Question about Dynex 32 in. LCD Flat-Panel HDTV
I have a dynex tv with basic cable coaxle plugged in. It receives around 20-25 channels after running auto scan with the source as "cable". After powering the tv down and then back on it defaults to "air" and none of the found channels are stored. I must change it to "cable" and run auto scan again. Any ideas?
    Scholar:
  • 140 Answers
In the TV se-up menu look for a place to set the 'Default antenna input' to cable/coaxial.
Posted on Nov 21, 2013
SOURCE: Dynex 32" 720 LCD HDTV - no channel listing after run auto scan?
Excuse me but the other answers are written by people who have not actually confronted the problem and are just guessing. They are all wrong. Here's the answer:
If your TV is expecting a TV input, it will keep searching for at least one TV channel on cable or antenna. If you only have a DVD player plugged in, for example, or if your cable is hooked up wrong, so there's no video signal on it, the TV will keep searching forever. (This is an unforgivable design flaw, by the way. But then, it was a cheap TV, wasn't it?)
To solve the problem, look at your remote control. You will find input buttons. Mine are small, along the top, right under the "power" button. Try pressing "video" for example, instead of TV. That stops the TV from hunting for TV channels.
Have a merry Christmas. Enjoy your new TV. Watch it in moderation and eat fruit and vegetables every day.
Posted on Dec 25, 2009
bschilz
  • 2049 Answers
SOURCE: I am looking for the owners manual for a dynex 32
Here's a link to the manual...
http://www.dynexproducts.com/skins/skin_1/Topics/Documents/07-062_DX-R32TV_WEB.pdf
Posted on Sep 04, 2009
SOURCE: My tv keeps saying to run auto channel scan.
FIRST, you must check ALL antenna connection, and if possible, try another "Known Good" antenna system. If it proves that the antenna system is all OK, then I fear your Tuner, has failed, this is a common event, that I get from time to time at my shop. Usually, it is a straight forward job and the cost would be about $250 - $350, depending exactly what is going on. However it would be best to get a "Quote" first, before proceeding, as this may only be a symptom, of a larger underlying problem, that may indeed cost much more.
Posted on May 23, 2010
  • 1779 Answers
SOURCE: My 22 month old Dynex lcd started changing
You will have to replace the Main Board. I suggest if your going to do the work yourself you better take the numbers off the main board and try www.shopjimmy.com .
Posted on Nov 30, 2010
SOURCE: Dynex TV losing favorite channels
Try changing the batteries in your remote. If the batteries are weak they may not be sending strong enough signals to the TV thus sending different signals than you meant.
Posted on Jul 13, 2011
Hi, I have a DYNEX 32in. 720p Flat-Screen TV. I am on Antenna & I can't get any channels below 16.1. I did Auto-scan. Anyone have any ideas? Thanks, AngelRock.
Do you have any other devices in your setup (cable box/modem, satellite, receiver, gaming consoles, etc)? What type of connection are you using (HDMI, composite/component)? Are you trying to obtain additional channels through a cable scan, or through basic antenna?
Mar 10, 2014 | Dynex Televison & Video
Dynex 32" tv cant get regular channels,
How is your TV setup--do you have a cable box, satellite, or basic cable? I would recommend going into the settings and running a channel search.
Press Menu. The on-screen display menu options with Setup highlighted.
Press RIGHT arrow to enter the sub-menu, then press DOWN or UP to highlight AUTO CH SEARCH.
Press ENTER or RIGHT arrow to start the search.
Oct 10, 2013 | Dynex DX-LCD19-09 19 in. LCD TV
Can't get rid of "Please Run Channel Auto Scan" stays on tv screen
for some reason it is not seeing you cable signal. you will need to make sure you have it set up for cable and not air. check your input options, like tv/av/hdmi/ ect hope this helps
Aug 05, 2012 | Dynex DX-LCD32-09 LCD TV
When setting up a new TV, it keeps telling me to "Please run channel auto scan." But it also states that if I sellect Cable/satellite, that the tv does not need to run the auto scan. When you...
you need to select cable from off your remote and run the auto scan.even if it says you does not need to run auto scan still run the auto scan.good luck.
Sep 25, 2011 | Dynex Televison & Video
I have a Curtis 24 inch Full HD LCD TV 2425A never used Trying to set it up and their was no book in the box it says to run Channel Auto scan .it is hooked up to Dish satelite ant. .to run the auto...
Used the tv remote go into tv Menu goto SETUP go down Ch. enter pick CABLE and enter again.Tv now will go into auto scanning for CABLE channels.After the auto scan done for the CABLE channels are finish.After this u will able to go to channel 60 to used the dish remote.
Apr 24, 2011 | Curtis Televison & Video
I just bought a new dynex 32 inch that did not come with a manual. I attached the cable into the correct area however I am still unable to see my cable channels even when changing the input. What am I...
Check this link to download the user's guide or quick setup guide. Press menu > channel, go down to TV source change it to cable and go down to auto scan and press > to start programing the channels into the LCD memory.
Sep 14, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex 32 Inch Installation Problem
Hi I Just Bought A Dynex 32 Inch HDTV. I Did A Auto Scan And It Didnt Pick Up Any Digital Channels? Am I Suppose To Have An Antenna Or Digital Box? How Do I Get Th Channels To Come In?
Nov 28, 2009 | Televison & Video
How do i run a channel scan? there is nothing in the manual
Found this in the most frequently asked questions at the Dynex customer support website on page 3. the website is:(http://www.dynexproducts.com/pc-680-23-dynex-32-720p-flat-panel-lcd-hdtv-matte-black.aspx) You can also call the customer support telephone number at 1-800-305-2204. between the hours of 7am-12am CST. Give them the model number of you television and tell them you are having problems completing the autoscan of the television. I hope this information helps you with your problem. 1.How do I set up my channels or run an autochannel search? 2.Are you using a cable/satellite box, cable connected directly to the TV, or an antenna? 3.If you are using a cable or satellite box you must use the remote that came with that box to change channels. 4.Make sure you have the correct input selected to view channels via the cable or satellite box. For example, if the cable or satellite box is connected via component cables please press input and select Component 1 or Component 2 to view your channels. If you are using cable connected directly to the TV: 1.Press MENU. The on-screen menu opens. 2.Press < or > to select Channel, then press v to access the Channel menu. 3.Press ^ or v to select Air/Cable, then press < or > to select Cable. 4.Press ^ or v to select Auto Scan. Press > or ENTER. 5.Press ^ or v to select Cable System, then press < or > to select your type of cable or satellite system. You can select STD, IRC, HRC, or AUTO. If you are not sure what type of system you have, select AUTO. 1.Press ^ or v to select Start to Scan, then press > or ENTER to start scanning. Your TV memorizes all cable channels you receive. If you are using an antenna: 1.Press MENU. The on-screen menu opens. 2.Press < or > to select Channel, then press v to access the Channel menu. 3.Press ^ or v to select Air/Cable, then press < or > to select Air. 4.Press ^ or v to select Auto Scan. Press > or ENTER. 5.Press ^ or v to select Start to Scan, then press > or ENTER to start scanning. Your TV memorizes all analog and digital channels you receive.
Mar 16, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex (no database) since power outage
What you have to do it go to the TV Menu and go to channel. Then go to channel scan and do one of those. THe problem is that is just doesnt know where to look for channels, but a quick scan will fix that.
Oct 03, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Cable TV connection
Hi, A couple of possibilities: 1. Line loss, some of the cables might be too long, shorted, loose ground, not connected right; 2. Splitter - passive splitter, you might be better off using a distribution amplifies (with gain control pref); 3. RFI - TV interference from external sources. Hope this be of some help/idea. Post back how things are or should you need further information. Good luck and kind regards.
Sep 02, 2007 | Televison & Video
Dynex 32 in. LCD Flat-Panel HDTV Logo
250 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
