Question about RTO Allis Chalmers Fuel Sending Unit 5040,5050... Tractors
5040 ac rear lift arms no power - RTO Allis Chalmers Fuel Sending Unit 5040,5050... Tractors
How to remove a interior plastic door panel from a 2005 Dodge Grand Caravan lift hatch
2 screws in arm rest 1 on the both side 3 on the bottom 1 in the door handle lift up if power windows watch for wires
Jan 15, 2016 | 2005 Dodge Grand Caravan
How to take off the rear windsheild wiper on a 94 grand cherokee
You will need a 13-inch wiper blade for the rear window. 1 - When removing the wiper blade lift the wiper arm away from the window. ----- 2 - With one hand holding the wiper arm press the small tab on the underside of the wiper blade where it meets the wiper arm. ----- 3 - Slide the wiper blade off of the arm by pulling the center toward the bottom of the arm.----- 4 - Lightly lay the wiper arm on the window.----- 5 - Prepare your new wiper blade by taking the curved part of the plastic clip and line it up with the curve of your wiper arm. ----- 6 - Lift the wiper arm and press it through the center of the wiper blade up and over the plastic clip. 7 - Pull the wiper blade up until it clicks. Place the arm back on the window.
Jan 11, 2012 | 1994 Jeep Grand Cherokee
I have a Brother HL-5250DN printer and trying to replace the Paper Feed pickup roller assembly. Can you tell me how to take the old part out or send a diagram? Thanks, Sherry
Paper feeding kit for MP tray
(1) Disconnect the AC cord from the Printer.
(2) Press the front cover release button.
(3) Open the Front cover.
(4) Remove the Drum/toner ASSY.
Open the MP feed frame cover. (6) Remove the Holder bearing MP. Lift up the Lift arm MP to release it from the Pin of the MP roller holder ASSY. (8) Slide the MP roller holder ASSY to the direction of the arrow 8a and put it up to remove. Fig. 3-77 (9) Turn the back side of the Separation pad ASSY MP to the direction of the arrow 9a and put it up to remove. Fig. 3-78 Separation pad ASSY MP MP roller holder ASSY Pin MP feed frame Lift arm MP 7 8a 8b MP feed frame MP frame 9b 9a
(1) Put the Hook of the Separation pad ASSY MP into the MP feed frame and pull down the Separation pad ASSY MP to the direction of the arrow 1b until it is locked. Fig. 3-79 (2) Lift up the Lift arm MP and put the MP roller holder ASSY into the MP feed frame. Put the Pin of the MP roller holder ASSY into the hole of the Lift arm MP. Fig. 3-80 Separation pad ASSY MP MP roller holder ASSY Pin MP feed frame MP frame MP feed frame Lift arm MP
(3) Put the Holder bearing MP into the MP feed frame and turn the Holder bearing MP to the direction of the arrow 3c to lock. (4) Close the MP feed frame cover. Holder bearing MP Hook MP feed frame cover Front cover MP feed frame 3a 3b 3c MP feed frame(5) Install the Drum/toner ASSY into the Printer. (6) Close the Front cover. (7) Connect the AC cord into the Printer. Printer AC cord Drum /toner ASSY Front cover .
Mar 18, 2011 | Brother HL 5250DN Laser Printer
I installed a new wiper motor. I ran it before installing the wiper arms. it will not stop at zero. it over travels down into the cowling. I try to rest them higher then they stop some where in the middle...
Try to run the motor without the wiper arms tightened down and turn it off so it can cycle down to its rest state. Then install the wiper arms.
Make sure, that the car's windshield wiper wiring is correct for this motor.
Wiper Arm & Blade Removal & Installation Front To Remove:
CAUTION
When the wipers are parked (off), the driver’s wiper arm must be above the passenger’s wiper arm.
  1. Remove the clip holding the outside end of the wiper arm cover to the arm.
  2. Lift the arm cap up to expose the nut.
  3. Remove the wiper arm mounting nut.
  4. Using a suitable two jaw puller, remove the wiper arm from the wiper pivot.
To Install:
  1. Verify that the wiper motor and linkage are in the parked position.
  2. Place the wiper arm in position over the wiper pivot.
  3. Install the nut to hold the wiper arm to the wiper pivot. Torque nut to 26 ft. lbs. (35 Nm). CAUTION
    Make sure to tighten the wiper arm nut properly.
  4. Push the arm cap cover down.
  5. Secure the clip holding the cover to the wiper arm.
Rear To Remove:
  1. Lift and hold the wiper arm away from the rear window.
  2. Lift the lock securing the wiper arm to the pivot.
  3. Slowly release the wiper arm so it rests against the lock.
  4. Remove the wiper arm from the pivot.
To Install:
  1. Install the wiper arm on the pivot.
  2. Pull the arm outward and release the lock.
  3. Gently release the wiper arm until it rests on the rear window.
Aug 22, 2010 | 1996 Dodge Grand Caravan
Can't remove rear wiper to replace on 96 caravan
Lift wiper arm from rear window. then release latch that holds the blade to the wiper arm.( It's small tab)
Jan 16, 2010 | 1996 Dodge Caravan
Ac problem
I just fixed mine. same problem, no ac light no fan. inside the heater control assembly there is a electric wiper arm on the fan switch. This arm connects all power for fan and ac. Mine broke out of the fan control switch. Dash is not too much problem to get out. Have to pull top dash center section out by puching forward and lifting out. pull all screws on center dash counsel. remove radio, two side covers that hide screwsand lower trim that holds emergency flasher switch. remove cables from heater control and wires and remove. Took me about an hour. The code on radio will need to be reset so make sure you have that handy. Hope this helps..
Jul 28, 2009 | 1998 Volkswagen Beetle
Allis chalmers AC 5040 is leaking water/fluid
looking for in the oil cooler inside the radiator maybe is broken.
Jul 11, 2009 | B&C Allis Chalmers Tractor B,c,ca Flywheel...
How to remove rear wiper arm
Remove the nut holding the arm. Should be able to lift up on the arm and loosen the joint at the motor.
May 29, 2009 | 1996 Dodge Caravan
Batter AC constant switch back nd forth
several possible causes -- bad power supply (AC adapter, bad battery, bad connection to AC adapter, bad connection to battery - or both.
May 26, 2009 | Acer Aspire 5040-3810 Notebook
HOW DO I REPLACE A REAR WINDOW WIPER ON 2005 FORD ESCAPE?
Remove the rear pivot arm.
Lift the pivot arm to the upright position.
Slide the locking tab out.
Pull up and remove the pivot arm.
Remove the rear wiper motor shaft nut cover.
Remove the rear wiper motor shaft nut.
Remove the rear wiper motor cover.
Remove the rear wiper motor bracket nut.
Remove the bolt and the rear wiper motor.
Jan 29, 2009 | 2005 Ford Escape
RTO Allis Chalmers Fuel Sending Unit 5040,5050... Tractors Logo
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
