Question about Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin Oil Radiato Heater
How to set the digital timer on blyss oil filled rad
Remote control for blyss carolina wall hung fire ?
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Aug 15, 2014 | Televison & Video
Blyss
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
Mar 24, 2014 | Televison & Video
I have a oil filled rad style electric heat ,which is leaking oil can it be fixed? If so how.
Here is a tip that I wrote that will help you to understand about oil filled radiator heaters....
Oil Filled Radiator Heater Leaking
heatman10
Dec 19, 2010 | Honeywell HZ-709 Oil Filled Radiator...
Is ther any thing special I need to know when replacing my rad for my 96 850 Wagon 2.4 liter. I have drained and removed the old rad which had a broken nipple on the intake side. I have drained the...
Only certain engines need to be purged of the air in there, some engines have a plug on the top for it, some have to be filled on a slant or jacked up, some don't need anything. But you do want to use a premix coolant, 50/50 right out of the jug, or if the old coolant is clean, pour it back in. The tranny oil you don't have to worry about. I would fill it up, keep an eye on the temp gauge and check it every day. If it needs filling, top it off with the same, fill the expansion tank too. If it overheats, then I would check on the purge, It will effect the engine. I can look it up for you, but you can use the google thing too. Hope this helps.
Oct 17, 2010 | 1996 Volvo 850
Delonghi dragon oil filled heater with timer. How does the timer work, is there a way to set it so that it stays on all the time? Do not have the manual
Within the timer is a 3 point switch. Push the switch to the end closest to the arrow and away from the clock icon. It will stay on
Oct 04, 2010 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
Delonghi Dragon Two, oil filled rad trips the main elec fuse
If it is tripping the breaker in the panel, there is a direct short in the heater. Scrap it before it causes a fire. Seriusly
Oct 24, 2009 | DeLonghi 6707E Oil Filled Radiator Heater
Set time on delonghi oil filled portable heaters and set start and finish times
It was very tough to find the actual manual online for your modle in English. However, you can call Delonghi customer support:
DeLonghi Customer Support: (800) 322-3848
Delonghi does have manuals for some models on their site. Take a look at this link, the model might be similar enough to yours to be able to get the information you need.
http://www.delonghiusa.com/search_results.cfm?sp_q=oil+filled+heater&sp_p=all&sp_f=ISO-8859-1&sp_w_control=1&sp_w=alike&sp_a=sp1003e79d&sp_c=5
Hope this was helpful.
have a great day!
Oct 29, 2008 | DeLonghi 6707E Oil Filled Radiator Heater
Delonghi MG15T Magnum Oil-Filled Radiator timer -timer keeps running?
I found the manual at this website:
http://safemanuals.com/user-guide-instructions-owner-manual/DELONGHI/MG15T-_M
I hope this helps.
Oct 13, 2008 | DeLonghi MG15T SafeHeat Oil Filled...
Heating & Cooling Logo
46 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
