Question about Gateway Profile 5.5 PC Desktop
How to do a cpu fan test - Gateway Profile 5.5 PC Desktop
Displays momentarily and asks for CPU fan connection. I have changed 4 fans and still get the same error message and the display goes off.
You're sure you have the cpu fan connected to the correct socket? sounds like it's not connected, or is connected to a different socket. Does the fan turn?
Apr 22, 2015 | Computers & Internet
When i turn on my hp all in one computer,it's telling me cpu fan can not be detected
Hello user...you are receiving this message at start-up because, in your bios system settings, "run fast diagnostic test" is enable...CPU fan is like a computer fan but attached with the cpu to cooled the cpu so that the cpu will function properly so as the computer...perhaps there is a problem with the fan, so its not running when the computer starts. This may harm your CPU, as a result may blow the circuits in the motherboard and eventually your computer will crash....for a technical advice, you may want to visit the nearest PC repair shop and change the cpu fan..
Jun 23, 2014 | HP Mini 1000 Netbook
Power supply works but pc doesn't power up no lights and fans dont work
Have you checked the power supply in different system? If yes then first replace CMOS battery and switch the CMOS battery jumper. And while doing this please unplug the hard disk or optical drive data cables and power. If it does not work then check the power switch is working or not or it is perfectly connected with the front panel PINS on the motherboard. If it is not connected perfectly computer will not start after pressing power button.
Second Level Test : Remove the CPU Fan - replace the CPU perfectly - again place the Fan.
Third Level (motherboard test): Just take the motherboard removing CPU,RAM, SMPS - use another same type CPU, RAM and SMPS - if it does not work so it is motherboard problem. If it works may be CPU problem.
Jun 12, 2010 | Gigabyte GA-8LD533 Motherboard
Motherboard test jig starts and shuts off
Need more info??
Any posting beep?? If not is ram or CPU.
If so then Mobo / cpu.
What have you plugged in?? Must have Ram and video.
If you have probably CPU.
Apr 13, 2010 | Intel Motherboard
CPU fan turns for a few seconds and stops, pc will not turn on. Have tried a good PSU, same issue. Removed all connection to motherboard apart from 20 pin, 4 pin power + cpu fan and PW switch: same issue.
1. First of all Remove dust from your CPU fan and try again if issue has been not resolve
2. Second test your SMPS by the help of Green & Red wire. In case fan is turning properly it mines your SMPS is ok
3. Third & last kindly replace your SMPS For the same.
Nov 19, 2009 | HP Pavilion a1120n (PX759AA) PC Desktop
Asus A8V-E not start
Looking at this post, I think your Motherboard is bad.
Have you tried a different Video Card?
My other thought is the CPU is overheating due to incorrect seating of the FAN and heat sink.
Try cleaning the CPU off, and put new paste on the CPU, then re-seat the heat sink.
Be careful to make sure the anchors are pushed all the way down by slightly twisting or wiggling the heat sink.
Check for looseness.
Push down on all memory sticks to ensure they are seated all the way in.
They should click on both sides.
If it still gives you a red light, then contact the website of the manufacturer, and get an RMA number for a replacement.
Jul 24, 2009 | ASUS A8V-E Deluxe Motherboard
DS10L AlphaServer CPU Fan Failure
The answer is to get hold of a high-speed case fan. I used a Scythe s-flex 80mm which has a +/- 5% RPM of 2800. rearrange the pins or use a choc-block such that yellow -> black, red -> yellow, black -> red. Hey presto.
Works for me.
Mar 19, 2008 | Compaq AlphaServer DS10
Averatec cpu fan
IF you check your BIOS and everything is fine, and also you run a stress test, and everything clears. They you have no problem, usually you see this error in custom builds.
rate pls
Jan 19, 2008 | Averatec Sotec 3200 Series Fan with...
Gateway Profile 5.5 PC Desktop Logo
14 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
