Question about Duravit Home
How to replace a duravit toilet seat?
Only 2 silver semi-circular discs...no bolts or nuts....
How do I replace a toilet seat on duravit happy D toilet
I think our toilet is a Duravit.
Close the seat and the lid then have a look at the back of the hinges. If you can see a small hole in the back of the hinge there will be a grub screw in the hole and you can undo it with an allen key (not sure what size - you'll have to try a couple)
May 21, 2012 | Duravit 0910100005 Happy D Toilet Cistern ...
The hinges of Duravit toilet cover seat 006331 are broken. Where can I get replacements?
I have not been able to find a "tribeca" on the Duravit website but on the site of one of their parts distributors I found the Duravit Toilet Seat DUR 006331000. Is this your model? Starck 3
On the Duravit website this product looks very similar but not the same number.
I was not able to find replacement hinges for this model sold separately. You might consider using their Find a Retailer feature to find an outlet close to you where you might make inquiries or order hinges and/or a new lid.
Jan 17, 2011 | Duravit Tribeca US-Type Elongated Toilet...
My toilet is a duravit 1930 series model with Euro style push flusher rather than handle. Internal flushing mechanism is not traditional float ball. toilet water constantly leaks from tank into bowl...
A fairly easy ( but messy ) fix - get a replacement tank to bowl gasket and bolt kit, shut off water supply, drain tank, remove bolts ( you might have to cut, depending on your water source and minerals in your water). Remove old gasket and clean surface with 00 grade steel wool. Replace gasket, install new bolts, remount tank.
Good luck!!
Nov 17, 2010 | Duravit Tribeca US-Type Elongated Toilet...
The toilet see is not tight. How can I tighten the seat? I have an elongated seat with the soft closing lid.
Right behind the bowl on the underside there is a nut on either side that holds the seat on...tighten those nuts and it will tighten down the seat...
heatman101
Aug 29, 2010 | Toto Aquia II Dual Flush Toilet
Have a Duravit Starck 3 2-piece toilet 2105010000 Hinges that hold the seat and cover are broken. Where are these hinges available?
Unfortunately you won't find a universal replacement part to work with this seat which you would commonly find at your local hardware store. I've looked through the Durovit site and could not find a parts catalog. Try using the find retailer option on the manufacturers site and if there isn't a retailer in your area contact the manufacturer directly to see if they supply parts for their seats. I'm guessing they don't and you would likely have to purchase a new seat.
http://www.duravit.com/service/find-a-retailer-useo6suuk8.html
Duravit USA, Inc.
2205 Northmont Parkway
Suite 200
Duluth, GA 30096
Phone +1 770 931 3575
Toll free: 888 387 2848
Fax +1 770 931 8454
Toll free: 888 387 2843
info@usa.duravit.com
Aug 02, 2010 | Duravit 0063810000 Stark 3 Toilet Seat and...
How do I remove the toilet seat for duravit
You need an open end wrench or socket I believe 9/16 is the size
Nov 14, 2009 | Duravit Darling Wall Mounted Toilet White
Toilet seat come loose and no obvious way to tighten??
well there should be 2 hinges rite behind seat. you wont see the screws cause they are under a plastic cover. take a flat head screw driver and pry up cover. lil cover should lift up towards tank. then you should see screws. the nut is under bowl you have to bend down then look up to see them or do what i do and feel for them. take big flat head or big philips screw driver and while you hold nut titen screw. hope this helps. duane:)
Oct 05, 2009 | Duravit Starck 3 Wall Mounted Toilet with...
Home Logo
41 people viewed this question
Top Duravit Home Experts
Paul Carew
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a Duravit Home Expert? Answer questions, earn points and help others
