Question about Mitsubishi WT-46809 46" Rear Projection Television
Wont stay on
When I turn on the power with remote or power button, the tv clicks, the timer button turns green, and it clicks and turns off after 3 seconds.
  • 2 more comments
  • BRIAN G
    BRIAN G Oct 09, 2007
    After pressing the menu and input buttons, It blinks two times/pause/then blinks one time. Hope this helps.
  • BRIAN G
    When is the best time to do a live chat with you? You do not show to be on right now. Thanks again and let me know.
  • BRIAN G
    BRIAN G Oct 11, 2007
    I will try to be here tomorrow morning Central time and find you, if not I will try someone else on the live chat. thanks for you time
  • BRIAN G
    I am here again, Troylove, can you help me?
    Genius:
  • 1,153 Answers
I can help u fix in live chat!
Posted on Oct 08, 2007
  • 1 more comment
  • Lashawn Robinson Oct 09, 2007
    Turn on to let tv shutdown then press the input and menu button on front panel together for 5 seconds. After the LED will blink a two digit sequence. This will be 1 set blinks then a short pause then another. Let me know what it says.
    Ok 2-1 is X-ray protect. (high voltage or beam current). If your not tech savvy then you might need Live Support! I can talk you through there but not here. Fix is Check IC5a03!
    I am online now and will be for another 1hour
SOURCE:
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
Power will not stay on
A problem in a certain parts or IC's on the board. You need a support technician for him to have a test inside the equipment. All parts have to be undergo into tester device to determine which is faulty.
thanks.
Feb 23, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Green light stays on when trying to turn off tv. picture go's off when cable remote is used but green light stays onand you can see that screen is still on?
You need to set up the cable box remote for your TV , now you are just turning off the cable box. Some cable boxes have a switched plug on the back that will turn on and off with the box. If yours has the switched receptacle you can use that to turn the TV on and off by plugging your TV into the switched receptacle. Make sure the TV power is on, the receptacle will kill the power so the clock on the TV wont work. Otherwise you need to set the code for your TVs remote and use the system power button.
Apr 23, 2014 | Mitsubishi LT-46153 LCD TV
Sony bravia screen just stays on black and wont go to picture.
It sounds like a main board failure but could be a power supply issue as well. The set will need to be diagnosed
Oct 01, 2012 | Sony Bravia Kdl - 60Ex700 60 inch 1080P...
Have lost instructions to Emerson universal jumbo remote
Using Code Search:
1. Turn on the device you want to program into the remote.
2. Point your remote control at the device
3. Press and hold the "Code Search" button for about 3 seconds until the light on the remote stays on.
4. Press the button on the remote for the device you want to program. Push the "TV" button to program the TV, press the "DVD" button to program the DVD player, etc. The light on the remote control will blink and stay on.
5. Slowly press and release the power button repeatedly until the device turns off. Each time you push the power button the light should blink once.
6. Press "Enter" to save the code into the remote and the light will turn off.
Program a Manual Code:
1. First turn on the device that you want to program such as your TV or DVD player.
2. Point your remote control at the device.
3. Press the button on the remote that corresponds to the device. If you want to program the TV, press the TV button.
4. Press the "Code Search" button for about 3 seconds until the light stays on.
5. Enter the code for your device using the number pad. The light will blink each time you push a button. If the code works, the light will turn off. If the light flashes, that means the code did not work. There may be multiple codes for a device. If a code does not work, start from the beginning by holding down code search until the light stays on and use a new code.
6. Press the power button to test if your device turns off. It it does not turn off, repeat the process with a new code.
Retrieving the Code for your Device:
If you used the code search function to program your device and want to know the code for future reference, you can retrieve the code from the remote. To do this:
1. Press and hold the Code Search for 3 seconds until the light stays on.
2. Press the device button for the code you want to retrieve. Press TV to get the TV code, etc. The light will blink once and stay on.
3. Press the number buttons from 0 to 9. When the light blinks once, that signals the first number of the code.
4. Repeat for the 2nd and 3rd digits of the code. The light will turn off after you retrieve the 3rd digit.
Programming the Sleep Setting:
1. Press and hold the "SLEEP" button until the light stays on.
2. Use the number pad to enter 2 digits for how many minutes to use for the timer (01 to 99 minutes). The light will turn off and start timing.
3. Make sure the remote is pointing at your device.
4. To cancel the sleep timer, press the power button once or hold down the sleep button until the light flashes once.
Here is a list of the Emerson Universal Codes:
http://www.jumboremotecontrol.com/remote_control_code_list.html
Here is a copy of your manual: http://www.jumboremotecontrol.com/innovage_jumbo_remote_manual.PDF
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 08, 2011 | Televison & Video
Lost the remote to the tv now it wont turn on manually
the remote has nothing to do with the tv not turning on or off you should be able to push the power button on front of the tv and turn it on that way.if its not staying on then theres something more wrong than just a lost remote
Jan 21, 2009 | Mitsubishi WS-55513 55" Rear Projection...
what is the model number of your set?
Mar 09, 2008 | Televison & Video
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
Same TV, same problem. I'll be watching for an answer. The dealer says it is old and outdated and not worth fixing.
Oct 07, 2007 | Mitsubishi WT-46809 46" Rear Projection...
My tv wont turn on
I am having the same issue. I think it's the bulb.
Aug 04, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Mitsubishi WT-46809 46" Rear Projection Television Logo
119 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
