Question about Water Heaters
White Rodgers Hot Water Thermostat Type 11B76-1
Setting up of HW Thermostat and if still functions
3 Suggested Answers
liteswink
  • 99 Answers
SOURCE: White rodgers motor turning heat not going thru
This item is a buy -out from Thermodisc send a inquiry to there contact us.
Link: Contact Us
Posted on Apr 07, 2010
SOURCE: Hot water heater restarts then turns off. This
Service technician is probably best bet for troubleshooting all possible causes from plumbing leak to burner assembly needing cleaned to blower problem to bad gas control valve or tripped ECO, or combination of things listed above.
The intelli vent controller has error codes.
Open link for images, error codes and sample manual.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#Intellivent
I think the Kenmore is a Rheem product, but the market changes very fast.
Intellivent control indicates that water heater has a blower on top of heater that communicates with the gas control valve to coordinate combustion.
Rheem recommends the burner assembly be cleaned no less than once a year by trained service technician who has the tools and experience.
Newer gas water heaters, both tank and tankless are maintenance heavy because of energy and safety standards, and because of new electronic controls. Tankless require more frequent attention.
If problem is going to cost more than $330, then install new gas water heater yourself from local box store. I recommend avoiding electronics, and blowers, and tankless so you can hold down costs and maintain the unit yourself.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Water heater electronics and energy factor are good initial selling points, but all costs are energy, and repairs, service and parts of more sophisticated machines can cost more than the $1 to $8 saving you can expect under best circumstance.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 22, 2011
Sometimes water is very hot other times luke warm at best.
flush the lime buildup out a 3/4in full port ball valve with hose adapter. Should do for the drain
Sep 19, 2015 | AO Smith A O Smith Water Heater Hot...
I have the White Rodgers Intellivent on an OA Smith propane hot water tank, but cannot get any lights on the controller, even after shutting off the power and then back on. The plug is hot and the uni
The plug is HOT?
Unplug immediately.
Is the outlet hot? Is the circuit breaker hot. Have you had a surge event or nearby lightning strike?
Do you have electrical issues in home?
Add a comment.
Test outlet for correct polarity, and test for overvoltage and short.
The intellivent is very susceptible to surge and will stop functioning.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Copy following link for troubleshoot by type of gas control valve.
Including intellivent service manual.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 09, 2012 | RTO W4 A.O Smith Gas Hot Water Heater...
My gas bill has been going up each month but I have not been increasing the use of hot water. I have turned down the temperature control to the lowest setting (vacation) but the water is still very hot -...
Replace gas control valve.
The gas valve is the thermostat.
Vacation setting should be 50 degrees, or so, depending on exact gas control valve.
If gas water heater is not responding to temperature setting, then thermostat is suspect.
Open following link to help identify tank-type gas valve.
Each gas valve should have identifying number on side.
Instructions how to replace typical gas control:
http://waterheatertimer.org/pdf/White-rodgers-gas-vale-replacement.pdf
http://waterheatertimer.org/pdf/How-to-replace-gas-control.pdf
Additional resources with service manuals:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Add a comment for more help.
Take a moment and rate answer for accuracy:
Sep 13, 2011 | Rheem 30 Gallon FVR NATGAS Water Heater...
I need help reprogramming a White Rogers thermostat Please call 352-561-6082
you need to look at the model number and then give me a call back and I will help you fine a way to get you hot water
Sep 08, 2011 | White Rodgers Water Heaters
My white rodgers control panel is set on vacation (green light) is on. I have held down the arrow buttons to get it off of vacation mode but it is not working. Obviously i need to switch it off as we have...
Water heater and gas valve are not clear:
Add a comment with description of water heater and gas valve for possible help.
Open following link for White Rodgers intelli-vent gas valve thermostat:
http://waterheatertimer.org/pdf/Intelli-vent-gas-valve2.pdf
1) Typical instructions for Kenmore and AO Smith water heater with Intelli-vent say:
Set on-off switch to ON position.
Hold down both arrow buttons for 1 second.
Then press hotter button.
2) Also check that 120Volt electrical outlet has power, and check outlet with cheap circuit analyzer from home center.
3) If Intelli-vent gas valve thermostat is malfunctioning, and won't reset, then contact manufacturer of water heater for replacement gas valve.
Label on side of tank will have Model number, manufacturer, type of gas LP NG, serial number for part ordering.
Jun 10, 2011 | White Rodgers Water Heaters
Air conditioner thermostat problem
this sounds like a short circuit that the cover is making with something. Take a close look at the contacts, wires and how close the cover comes to them.
Jun 09, 2010 | White Rodgers 0754-1 Electric Water Heater...
How do you reset a white rodgers hot water heater?
The red button at the middle is the manual reset button.
Apr 24, 2010 | White Rodgers 0754-1 Electric Water Heater...
Water Heaters Logo
314 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
