Question about Fetco International CBS-2052
Fetco Coffee brewer CBS-5IH isn't brewing hot coffee and isn't producing hot water
How to fix hot water
2 Suggested Answers
SOURCE: Fetco CBS-31Aap over brewing
It's possible that your airpots are too small. We have the same machine and 3.0 litre airpots and it's perfect. But I can't find the right filters for it! I'm currently using a bunn filter and MOST of the time I end up with a lot of grounds in my coffee.
Posted on Nov 01, 2008
When I brew on one side of my Fetco cbs-52h, both sides brew. Any idea?
Refilling water in the tank does not stop at the appropriate level. Is much higher than the height of the level sensor which causes the other party also poured water. Descaling of the level probe should solve the problem.
May 04, 2014 | Fetco International Coffee Makers &...
Fetco cbs 51h drips water
Replace the brew solenoid on top of the sprayhead. Either something is keeping the spring and gasket open or the gasket is damaged. Get a rebuild kit from fetco or a new brew solenoid.
Oct 02, 2013 | Fetco International Coffee Makers &...
Cbs 2031 will randomly push 2 0nces to 30 ouncec of water out overflow next to spray head
The bypass valve is letting by and needs to be replaced. You should be able to get one from your local agent and swapping it out is a simple enough task requirring only basic hand tools and some PTFE tape.
Access to the valve is via the top cover and the valve is located logically close to where the water is leaking, just follow the pipes.
Jun 23, 2012 | Fetco International CBS-2031
Fetco cbs-51h coffee maker not heating hot enough. turned thermostat all wasy up. coffee luke warm.
It can be the Temperature sensing probe, heating element or a loose/burned wire connection.
Adjusting the brew temperature is not going to help
Jan 17, 2011 | Coffee Makers & Espresso Machines
When I turned on the brewer the message er 100 lit up. it says its a filling problem of some sort. how do i fix this?
Check the inlet solenoid on the unit the screen may be clogged and not allowing water to flow or the solenoid is damaged and needs to be replaced. Also check the level probe that might be damaged as well.
Oct 07, 2009 | Fetco International LUXUS® 5000 CBS-52H-15...
Fetco coffee brewer CBS- 2052 error 102 unwanted fill
Probably the filling valve allows water when is in a close position.
Jan 23, 2009 | Fetco International CBS-2052
Jun 18, 2008 | Fetco International CBS-31AAP
Not heating
yes just remove the cover lot of time it just thr femelle therminal that overheated cut the old therminal clean contact put a new therminal cheers
Jan 21, 2008 | Fetco International CBS-51H-10 Coffee...
Coffee Makers & Espresso Machines Logo
Top Fetco International Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Fetco International Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
