I have the 1 gallon Petco brand Mini Aquarium Kit but want to know if it is possible to order replacement parts, either the light socket/housing itself if possible or a whole new lid. I purchased this kit used and not from Petco or any online retailer While the tank, underground filter, and lid are all good, and the switch and plug to attach the light housing under the lid are still intact, the light socket/housing is missing. I've looked on the Petco website but can't seem to find any info about replacement parts for this kit
4 Suggested Answers
  • 641 Answers
SOURCE: For those looking for an owners manual
Thanks a lot for the information !
Posted on Aug 15, 2007
SOURCE: Stacking Frigidaire dryer on washer using stacking kit 5303937141
i have the two brackets but have no idea how they attach. does the top come off the washer?
Posted on Jun 30, 2008
SOURCE: Outer tub bearings are gone
My bearings went out too and I found this site http://www.neptunebearing.com/ Ordered the bearings and the Tony Tool. My son and I replaced the bearings in about 2 hours!
Posted on Apr 03, 2009
Mini-bow 2.5 gallon aquarium setup
Thank you for advising us of your recent purchase. Do you have a question for the forum?
Dec 03, 2013 | Fish
I have the Petco brand Mini Aquarium Kit but need either the light housing or a new lid. The switch is still intact and the plug to attach the light under the lid, but the socket/housing for the bulb is...
go to bunnings or electrical store and ask for what you need like how you asked it can be hard to enstall your self but if you call some one or make minor will go smooth
Nov 21, 2013 | Washing Machines
The circulation pump on my Fluval Spec V 5 gallon quit working. I bought the tank only three months ago. Any thoughts on why it conked out in such a short time?
did it "conk" out or is the pump impeller stopped by a buildup of material ?? the reason I say this its very unusual for a aquarium pump to go completely out (ive had one running 24/7 for ten years) but in that ten years ive replaced two impellors and cleaned it out over one hundred times , and yes three months is the perfect time period for a cleaning needed !!!
Aug 11, 2013 | Fluval Spec V 5 Gallon Aquarium Kit
How to fix fluval led
on this tank the lights are built into the filter pump housing , if they go bad it might be possible to retrofit a new sealed light bar into the same space , but you will need to have previous knowledge of electronics and specify L.E.D. lights as they don't work like regular light bulbs but require a special kind of power or will be damaged if hooked to wrong type of power I suppose its possible to use batterys but id have no idea how long that would work
Jan 29, 2013 | Fluval LED Edge Aquarium 6-Gallon Aquarium...
How do I know what size heater to buy for my aquarium?
The basic rule is that a heater needs to use 5 watts in order to heat 1 gallon of water. For example, if your aquarium has 10 gallons, then you need a 50 watts heater. If you have a 50 gallons aquarium, then you need a 250 watts heater.
Sep 05, 2012 | Fish
Where can I buy some aquarium gravel online?
There are several brand and varieties of gravel to choose from. I would be more than happy to post some of the more preferred brands here for you; however the choice is not so simple. Make sure you know what kind of gravel you need for the type of tank you have.
http://www.petsmart.com/product/index.jsp?productId=3577442
http://www.petco.com/product/112362/CaribSea-Instant-Aquarium-Crystal-River-Gravel.aspx
http://www.aquariumguys.com/gravel.html
Aug 28, 2012 | Aquaculture Fish
How can I properly determine the amount of watts per gallon of lighting I need for my aquarium?
How many watts you need depends on the type of plants and the volume of the tank. Here is an excerpt from an article that will help you determine proper wattage.
Instructions
Identify the species of plants you have in your tank or that you plan to put in your tank and how much light that species needs. Each species of plant will have an optimal lighting requirements, from low light to bright light. To determine the plant species, compare photos on the Aquarium Plants Photos and Profiles page of the Aqua Hobby website, or take samples of the aquatic plants to your local aquarium store for identification.
Write down how much lighting each of the plant species in your tank needs. Give each plant a rating of low, medium or bright. The books "The Complete Fishkeeper" and "Freshwater Aquariums for Dummies," as well as your local fish store, are good sources of information for this.
Review your list and determine what type of plant dominates your tank. For example, if you have mostly plants that need bright light, then use a bright-light formula. If you have an equal mix of plant lighting needs, then use a medium-light formula.
Calculate a range of watts of lighting you need for your tank with one of the following formulas, depending on the amount of light you determined you needed for your plants. For low light, multiply one and two by the number of gallons. For medium light, multiply two and three by the number of gallons. For bright light, calculate three and five by the number of gallons. For example, for a 20-gallon tank with plants that need medium light, you would get a range of 40 to 60 watts (2 x 20 = 40 and 3 x 20 = 60).
Read more: How to Determine Watts Per Gallon for Aquarium Lighting ' eHow.com http://www.ehow.com/how_8014286_determine-per-gallon-aquarium-lighting.html#ixzz23KB8HErA
Aug 14, 2012 | Fish
Is it possible to make my own aquarium filter at home?
I have found you a how-to guide on making your own filter for your aquarium; however it is only productive for aquariums containing up to 40 gallons of water.
http://www.ehow.com/how_7718545_make-aquarium-water-filter.html
Aug 14, 2012 | Fish
Washing Machines Logo
69 people viewed this question
Top Washing Machines Experts
