Question about Samsung Microwave Control Box Assembly - DE94-01648B
Microwave Control Box Assembly - DE94-01648B - Samsung Microwave Control Box Assembly - DE94-01648B
I have a SamSung microwave that keeps beeping SE on display
"SE" means you have a shorting membrane keypad.
On some models, the membrane keypad itself is replaced.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
On other models, the keypad is not available as a separate part, so you have to order either the control panel frame assembly (which has a new keypad on it) or a whole new controller assembly / control box.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Here's a YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Some connectors have a lock.
Jan 29, 2013 | Microwave Ovens
What is the symbol --se-- on a amana serial number1000001gt radarange microwave oven mean
"SE" means you have a defective membrane keypad.
With your full model number, I could have given you detailed instructions and parts numbers.
But without that, I'll have to just be generic.
If your model's membrane keypad is available as a separate part, that's usually the cheapest but most involved way to fix it.
Here is a handy guide with pictures showing you what's typically involved.
If it's not available separately, then you can replace either the control panel frame assembly, which comes with a new keypad on it, or the entire control box / controller assembly.
There is a a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 16, 2013 | Amana Radarange Microwave Oven
Samsung microwave says-SE- but won't respond otherwise
Jan 15, 2013 | LG LMVM1935 Convection/Microwave Oven
Shows a 5E error code. Can you help?
SE means you have a shorted membrane keypad.
Actually the best overall solution to this problem is usually to order a new controller assembly (control box) and install it yourself. It's pretty simple.
We have a similar service manual and have uploaded it to our site here to help you.
Your part numbers may be different, so you can find helpful exploded views by entering your actual full model number at the Sears parts direct Web site here.
At Web site , they have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Some connectors on the relays may have a lock:
Apr 23, 2011 | Samsung SMH9187 Microwave Oven
My Samsung SMH7187 Microwave oven display reads "SE". How do I fix it?
"SE" means you have a shorted membrane keypad.
Your part numbers may be different, so you can find helpful exploded views by entering your actual full model number at the Sears Parts Direct Web site here.
At our Web site , we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
We're happy to give you with help and appreciate your thoughtful rating of our answer.
Jan 03, 2011 | Samsung SMH7178STD Microwave Oven
My Tappan TMV151FS MIROWAVE OVEN DOES NOT WORK THE MESSAGE READS (SE) IN THE LCD WINDOW CAN'T LOCATE MY OWNERS MANUAL CAN YOU GIVE ME ANY INFORMATION ON THIS PROBLEM THANK YOU LEO LAFLER
The most economical repair (and a pretty simple one) is to replace your entire controller assembly.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Model TMV151FBA is black and model TMV151FSA is white.
You would order one of these here:
PART DESCRIPTION COST
5304456080 Control Box, assembly, black $145.14
5304456081 Control Box, assembly, white $149.42
Sep 07, 2010 | Tappan Microwave Ovens
What is a E5 error code in a micro over model number 401.80083700
An "SE" error would be a shorted membrane keypad.
I'm not sure about an "E5" error.
You would have to consult the "mini-manual" or technical sheet inside the microwave, usually located behind the control panel or hidden inside the area behind the grille. It may mention an "E5" error.
If it is an SE error this is a problem that's pretty easy for the homeowner or a friend to do himself. And you can save $200 or so.
I'll tell you what the DIY options are and you can decide if you'd prefer one of those or to call Sears/Kenmore for service:
Take your control box off as in the video at our site, peel the old keypad off as in this handy guide with pictures , clean the surface, stick on the new keypad
order by part number here DE34-00233T SWITCH MEMBRANE $20.60 membrane keypad
(We can do this job for you for a total of $64.95, but as you can see, the other two options are more practical and economical)
Take your control box off as in the video at our site, disconnect the keypad strip as shown here, move your circuit board to the new frame, reinstall
order by part number here DE94-01647D ASY CONTROL PANEL $31.77 control panel frame with keypad
Take yours off as in the video at our site, then install the new one
order by part number here DE94-01648D ASY CONTROL, BOX $58.98 complete control panel assembly with frame, keypad and circuit board
Dec 04, 2009 | Kenmore 62622 Microwave Oven
Our samsung microwave displays shows 5E and hangs up. We can hold down the start and clear at the same time and will clear off for a second.
-SE- error means you have a shorted membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
It's usually more economical on a Samsung to replace the control panel assembly, which includes the frame and keypad or (depending on your model number) the entire control box assembly which includes the keypad, frame and circuit board.
Either parts swap is easy to do. About 8 screws and a few connectors.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Mar 02, 2009 | Samsung SMH7178STD Microwave Oven
Samsung Microwave Control Box Assembly - DE94-01648B Logo
41 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
