to see the memory usage or vendor legitimacy of individual services and processes. End users in Windows XP Professional (and derivatives, such as Windows Server 2003 and Windows XP Media Center Edition) can run the following command at the system prompt to get a breakdown:
tasklist /svc /fi "imagename eq svchost.exe" (NB: This command does not work in Windows XP Home.)
Due to being widespread among running processes, svchost.exe has long been a common disguise used by malware to hide its presence from the user. (One of the common trojan horses deceptively uses scvhost.exe). Users may then run tasklist with no arguments and match the reported PIDs with the previously shown Svchost instances. If memory usage appears abnormal, the user can look up the service names shown by their command on the internet to see if it is a known service or malware.
The Svchost.exe file is located in the %SystemRoot%\System32 folder. The main registry key involved at bootup is HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SvcHost (values in this key will show the user at least a partial list of the actual processes behind instances of svchost).
The 30 April, 2007 release of WSUS 3.0 led to reports of svchost.exe issues, including 100% CPU usage, memory hogging, and excessive laptop fan/power usage.[1]
[edit] See also
Oct 29, 2008 | Microsoft Windows Server Standard 2003 for...
Slow computer
Have u got sufficient RAM to support all ur programs...Check with the Windows Task Manager (Right click on the Task bar) for the physical memory and page file usage in ur PC.
Using Task Manager itself...check whether any unknown process  like DC.exe, FUN.exe, etc., are running....OR...anyother process is running with more than 50% processor utilisation!
If any of the above symptoms are there, try changing to some other antivirus like Antivir OR Comodo and search for Malwares, and Viruses...
Bye
Have a nice day.
I hope ... this solves ur problem. :)
May 03, 2008 | Dell Microsoft Windows XP Home Edition
Dell Inspiron 8600 Notebook Logo
49 people viewed this question
Alun Cox
