Question about Imada I80 Torque Tester 0.30 to 70.00 in-lb Range 0.01 in-lb
Imada I-80 Torque tester intermittently reads -7 in/lbs and errors out when testing a torque screwdriver.
The I-80 errors out even when the driver is set at lowest setting (1) and it doesn't make any difference if FWD or REV. The I-80 was calibrated in April 2013. This problem started about 2 months after being calibrated. It has never given me a problem before.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 22 Answers
The torque transducer may have been overloaded and damaged. It will need servicing and possibly a new transducer installed.
Posted on Aug 13, 2014
04kiaoptima 2.4crankshaft torque specs
main bearings torque is 18 ft lbs. plus 90 - 94 degrees, rod bearings torque is 13 - 16 ft lbs. plus 90 - 94 degrees.crankshaft damper bolt torque 80 - 94 ft lbs, fly wheel bolts torques 94 - 101 ft lbs.
Oct 29, 2012 | 2004 Kia Optima
Whats the head bolt torque specs for B&S 310C707 17.5 hp
220 lbs? That's ridiculosly tight,even on a big block V8! I bet it is 220 INCH lbs.,not ft/lbs. This seemed about right with my scientific test(a beam-type torque wrench and a 1/2" combo wrench).55 ft/lbs is about the territory of head bolts on automotive engines with 5/8" head bolts.1/2 drive torque wrenches usually read in ft/lbs,so you need a 3/8" drive torque wrench.
Sep 15, 2012 | Measuring Tools & Sensors
What does mean torque the bolt to 80-106 in lbs (11-13 Nm)
Hi Anonymous, that means torque that fastner to 80 - 106 inch pounds or 7 - 9 ft lbs. Have nice day.
Apr 12, 2012 | Cars & Trucks
What is the torque number sequence for a 2001 oldsmobile aurora 3.5 v6
Assuming about cylinder head...
Fig. Front cylinder head bolt torque sequence - 3.5L (VIN H) engine
  1. Install the cylinder head with a new gasket.
  2. Install new M11 bolts and M6 bolts.
  3. Torque the M11 bolts in sequence to:
    1. Step 1: 30 ft. lbs. (40 Nm).
    2. Step 2: 100 degree turn.
    3. Step 3: 100 degree turn.
  4. Torque the long M6 bolt to 22 ft. lbs. (30 Nm).
  5. Torque both shorter M6 bolts to 106 inch lbs. (12 Nm).
  6. Install or connect the following:
    Lifters Rocker arms Camshafts Primary chain
  7. Remove the timing chain holding tool.
  8. Install or connect the following:
    Camshaft covers. Torque the bolts to 80 inch lbs. (9 Nm). Exhaust manifold. Torque the bolts to 22 ft. lbs. (30 Nm). Coolant crossover pipe. Torque the bolts to 18 ft. lbs. (25 Nm). Intake manifold. Torque the bolts to 62 inch lbs. (7 Nm). New oil filter Negative battery cable
Hope helps.
Mar 29, 2011 | 2001 Oldsmobile Aurora
I need to know he torque spects for the oil filter container the bolts on to the moter on a 94 BMW 318i...there are 6 bolts...I also need to know the torque spects on the alternator mounting bracket...
OIL PAN OR TRANSMISSION PAN BOLTS TORQUE ABOUT 7 FT LBS. CAN GET SPECS ON BOLTS SIZES. IF BOLTS SIZES IS 13M I4M 15 M TORQUE BOLTS ABOUT 55 TO 80 FT LBS
Nov 11, 2010 | 1994 BMW 3 Series
1998 FORD FESTIVA HEAD BOLT TORQUE SETTINGS & TIGHTENING SEQUENCE (1.5 LITRE ENGINE)
1978 - 1980 FORD FESTIVA 1.6L 65-70 Foot pounds (Final torque)
Torque sequence 9 3 1 5 7 8 6 2 4 10 Step 1: torque to 5 Ft/Lbs Step 2: torque to 20-30 Ft/Lbs Step 3: torque to 50-55 Ft/Lbs Step 4: torque to 65-70 Ft/Lbs Recheck final torque in sequence
1988 - 1993 F0RD FESTIVA 1.3L
Torque sequence front of engine 8 4 1 5 9 7 3 2 6 10 Step 1: torque to 35-40 Ft/Lbs Step 2: torque to 56-60 Ft/Lbs Recheck final torque in sequence
2011 FORD FESTIVA 1.6L NO TORQUE SPECS AVAILABLE THERE IS NO FORD FESTIVA MANUFACTURED IN 1998 ALSO NO FORD FESTIVA MANUFACTURED WITH A 1.5L ENGINE
HOPE THIS HELPS YOU
Aug 06, 2010 | Ford Focus Cars & Trucks
Rod and main bolt torque specs
rods bearings for the 4.2 engine is.18 ft lbs +110 degrees. main bearings 18 ft lbs +180 degrees. the 5.3 engine rod bearings torque is.15 ft lbs +85 degrees.main bearings is inner bolts 1st pass 15 ft lbs .final pass is 80 degrees.outer bolts 1st pass is15 ft lbs .final pass is additional 51 degrees.the m8 bolts 18 ft lbs..the 6.0 engine rod bearings torque is 15 ft lbs plus 85 degrees.the main bearings torque is inner bolt 1st pass 15 ft lbs .final pass plus 80 degrees. outer bolts .1st pass 15 ft lbs final pass plus 51 degrees.m8 bolts 18 ft lbs.
Jun 19, 2009 | Saab 9 7X Cars & Trucks
Head bolt toqure
Hope this helps, from autozone site. Curt
Application:
Cylinder head bolt torque sequence
Note :
Torque sequence:
front | 3 1 6 |
of | |
vehicle | 5 2 4 |
Step 1: Lightly oil cylinder bolt threads & washers
Step 2: Torque to 22 Ft/Lbs
Step 3: Torque to 51 Ft/Lbs
Step 4: Loosen all bolts 180 degrees
Step 5: Loosen all bolts 180 degrees
Step 6: Torque bolts 1 & 2 to 25 Ft/Lbs
Step 7: Torque bolts 3, 4, 5, 6 to 11 Ft/Lbs
Step 8: Turn all bolts an additional 80 to 90 degrees
Step 9: Turn all bolts an additional 80 to 90 degrees
*** CAUTION ***
engine uses Torque To Yield head bolts (TTY) that
permanently stretch during the initial installation.
New head bolts must be used when cylinder head is
replaced or re-installed to obtain proper Torque.
Apr 24, 2009 | 1995 Subaru Legacy
Change torque setting on Uryu pneumatic driver
Check out the link below. It will take you to www.FlexibleAssembly.com. They are an URYU distributor and have a lot of technical information listed on their site. This link has specific information on how to adjust the torque on an URYU screwdriver.
http://www.flexibleassembly.com/URYU-LT-Torque-Adjustment
The use of a digital torque tester can be very important when it comes to trying to accurately calibrate your tools. Below is a link to an FAQ page about torque testers. I’ve had a lot of success with using this site to find technical support related information.
http://www.flexibleassembly.com/Torque-Testers-and-Torque-Meters
-Deezy
Mar 31, 2009 | Air Tools & Compressors
Torque setting
Ok, lets see- I still have my old official shop manual for that bike...Cylinder head nut torque is 16-20 ft lbs,Cam sprocket bolt torque is 12-17 ft lbs, Valve adjuster cover torque is 7-10 ft lbs, Cyl head cover torque is (6mm)- 7-10 ft lbs (7mm) 9-12ft lbs, Rocker arm adjuster nut torque is 11-13 ft lbs.
Nov 20, 2008 | 1984 Honda FT 500
Imada I80 Torque Tester 0.30 to 70.00 in-lb Range 0.01 in-lb Logo
66 people viewed this question
Top Imada Tools & Hardware - Others Experts
Are you an Imada Tool and Hardware - Other Expert? Answer questions, earn points and help others
