Question about Briggs & Stratton Tools & Hardware - Others
23hp briggs go devil throttle stuck open - Briggs & Stratton Tools & Hardware - Others
2 Suggested Answers
budgie140
  • 501 Answers
SOURCE: 23hp briggs won't run when it's hot.
probably ignition coil.common problem
Posted on Jun 29, 2010
My Briggs 23hp ran out of fuel is there a reset switch as the engin will not start anymore.
I would be checking low oil level as there is a low level oil switch that switches off when you run low on engine oil.
May 10, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
How to change the crank case gasket briggs 23hp
Yes you need to drain the oil, turn the engine onto its flywheel, remove all the crankcase screws, clean the exposed crank to remove any rust or dirt, now gentlty ease the base off, it should come away with the oil pump gear.
Dec 09, 2012 | Husqvarna 23hp Briggs & Stratton 48-inch...
I have a 23hp briggs on a mud motor runs perfect out of the water. 3880rpm at wide open out of the water. in the water it get 2600 rpms just dont seem to be doing all it can do when you put it in the...
What you describe sounds like a load issue. In absence of other engine issues, too much "purchase" of your pump would render conditions like you describe. In marine applications, we would switch to a different pitch propeller to load and unload the engine.
However, 2600 does not sound too bad for a loaded, full throttle set up.
I suggest that you check with the tech department at the manufacturer and see what they think is the desired RPM.
One other item to look at is often engines are throttled by a wind govenor, at the flywheel. Often you can tweak the linkage connecting to the throttle plate and achieve a higher loaded RPM.
Nov 19, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Jun 29, 2010 | Briggs & Stratton Garden
Hard to start lawn tractor
I have 2009 lawn tractor that will not start (from day 1) unless I use a small squirt
of start fluid into the air cleaner area. Nothing else seems to work. The battery will run down before it starts. Once engine is warm it starts great. Love the tractor,
hate the starting problem. Elevation is not a problem in michigan.
Jan 11, 2010 | Briggs & Stratton Briggs Stratton Intek V...
As soon as my 10 hp Briggs & stratton engine starts, it goes to full throttle. I have no control
The engine speed is controlled by a governor and throttle position. There is a spring that holds the throttle (butterfly valve) against the slower position. When the motor is under load' the governor exerts force to open the throttle position. Make sure that all of the components are clean and not binding. Look for a broken or disconnected spring. It is also possible that the governor is stuck in the demand full throttle position.
Sep 11, 2009 | Briggs & Stratton Garden
Briggs & stratton carburation problem
You should be able to order one from the saw manufacturer or through your local small engine repair shop.
Sep 05, 2009 | Saws
Tools & Hardware - Others Logo
21 people viewed this question
Top Briggs & Stratton Tools & Hardware - Others Experts
Bill Boyd
Daryl Gleaton
obsteiner
Are you a Briggs & Stratton Tool and Hardware - Other Expert? Answer questions, earn points and help others
