Question about Pyle PT210 Amplifier
Amp schematic diagram
Ic amplifier number
I have a Sony STR-V444ES receiver that is receiving what I believe to be a static discharge. When I turn on all components, I will receive a random loud popping sound that usually happens in the first 15...
The AVR have problem in its pre amplifier stage. Normally this type of cracking noise will hear because of faulty op amp (operational amplifier) ics. To repair such problems you should have through knowledge in electronics. And also need SMD rework stations Beacuse all the op amp ics are SMDs. If yo have such knowledge then i have added here the link to the service manula for your AVR.
Refer the page number page number 13 first. Its the Audio section blaock diagram of the AVR. you can see the the suspected ic in the top right corner marked as IC410. Which is the pre stage op amp for the frond left righ amplifier. You have to replace this ic( integrated circuit).
You can find the position of the ic by refering Page number 27. Its the input board . On the board you can see three ics with 8 legs(four in each side) On the left side. You have to replace the ic marke as IC410. You can find the schematic for the input board in page number 26. the The part number of the ic M5218AFP-T .
Refer the sevice manual to know how to carefully to remove the input baord.
http://sportsbil.com/sony/STR/STR-V/STR-V333ES_V444ES_V555ES_v1.2.pdf
If you need any more assistance feel free to conatct me through fixya.
Ajin
Feb 08, 2012 | Audio Players & Recorders
What is technics amplifier su z2 ic number
HI,
The out put ic number of Technics SU Z2 is SVITK2038. If you can sent your email address the i will sent the schematic diagram
OK
Oct 10, 2011 | Technics SUV500 2-Channel Amplifier
My Philips home theater model hts3105/98 is not working due to IC breakdown hence i need that ic number to replace it. hence please help me.
Every IC has their number printed on the top 1st line. If you have identified the IC, look for the number. If it is burnt & cannot get the number, you will have to refer the schematic diagram of the model. The service manual is available under following url. Just paste the following url in your browser , a download link is there.
http://new.eserviceinfo.com/downloadsm/54246/PHILIPS_HTS3105.html
sonsunny
Jun 17, 2011 | Televison & Video
Where can I get a schematic for the Bugera 1990 guitar amplifier? This amp is made off shore but is popular and sold in the US. No supplier can help...the manufacturer has no phone number for support. ...
Hi, If you put " a schematic for the Bugera 1990 guitar amplifier?" in your search engine, you will get a selection of schematic web sites. Chose "frinthylcprobin.files.wordpress.com" There you will be able to download the schematic.
Kind regards
David
Feb 25, 2018 | Audio Players & Recorders
I request a schematic diagram of crown power amp CE2000 2-Channel
The surface mount ic= MC33079D , 14 pin quad low noise op amp is likely at fault, IF the amp is NOT showing a fault light. A LM324D surface mount will
also work in a pinch. It's located on the input pcb attached to the input jacks.
Jan 19, 2010 | Crown CE2000 2-Channel Amplifier
Schematic Diagram
I don't have a schematic but I have photos of that amp. What part do you need to identify?
babin_perry@yahoo.com
Jul 21, 2009 | Kicker KX1200.1 Car Audio Amplifier
In need of the wiring diagram with values
contact the company that makes the amplifier. I have bought schematics from car stereo manufacturers before, it shouldn't be a problem.
Mar 28, 2009 | Philips GEMINI XG-3001 Fan...
Have a a7 Hc... Blown transistors.. Shematic diagram??
What are the part numbers on the transistors you replaced?
Did you replace transistors in the output section and the power supply section?
Does this amp have the defaced ICs labeled B52 and F16?
Jun 21, 2008 | Cadence A7 HC Car Audio Amplifier
Spl amp 2400 watts
do you know how to trouble shoot solid state devices??? if so then what you need to do is disconnect the collector if its a transistor output device or the b+ leg if its an Ic output device and then measure the ohms between the emitter and the collector or on an ic device the B+ leg to the outpot leg. If its shorted Your gonna need a schematic most likly to trace the path of the short.. if you dont understand this then you will need to take it to a repair shop and let them do the repair as you may not be up to a componet level type repair.. BUT if you are please get the schematic diagram and post it attention to me and i will be more then happy to assist you with this repair. Good luck
May 03, 2006 | SPL Dynamics Z1X-2400D Car Audio Amplifier
Pyle PT210 Amplifier Logo
37 people viewed this question
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
