Question about Vtech Counting Fun Elephant
Vtech elephant popping mechanism
It does not pop! Any advice?
Sounds like a motorcycle but muffle isi okay coming from throttle body
Hard to figure without hearing it but if it's POP - POP - POP - POP - POP then it's likely a lifter camshaft or valve problem possibly jumped timing or even cross firing. Best to take it to a mechanic .
Mar 07, 2015 | 2006 Chevrolet Chevrolet Aveo LS
Tip
FRIDGIDAIRE FRONT LOAD WASHER DOOR LOCK
THIS FRONT LOAD WASHER HAS AN ELECTRONIC SWITCH THAT SNAPS INTO THE LOCK MECHANISM. MINE POPPED OUT OF THE 2 CLIPS THAT HELD IT IN PLACE, SO WHEN I CLOSED THE DOOR, THE LOCK LIGHT DID NOT LIGHT AND THE DOOR DID NOT LOCK. HAD ALL KINDS OF ADVICE THAT DIDN'T WORK. UNPLUG THE WASHER, REMOVE O RING AROUND RUBBER BOOT. REMOVE THE FRONT PART OF THE BOOT. THEN YOU JUST REMOVE THE LOCK MECHANISMS, 2 SCREWS IN THE FRONT. PULL THE LOCK MECHANISM HOUSING TO THE SIDE, BE CAREFUL OF THE CONNECTED WIRES, THEN LOOK WITH A FLASHLIGHT. IF THE SMALL SWITCH BOX IS OUT OF PLACE, THEN POP IT BACK IN. THIS PROBLEM STARTED WHEN I WAS CLOSING THE DOOR TOO HARD AND QUICKLY. SO BE GENTLE WHEN CLOSING YOUR DOOR. THE ARM THAT LIFTS TO HIT THE SWITCH THAT TURNS THE DOOR LOCK LIGHT ON AND LOCKS THE DOOR, IS PLASTIC.
on Sep 17, 2013 | Frigidaire Washing Machines
Turn off pop up blockers
Open Google Chrome. Go to menu. Now go to Privacy>> Content Settings>>Pop-Ups, Then Select Allow all Pop-ups. You can add manually website addresses in Manage Exceptions.
Apr 21, 2013 | Google Chrome
Wont pop up old toastmaster toaster
Hi mon42,
The 'click' sound indicates that the pop up mechanism is most likely intact. The problem of not popping up is most certainly caused by a worn or broken or disconnected spring which forces the toast to pop up once it's done.
You will need to take the toaster apart and look for the mechanism which pops the toaster up (look for the mechanism attached to the tray in which the toast lies). There should be a spring, or remnants of a spring, which should be fairly easily replaceable with a similar spring. This should be readily available from your local appliance spares store.
Please let me know if I can help any further or furnish you with more details. As your toaster is very old, it will be too difficult to find any documentation on the specific model.
Best wishes,
Graeme.
Jan 06, 2012 | Toastmaster Kitchen Appliances - Others
I have a Canon Rebel. When I try to take pictures the flash "hood" or something automatically pops up but somehow the light doesn't flash and all I hear are 3 clicks. Then the screen says error...
Aprilm,
Error 5 is a flash error. What sounds like it happening is the mechanical part of the flash is working allowing for the pop-up, but the camera thinks there is an external flash present. A repair shop should be able to address the issue. Usually it's a problem with the micro switches "inside" the flash shoe.
Please let me know if you have any more questions.
Thank you.
Feb 20, 2011 | Canon Rebel XT / EOS 350D Digital Camera
An old man has 17 elephants, when he was going to ...
9, 6, 1.
Answer found in less than 10 seconds.
May 20, 2010 | Computers & Internet
Can open battery back on cordless phone
I had to use a knife to slide under the top of the release area and pop it out. It wouldn't slide like it is supposed to. didn't break it....
Jan 01, 2010 | Vtech IA5854 5.8 GHz Cordless Phone
Timing Belt and Intake and Exhaust Valves..
At least engine head must be removed for inspection and repair. When head removed you can estimate also if any damage on pistons top surface.
Jun 25, 2008 | 2004 Hyundai XG350
Hotpoint fridge
Just turn the control knob back down to 0 and button should pop back up.
Jun 19, 2008 | Refrigerators
Vtech Counting Fun Elephant Logo
32 people viewed this question
Top Vtech Toys Experts
Nikki  Mclean
Nikki Mclean
Are you a Vtech Toy Expert? Answer questions, earn points and help others
